config fuer 7945G ?
McRib
27 Jan 2005
Asterisk 1.2.16, Phone 7945G -- ist mein Asterisk zu alt ?
Das Phone kommt nur bis zur Registrierung.
Status messages:
16:51:59 SEP001E138Cxxxx.cnf.xml
16:54:47 File Not Found : CTLFile.tlv
16:54:47 No CTL installed
16:54:48 SEP001E138Cxxxx.cnf.xml
16:57:36 File Not Found : CTLFile.tlv
16:57:36 No CTL installed
16:57:36 SEP001E138Cxxxx.cnf.xml
17:00:25 File Not Found : CTLFile.tlv
17:00:25 No CTL installed
17:00:25 SEP001E138Cxxxx.cnf.xml
xmlDefault.CNF.XML:
<Default>
<callManagerGroup>
<members>
<member priority="0">
<callManager>
<ports>
<ethernetPhonePort>2000</ethernetPhonePort>
</ports>
<processNodeName>192.168.0.1</processNodeName>
</callManager>
</member>
</members>
</callManagerGroup>
<loadInformation8 model="IP Phone 7940">P003-07-1-00</loadInformation8>
<loadInformation7 model="IP Phone 7945">P003-07-1-00</loadInformation7>
<authenticationURL></authenticationURL>
<directoryURL></directoryURL>
<idleURL></idleURL>
<informationURL></informationURL>
<messagesURL></messagesURL>
<servicesURL></servicesURL>
</Default>
asterisk debug:
Jan  3 21:16:33 WARNING[14879]: chan_skinny.c:2861 get_input: Skinny Client sent less data than expected.
Jan  3 21:16:33 NOTICE[14879]: chan_skinny.c:2926 skinny_session: Skinny Session returned: Success
    -- Starting Skinny session from 192.168.0.10
Device SEP001E138Cxxxx is attempting to register
Requesting capabilities
Buttontemplate requested
Sending 12SP template to 200@7945G ()
Recieved SoftKey Template Request
Received SoftKeySetReq
RECEIVED UNKNOWN MESSAGE TYPE:  c
Received CapabilitiesRes
Received LineStateReq
RECEIVED UNKNOWN MESSAGE TYPE:  9
Received Time/Date Request
Jan  3 21:16:33 WARNING[14880]: chan_skinny.c:2861 get_input: Skinny Client sent less data than expected.
Jan  3 21:16:33 NOTICE[14880]: chan_skinny.c:2926 skinny_session: Skinny Session returned: Success
was verwendest als chan_sccp?
so?
kannst Du vielleicht noch mal schreiben welche das waren, dann könnten wir das Problem gemeinsam lösen?
Danke fuer das freundliche Angebot :-D
Habe den Kram jetzt installiert und nur eine Fehlermeldung ist uebrig: Er kann sccp.conf nicht finden und es deshalb auch nicht nach /etc/asterisk kopieren...
Auf http://chan-sccp.org/index.php?display=config gibt es z.B. ein sccp.conf nur taucht dort 7945 nicht auf... Immerhin unterscheidet es sich deutlich vom 7940...
nimm einfach mal zum test ein 7970.
Es ist nicht wirklich notwendig das richtige Phone einzustellen
Die Line wird noch nicht registriert.
Bei "id" und "pin" steht "future use" ... Desweiteren gibt es eine [devices] und eine [lines] Sektion... irgendwie verwirrend ... :-/
Gibt es die Moeglichkeit das Datum als 04-Jan-2008 anzeigen zu lassen ?
Lishheshuyg
