Fehlermeldung 404 Not found bei Xlite,Sipgate und Asterisk
alexshh
19 Apr 2005
Hallo ,
eingehend funktioniert der Anruf . Abgehend bekomme ich folgende Fehlermeldung im Asterisk :
12 headers, 8 lines
Using latest request as basis request
Sending to 195.124.138.122 : 5060 (non-NAT)
Found user '8512415'
Found RTP audio format 8
Peer audio RTP is at port 195.124.138.122:8000
Found description format pcma
Capabilities: us - 0x4e (gsm|ulaw|alaw|slin), peer - audio=0x8 (alaw)/video=0x0 (nothing), combined - 0x8 (alaw)
Non-codec capabilities: us - 0x1 (g723), peer - 0x0 (nothing), combined - 0x0 (nothing)
Looking for 0017620827025 in 8512415
Reliably Transmitting (no NAT):
SIP/2.0 404 Not Found
Via: SIP/2.0/UDP 195.124.138.122:5060;branch=z9hG4bK86A1D3E160C349AE9CF242580CED760C
From: 8512415 <sip:[email protected]>;tag=1073948574
To: <sip:[email protected]>;tag=as6244029b
Call-ID: [email protected]
CSeq: 51293 INVITE
User-Agent: Asterisk PBX
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER
Contact: <sip:[email protected]>
Content-Length: 0
to 195.124.138.122:5060
hier meine sip und die extensions : Wer hat einen Tip für mich ?
[globals]
Petra => 8512415
Diana => 7773052
[default]
exten => 8512415,1,Dial(SIP/${Petra},60)
exten => 8512415,2,Background(day)
exten => 8512415,3,Hangup()
[8512415]
;exten => _0.,1,SetCallerID,8512415
;exten => _0.,2,SetCIDName(${Petra})
exten => _0.,3,Dial(SIP/${EXTEN:1}@sipgate.de,60)
exten => _0.,4,Hangup
hier noch die Sip :
[general]
register => 8512415:[email protected]/8512415
nat = yes
localnet = 195.124.138.0/255.255.255.0
port = 5060
bindaddr = 0.0.0.0
disallow = all
; maxexpirey=3600
; defaultexpirey=120
allow = gsm
allow = ulaw
allow = alaw
;allow=729
allow=slinear
qualify = yes
srvlookup = yes
insecure = very
; host = 195.124.138.131
; tos = 0x04
canreinvite = no
language = de
context = default
dtmfmode = info
[8512415]
port = 5060
auth = md5
type = friend
secret = XXXXXX
insecure = very
;fromdomain=sipgate.de
host = dynamic
nat = no
username = 8512415
;fromuser = 8512415
reinvite = yes
context = 8512415
canreinvite = no
qualify = yes
dtmfmode = info
Zusätzlich habe ich noch eine Frage in vielen sip.conf steht der Eintrag host=sipgate.de mit diesem Eintrag kann sich Xlite nicht an * anmelden.
(Da eigentlich der Host doch die IP des Xlite PC?s ist , oder ????)
Danke für jede Hilfe
alexshh!
Ich habe folgendes gefunden was nicht stimmen kann:
Als localnet hast Du ein Routing-Net eingegeben. Das
kann zu Problemen führen. Der localnet-Eintrag ist
für nonrouting-IP's wie im RFC 1918 angegeben vorgesehen
und das sind:
10.0.0.0 - 10.255.255.255 (10/8 prefix)
172.16.0.0 - 172.31.255.255 (172.16/12 prefix)
192.168.0.0 - 192.168.255.255 (192.168/16 prefix)
weiterhin hast Du zwei Semikola zuviel:
[8512415]
Im Übrigen ist das wohl der Incoming-Context vom Sipgate.
Hier müsste ein Dial(SIP/${Petra},60) stehen, oder?
Wenn's dennoch nicht klappen will, einfach "from scratch"
neu anfagen.
britzelfix
Ausserdem ist im Wahlstring eine 0 zuviel.
wo kommt die denn her?
jo
Failed to a
das mit dem Routing Netz kann ich mal probieren.
Zu den Semikola , die hatte ich nur zum Test gesetzt sind aber wieder weg.
Der context [8512415] ist der outgoing context.
Vielleicht kann jemand nochmal einen kurzen Blick auf das Gesamtkunstwerk machen.
In der sip.conf stehen nur die beiden contexte
[general]
context=default
[8512415]
context=8512415
und in der extensions.conf
[default]
exten => eingehend (funktioniert)
[8512415]
exten => _0.,3,Dial(SIP${EXTEN:1}@sipgate.de,60,trg)
in der CLI zeigt er beim wählen :
Executing SetCallerID("SIP/8512415-2eb5","") in new stack
Executing SetCIDName("SIP/8512415-2eb5","")in new stack
Executing Dial("SIP/8512415-2eb5","SIP/[email protected]|60|trg) in new stack
Called [email protected]
Notice(3588):chan_sip.c:6848 handle_response :Failed to authenticate on INVITE to &acute;"asterisk" <sip:[email protected]>;tag=xxxxxxxxxx
Got SIP response 481 "Call Leg Does Not Exist" back von 217.10.79.9
XLITE SELBER ZEIGT AN DAS ES WÄHLT UND DAS ES BEI DER GEGENSTELLE LÄUTET WAS ES LEIDER NICHT MACHT
müßte der Eintrag nach ...INVITE to .....<sip:asterisk@EXTERNE IP
stehen und nicht die locale ?????
wer weiss was genau diese 481 Fehlermeldung bedeutet.
DANKE FÜR JEDEN TIP
Mal im Ernst, warum erwartest Du, das hier Deine Konfigurationsdateien auseinandergenommen werden?
Nimm einfach eines der vielen funktionierenden Beispiele hier aus dem Forum und trage Deine Zugangsdaten an den entsprechenden Stellen ein.
jo
--->manch mal ist weniger mehr
Danke eigentlich das Forum dem Austausch und der Hilfe dient.Sonst kannst du auch ein Posting auf www.ip-phone-forum.de, stellen das sich alle abtippen.
Bin über jede HILFE und TIPS weiterhin dankbar.
Postman212
