Environment variables for Fritz!Box fon
warp_be
6 Feb 2007
i have a fritz!Box fon, on which i tried to update the firmware.
I did something wrong, and after playing a long time with image, recovery tools, and environment variables, i'm now able to boot the fritz!box.
But when i configure for internet, it tells me that there's no configuration for internet.
If i come back on the configuration page, i can see my username for the ADSL connexion.
I guess that i did something wrong with the environment variables.
Can someone show me his environment variables (both 'env' and 'cat /proc/avalanche/env')
Thanks !!
FRITZ!Box 7141 with DS-Mod
env:
/var/mod/root $ env
CONFIG_WLAN=y
CONFIG_USB_HOST_AVM=y
CONFIG_AB_COUNT=2
CONFIG_I2C=n
CONFIG_JFFS2=n
CONFIG_CAPI_NT=n
USER=root
CONFIG_STOREUSRCFG=y
CONFIG_NFS=n
CONFIG_UBIK2=n
CONFIG_CAPI_XILINX=y
LD_LIBRARY_PATH=/mod/lib
CONFIG_USB=n
HOME=/mod/root
OEM=1und1
CONFIG_PRODUKT_NAME=FRITZ!Box Fon WLAN 7141 (UI)
CONFIG_VDSL=n
wlan_cal=000E,000D,0010,00E0,010A,00DC,010A,0340,0328
CONFIG_ENVIRONMENT_PATH=/proc/sys/urlader
CONFIG_USB_HOST_TI=n
CONFIG_LED_NO_DSL_LED=y
CONFIG_ASSIST=y
CONFIG_USB_STORAGE=y
CONFIG_CAPI_POTS=y
CONFIG_SUBVERSION=ds-0.2.9
CONFIG_VERSION=04.25
HWRevision_ATA=1
CONFIG_BLUETOOTH_CTP=n
CONFIG_SERVICEPORTAL_URL=http://www.avm.de/fritzbox-service-portal.php?hardware=108&oem=1und1&language=de&country=&version=40.04.25&subversion=0.2.9
CONFIG_ROMSIZE=8
CONFIG_FIRMWARE_URL=http://www.avm.de/fritzbox-firmware-update.php?hardware=108&oem=1und1&language=de&country=
CONFIG_PRODUKT=Fritz_Box_7141
HWRevision=108
HWRevision_BitFileCount=
ANNEX=B
CONFIG_XILINX=y
CONFIG_VERSION_MAJOR=40
CONFIG_BUTTON=y
LOGNAME=root
CONFIG_USB_PRINT_SERV=y
CONFIG_VPN=n
CONFIG_ETH_COUNT=1
CONFIG_UPNP=y
CONFIG_CAPI=y
TERM=xterm
CONFIG_MAILER=y
CONFIG_TR069=y
CONFIG_CDROM_FALLBACK=n
CONFIG_DECT=n
CONFIG_WLAN_WDS=y
PATH=/sbin:/bin:/usr/sbin:/usr/bin:/mod/sbin:/mod/bin:/mod/usr/sbin:/mod/usr/bin
CONFIG_INSTALL_TYPE=ar7_8MB_xilinx_1eth_2ab_isdn_te_pots_wlan_usb_host_49780
CONFIG_NAND=n
CONFIG_WLAN_1130TNET=n
CONFIG_CAPI_UBIK=n
enable_ata=1
CONFIG_MEDIASRV=n
CONFIG_OEM_DEFAULT=avm
CONFIG_AUDIO=n
CONFIG_ATA=y
CONFIG_HOMEI2C=n
CONFIG_VLYNQ=y
CONFIG_WLAN_1350TNET=y
CONFIG_VLYNQ_PARAMS=vlynq_reset_bit_0=17
SHELL=/bin/sh
CONFIG_MEDIACLI=n
CONFIG_USB_WLAN_AUTH=y
CONFIG_HOSTNAME=fritz.fonwlan.box
CONFIG_CDROM=n
CONFIG_AURA=n
ETC_CONFIG_PATH=/etc/init.d/rc.init
Language=de
CONFIG_CAPI_TE=y
CONFIG_ANNEX=B
PWD=/var/mod/root
Country=049
CONFIG_VLYNQ0=3
CONFIG_TAM_MODE=0
CONFIG_WLAN_GREEN=n
TZ=CET-1CEST,M3.5.0,M10.5.0
CONFIG_VLYNQ1=0
CONFIG_CAPI_MIPS=n
OEM_DEFAULT_INDEX=
CONFIG_BLUETOOTH=n
CONFIG_TAM=n
CONFIG_ATA_FULL=n
CONFIG_RAMSIZE=32
CONFIG_DSL=y
CONFIG_FON=y
Patrick89
