[ENGLISCH] dialing rule problem / bug?
pepsi_max2k
27 Mai 2008
I've found a small issue in the dialing plans on my 5050, has anyone experienced something similar or am I doing something wrong?
Other than the 3 undeletable emergency numbers, if I have just:
1  	Internet: XYZ
Any number starting with 1 (like sipgate's 10000) will go out via voip xyz, telnet output is normal. But, if I then add:
01  	Festnetz
1  	Internet: XYZ
Then all outgoing numbers beginning 01 or 1 will fail, and I just get silence. In telnet it looks normal at the start but it just stops at the first output of:
<<<UDP Status: 100 trying -- your call is important to us
Also, 01 can be Festnetz or Internet, either way it just fails. And yet...
011  	Festnetz
1  	Internet: XYZ
Now it works again :| With all of them the number seems to go through ok, telnet output reads "sip:[email protected]" for all calls, and it's just with the 01 and 1 that output just hangs at the Status 100 message.
It seems like it's stripping the 0 from the beginning of the rules, so 01 is the same as 1, and if there's two dial rules for the same number then it causes some weird issue. It's also the same if you have, say, 02 and 2, 07 and 7, etc.
Anyone else got the same problem, or know what I'm doing wrong? I guess I can work around it by just adding 011, 012, 013, 014, 015, etc etc, but christ is there anything on these boxes that actually works without a million workarounds? :(
fwiw i have 00, 44, 0, 1XXX as my regional numbers, but non of them ticked (i'm just using sipgate to test so don't need regional prefixes, though afaik they make no difference to the above issue).
EDIT: I'm running Freetz 1.0 w/ 04.31 now and it seems fine. Dunno what caused the original bug on AVM 04.31 but at least I don't gotta do a million dialplans now :)
Flo3
