FBF7170 - 29.04.49: Anrufbeantworter too simple - need IVR - is * the solution?
treanus
11 Sep 2007
sorry my German is not sufficient enough to write understandable questions. If anyone wants to answer in German, that is OK, since I understand 90% of it...
I'm very happy with my FBF so far, connecting to adsl, having 3 incomming/outgoing MSN isdn numbers (FON 1 to 3), and one "internetrufnummer"...
I've also tried to use the new inbuilt "anrufbeatworter" with success.
I NOW WANT TO GO ONE STEP FURTHER:
I want the anrufbeantworter to pick up the phone on one isdn MSN number, than play an "ansage" and than perform a "rufumleitung" to an external number, either using the ougoing isdn line, or using the sip connection.
QUESTIONS:
1/ Do I need asterisk to do this? Or, can the current default "anrufbeatworter" be hacked to do this?
2/ If I need asterisk, how to proceed? I've been reading most of the forum last couple of days, struggled a bit to get * installed, since the missing libresolv.so.0 library, but this can be worked around. I guess I need to edit /var/tmp/asterisk/extensions.conf, /var/tmp/asterisk/sip.conf, and make my own voicemail.conf? But I have to admit I'm a bit lost here... how to proceed?
Thanks for any advice...
Stefan.
@treanus
1) Once the FBF has control of the incoming call ( e.g. responding with a message ), I doubt that there will be an easy and comfortable way to get control back and forward the phone to another number.
Asterisk would for sure be a good option to do this at a fairly reasonable effort.
2) If you decide to go the asterisk route, then I suggest that you slightly adapt the voicemail set-up example that is provided in the default extensions.conf file, rather than using the app_voicemail.so module!
Reason being: What you are looking for appears to be more like an IVR functionality but a "vanilla" Voicemail implementation.
Regards
dynamic
Protonator
