[Erledigt] Brauche Hilfe bei der Deutung meiner Syslog
gismotro
5 Sep 2007
Hallo Freunde,
meine Fritzbox schreibt mir das Syslog voll und ich weiß nicht was das bedeutet. Könnte einer der wissenden mir das mal entschlüsseln ?
Jun 16 19:33:24 fritz user.info kernel: clusters badly computed (47628 != 47566)
Jun 16 19:33:24 fritz user.info kernel: clusters badly computed (47629 != 47567)
Jun 16 19:33:24 fritz user.info kernel: clusters badly computed (47630 != 47568)
Jun 16 19:33:24 fritz user.info kernel: clusters badly computed (47631 != 47569)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47632 != 47570)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47633 != 47571)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47634 != 47572)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47635 != 47573)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47636 != 47574)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47637 != 47575)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47638 != 47576)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47639 != 47577)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47640 != 47578)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47641 != 47579)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47642 != 47580)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47643 != 47581)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47644 != 47582)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47645 != 47583)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47646 != 47584)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47647 != 47585)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47648 != 47586)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47649 != 47587)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47650 != 47588)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47651 != 47589)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47652 != 47590)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47653 != 47591)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47654 != 47592)
Jun 16 19:33:25 fritz user.info kernel: clusters badly computed (47655 != 47593)
[u.s.w.]
Die Anzeige meiner uStor02 sieht auch merkwürdig aus ?
Edit: Nach einem Reload hat sich das Syslog wieder beruhigt und die Anzeige ist wieder normal, aber komisch ist das schon.
Wäre über eine Erklärung / Ansatz zur Fehlersuche Dankbar.
Hi Gismotro,
Handelt es sich dabei um eine Platte oder einen Stick?
Ziehe ihn einmal sauber ab und überprüfe ihn am PC. Mein Laptop erzählte mir letztens was von Clustern und dann war nach den Neustart die Platte im Allerwertesten :noidea: Mal ein Versuch ...
Und :gruebel: Isse nu putt?
Versuche es einmal mit Chkdsk / defrag oder ähnlichen Programmen.
Nach dem Reboot der Box läuft die Platte wieder Fehlerfrei. Keine Ahnung welcher Dienst oder was auch immer da stehen geblieben ist oder sich im Freetz oder in der AVM-Software aufgehängt hatte.
Anscheinend wurde auf eine Datei auf einem FAT-Dateisystem geschrieben. Die Anzahl der Blöcke, die die Datei hätte haben sollen, stimmte nicht mit der tatsächlichen Anzahl der Blöcke überein. Da die Differenz immer gleich ist, betrifft es wohl nur eine Datei. Ein chkdsk des Dateisystems wäre angebracht.
OK, danke. Werde ich mal machen.
Edit: laut google soll es der Befehl fsch sein, der geht aber nicht unter freetz, oder ?
/var/media/ftp/uStor02 # /var/media/ftp/uStor02 #fsch /dev/sda2
-sh: /var/media/ftp/uStor02: Permission denied
/var/media/ftp/uStor02 # sudo fsch /dev/sda2
-sh: sudo: not found
fsck, nicht fsch ;)
Einen USB-Speicher mit FAT würde ich an ein Windows-System anschließen und dort testen lassen.
Unter Linux gibt es fsck.vfat. fsck sollte fsck.vfat aufrufen, wenn das Dateisystem als vfat erkannt wird und fsck.vfat vorhanden ist. Ich weiß aber nicht, wie gut fsck.vfat ist im Vergleich zur Prüfung unter Windows.
Gismo, ich hab mir dafür die dosfstools mit ins freetz-image gebaut. Dann kannst du das gleich von der Box durchführen lassen.
stego88
