[Erledigt]Timer-Probleme (War:Wie mit Konferenzen arbeiten?)
ike
Aktives Mitglied
18 Apr 2005
Hi!
In der Anleitung steht so schön:
Each extension you create will have its own conference. For example extension 200 has conference 8200. Just dial 8200 to get into your conference. If you dial from 8200 you are the moderator.
Also habe ich ja wohl - wenn ich die Extension 11 habe, die Konferenz 811.
Ich wähle also "811" und was passiert: "Das war keine gültige Konferenznummer". (in der meetme_additional.conf ist die Nummer aber angegeben) Irgendetwas muß also anscheinend noch geschehen, damit eine Konferenz gestartet werden kann, aber was?
Update:
So sieht mein Logfile aus:
Sep  7 14:39:15 VERBOSE[2337]:     -- Goto (from-internal,817,5)
Sep  7 14:39:15 VERBOSE[2337]:     -- Executing MeetMe("SIP/17-d8ad", "817|asM") in new stack
Sep  7 14:39:15 VERBOSE[2337]:   == Parsing '/etc/asterisk/meetme.conf': Sep  7 14:39:15 VERBOSE[2337]:   == Parsing '/etc/asterisk/meetme.conf': Found
Sep  7 14:39:15 VERBOSE[2337]:   == Parsing '/etc/asterisk/meetme_additional.conf': Sep  7 14:39:15 VERBOSE[2337]:   == Parsing '/etc/asterisk/meetme_additional.conf': Found
Sep  7 14:39:15 WARNING[2337]: Unable to open '/dev/zap/pseudo': No such device or address
Sep  7 14:39:15 ERROR[2337]: Unable to dup channel: No such device or address
Sep  7 14:39:15 WARNING[2337]: Unable to open pseudo channel - trying device
Sep  7 14:39:15 WARNING[2337]: Unable to open pseudo device
Sep  7 14:39:15 DEBUG[2337]: Ooh, format changed from unknown to ulaw
Sep  7 14:39:15 VERBOSE[2337]:     -- Playing 'conf-invalid' (language 'de3')
Sep  7 14:39:16 WARNING[2337]: Stale nonce received from '<sip:[email protected];user=phone>'
Sep  7 14:39:19 VERBOSE[2337]:   == Spawn extension (from-internal, 817, 5) exited non-zero on 'SIP/17-d8ad'
Sep  7 14:39:19 VERBOSE[2337]:     -- Executing Macro("SIP/17-d8ad", "hangupcall") in new stack
Sep  7 14:39:19 VERBOSE[2337]:     -- Executing ResetCDR("SIP/17-d8ad", "w") in new stack
Liegt es am fehlenden Timer-Device? ztdummy und Ähnliches laden alle nicht:
[root@asterisk asterisk]# insmod /lib/modules/2.4.21-32.EL/misc/ztdummy.o
/lib/modules/2.4.21-32.EL/misc/ztdummy.o: unresolved symbol unlink_td
/lib/modules/2.4.21-32.EL/misc/ztdummy.o: unresolved symbol alloc_td
/lib/modules/2.4.21-32.EL/misc/ztdummy.o: unresolved symbol delete_desc
/lib/modules/2.4.21-32.EL/misc/ztdummy.o: unresolved symbol uhci_devices
/lib/modules/2.4.21-32.EL/misc/ztdummy.o: unresolved symbol uhci_interrupt
/lib/modules/2.4.21-32.EL/misc/ztdummy.o: unresolved symbol fill_td
/lib/modules/2.4.21-32.EL/misc/ztdummy.o: unresolved symbol insert_td_horizontal
Update2:
Es liegt wohl am Timer. Jedoch habe ich gleich haufenweise Probleme:
  • Ich habe keine Digium-Karten installiert
  • Ich habe kein USB-UHCI
  • Asterisk@Home hat Kernel 2.4, also benötigt ztdummy aber USB-UHCI
  • Für zaprtc dürfte die rtc nicht im Kernel included sein
  • Leider lässt sich der Kernel nicht erneut compilieren, es kommt ein ominöser Fehler beim Compilieren der Module
  • realzap dürfte zu aufwendig sein ...
Was tun?
Der Kernel-Fehler:
In file included from /usr/src/linux-2.4.21-32.EL/include/linux/fs.h:19,
                 from /usr/src/linux-2.4.21-32.EL/include/linux/capability.h:17,
                 from /usr/src/linux-2.4.21-32.EL/include/linux/binfmts.h:4,
                 from /usr/src/linux-2.4.21-32.EL/include/linux/sched.h:10,
                 from /usr/src/linux-2.4.21-32.EL/include/linux/mm.h:22,
                 from /usr/src/linux-2.4.21-32.EL/include/linux/slab.h:14,
                 from /usr/src/linux-2.4.21-32.EL/include/linux/proc_fs.h:5,
                 from cpufreq.c:24:
/usr/src/linux-2.4.21-32.EL/include/linux/dcache.h: In function `dget':
/usr/src/linux-2.4.21-32.EL/include/linux/dcache.h:254: warning: implicit declaration of function `__out_of_line_bug_R8b0fd3c5'
cpufreq.c: In function `cpufreq_parse_policy':
cpufreq.c:111: warning: implicit declaration of function `sscanf_R859204af'
cpufreq.c: In function `cpufreq_proc_read':
cpufreq.c:225: warning: implicit declaration of function `sprintf_R1d26aa98'
cpufreq.c: In function `cpufreq_proc_init':
cpufreq.c:327: warning: implicit declaration of function `printk_R1b7d4074'
cpufreq.c: In function `cpufreq_restore':
cpufreq.c:1109: warning: implicit declaration of function `panic_R01075bf0'
make[1]: *** [cpufreq.o] Error 1
make[1]: Leaving directory `/usr/src/linux-2.4.21-32.EL/kernel'
make: *** [_mod_kernel] Error 2
[root@asterisk linux]#
Update:
Wenn die ISDN-Karten drin sind (heute geliefert), erzeugen diese das nötige Timing - Konferenzen gehen jetzt.
tempuser777
