DSL sync, 08.04.01 and 04.02
livio
21 Jan 2006
Hi guys,
I was successfully using an Annex B Fritz Fon Wlan modified into an Annex A on the italian network, till I decided to upgrade from the 08.04.01 to the 08.04.02 firwmare version. :mad:
The sync comes and goes about every 20 seconds makeing the router unable to connecting me to the internet.
Before the upgrade the signal to noise ratio was good (over 30) and the line attenuation was low (about 15).
The worst thing is that I tried to downgrade to the stable 08.04.01, but it doesn't work at all. It is not able to sync. Everything is the same, nothing except the double firmware update (08.04.01 -> 08.04.02 -> 08.04.01).
What did the 08.04.02 version modified on my fritz? How can I fix it?
If I remember correctly on the dsl information owerview page, the dslam was alcatel H2 and now it seems to try with H0 or H1. Is it important? How can I force a different one to see if it works?
Thank you in advance.
Livio
densen420
