FBF Problem With Asterisk
kandy
19 Feb 2005
I have a problem with my FBF and Asterisk, when I connect the FBF on the network it automaticly register himself on asterisk, but after 15 min the FBF is not register any more. If I pickup the phone and I call everything goes well, but if someone call me they are not able to reach me.
Here you have my sip.conf
[general]
context=default
port=5060
bindaddr=192.168.0.1
srvlookup=no
maxexpirey=1900
defaultexpirey=120
disallow=all
allow=g729
allow=alaw
allow=ulaw
allow=gsm
[700]
type = friend
username = 700
secret = XXXXX
host = dynamic
dtmfmode=RFC2833
callerid="Mio" <700>
context=from-sip
mailbox=700
language=it
canreinvite = no
qualify=30000
nat=yes
if you need
extensions.conf
[from-sip]
exten => 700,1,Dial(sip/700,30)
exten => 700,2,Voicemail(u700)
exten => 700,102,Voicemail(b700)
Any suggestion?
Hmm... is there anything visible in the *-log (/var/log/asterisk/messages) after those 15min?
Are the incoming calls after the 15min still visible on the *-CLI? If they don't reach * at all, it might be some router problem.
If not, whats the status of the FBF in *? (sip show peers)
after some test I reach this point
-- Got SIP response 489 "Bad Event" back from 192.168.0.15
-- Executing VoiceMailMain("SIP/700-a794", "") in new stack
-- Playing 'vm-login' (language 'it')
-- Playing 'vm-password' (language 'it')
-- Playing 'vm-youhave' (language 'it')
-- Playing 'digits/2' (language 'it')
-- Playing 'vm-INBOX' (language 'it')
-- Playing 'vm-messages' (language 'it')
-- Playing 'vm-onefor' (language 'it')
-- Playing 'vm-opts' (language 'it')
-- Playing 'vm-first' (language 'it')
-- Playing 'vm-message' (language 'it')
== Parsing '/var/spool/asterisk/voicemail/default/700/INBOX/msg0000.txt': Found
-- Playing 'vm-received' (language 'it')
-- Playing 'digits/day-0' (language 'it')
-- Playing 'digits/mon-3' (language 'it')
-- Playing 'digits/h-10' (language 'it')
-- Playing 'digits/thousand' (language 'it')
-- Playing 'digits/5' (language 'it')
Apr 12 00:00:36 WARNING[30169]: file.c:475 ast_openstream: File digits/it does not exist in any format
Apr 12 00:00:36 WARNING[30169]: file.c:779 ast_streamfile: Unable to open digits/it (format alaw): No such file or directory
Apr 12 00:00:36 WARNING[30169]: say.c:488 wait_file: Unable to play message digits/it
== Spawn extension (from-sip, 444, 1) exited non-zero on 'SIP/700-a794'
I have the direcory digits/it
Someone knows why I need to pickup the phone in order to have the fritz registered on my asterisk.
I need to configure the fbf in a special way?
:lol:
@kandy
not sure if it will fix your problem, but there is a statement missing in your sip.conf [general] context:
localnet = 192.168.0.0/255.255.255.0
Also, if you want to reach the outside, there should be an
externip =
entry, if you don't have a static IP on your internet connection, get a subdomain via dyndns.org, put that in your router and use that as externip
hth,
Tin
now I added the itwo lines
Did you know why I have this error Got SIP response 489 "Bad Event" back from 192.168.0.15 ?
@kandy
sorry, I don't have a FBF, but other FBF users seem to have similar problems too. Maybe you can gather some useful information from this thread:
http://www.ip-phone-forum.de/forum/viewtopic.php?p=59374
It is in german however... Probably someone like "rollo" can help you better in this case.
Tin
Georg Martin Reuss
