Hi Leute!
Ich habe bei manchen Faxempfang probleme, das Asterisk sofort ein hangup macht. Hier mal die Ausgabe des anrufs.
< Protocol Discriminator: Q.931 (8) len=35
< Call Ref: len= 1 (reference 1/0x1) (Originator)
< Message type: SETUP (5)
< [04 03 90 90 a3]
< Bearer Capability (len= 5) [ Ext: 1 Q.931 Std: 0 Info transfer capability: 3.1kHz audio (16)
< Ext: 1 Trans mode/rate: 64kbps, circuit-mode (16)
< Ext: 1 User information layer 1: A-Law (35)
< [18 01 89]
< Channel ID (len= 3) [ Ext: 1 IntID: Implicit, Other Spare: 0, Exclusive Dchan: 0
< ChanSel: B1 channel
< [1e 02 84 83]
< Progress Indicator (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) 0: 0 Location: Public network serving the remote user (4)
< Ext: 1 Progress Description: Calling equipment is non-ISDN. (3) ]
< [29 05 06 02 0a 0d 06]
< Time Date (len= 7) [ 06-02-10 13:06 ]
< [6c 0a 21 83 32 39 34 32 33 32 32 34]
< Calling Number (len=12) [ Ext: 0 TON: National Number (2) NPI: ISDN/Telephony Numbering Plan (E.164/E.163) (1)
< Presentation: Presentation allowed of network provided number (3) '29423224' ]
-- Making new call for cr 1
-- Processing Q.931 Call Setup
-- Processing IE 4 (cs0, Bearer Capability)
-- Processing IE 24 (cs0, Channel Identification)
-- Processing IE 30 (cs0, Progress Indicator)
-- Processing IE 41 (cs0, Date/Time)
-- Processing IE 108 (cs0, Calling Party Number)
> Protocol Discriminator: Q.931 (8) len=11
> Call Ref: len= 1 (reference 129/0x81) (Terminator)
> Message type: SETUP ACKNOWLEDGE (13)
> [18 01 89]
> ChanSel: B1 channel
> [1e 02 81 82]
> Progress Indicator (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) 0: 0 Location: Private network serving the local user (1)
> Ext: 1 Progress Description: Called equipment is non-ISDN. (2) ]
-- Executing WaitExten("Zap/1-1", "4") in new stack
-- Accepting voice call from '29423224' to 's' on channel 0/1, span 1
< Protocol Discriminator: Q.931 (8) len=8
< Message type: INFORMATION (123)
< [70 02 81 31]
< Called Number (len= 4) [ Ext: 1 TON: Unknown Number Type (0) NPI: ISDN/Telephony Numbering Plan (E.164/E.163) (1) '1' ]
-- Processing IE 112 (cs0, Called Party Number)
< [70 02 81 38]
< Called Number (len= 4) [ Ext: 1 TON: Unknown Number Type (0) NPI: ISDN/Telephony Numbering Plan (E.164/E.163) (1) '8' ]
== CDR updated on Zap/1-1
-- Executing Answer("Zap/1-1", "") in new stack
> Message type: CONNECT (7)
> [18 01 89]
> ChanSel: B1 channel
> [1e 02 81 82]
-- Executing Wait("Zap/1-1", "3") in new stack
< Protocol Discriminator: Q.931 (8) len=4
< Message type: CONNECT ACKNOWLEDGE (15)
-- Executing Macro("Zap/1-1", "faxempfang") in new stack
-- Executing SetVar("Zap/1-1", "FAXFILE=/var/spool/asterisk/fax/asterisk-18990-1139573079.1257") in new stack
-- Executing SetVar("Zap/1-1", "[email protected]") in new stack
-- Executing RxFAX("Zap/1-1", "/var/spool/asterisk/fax/asterisk-18990-1139573079.1257") in new stack
-- Redirecting Zap/1-1 to fax extension
-- Executing System("Zap/1-1", "/etc/asterisk/faxmail "029423224" "[email protected]" "/var/spool/asterisk/fax/asterisk-18990-1139573079.1257"") in new stack
NEW_HANGUP DEBUG: Calling q931_hangup, ourstate Active, peerstate Active
> Message type: DISCONNECT (69)
> [08 02 81 90]
> Cause (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) 0: 0 Location: Private network serving the local user (1)
> Ext: 1 Cause: Normal Clearing (16), class = Normal Event (1) ]
-- Hungup 'Zap/1-1'
BITTE um EURO HILFE
Danke Macsea
< [04 03 90 90 a3]
< [18 01 89]
< [1e 02 84 83]
> [18 01 89]
> ChanSel: B1 channel
> [1e 02 81 82]
< [70 02 81 31]
< [70 02 81 38]
> [18 01 89]
> ChanSel: B1 channel
> [1e 02 81 82]
> [08 02 81 90]
-- Hungup 'Zap/1-1'
BITTE um EURO HILFE
Danke Macsea
