Firmware 2.0.11(GWa) verfügbar
  • Ersteller Ersteller bodhran
B
bodhran
Guest
Release Notes for 2.0.11(GWa) -- Sipura Phone Adapter
SPA-3000 -- 1 Port FXS, 1 Port FXO, 1 Ethernet Interface
Copyright (C) 2003-2004 Sipura Technology Inc.
* * * * * * * * * * IMPORTANT * * * * * * * * * * * * * * * *  *
* Use of Proprietary Information and Copyright Notice:         *
* This release note document contains proprietary information  *
* that is to be used only by Sipura Technology customers.      *
* Any unauthorized disclosure, copying, distribution, or use   *
* of this information is prohibited. This restriction includes *
* ALL Internet based discussion forums, e.g. DSLreports.       *
Bug Fixes
-- since 2.0.10(GWf) --
01. BUG ID=221
   SPA does not bypass stun and natmapping when ringing through Line 1
   from the PSTN
02. BUGID=00225
    Removed clicking noise in G729 encoder and
    static noise associated with G726r24 an G726r40 encoder
New Features and Enhancements
01. Added <RTP Log Intvl> Line 1/PSTN Line option to control how often to log
    RTP stats for each active call. Units in seconds. 0 means do not log.
    (debug level 1). Formats are:
    [<line-id>:]Tx:dst=,ssrc=,pt=,p=,o=
    [<line-id>:]Rx:src=,ssrc=,id>,pt=,p=,o=,L=,j=,l=
    Note: line-id = 0/1 for Line 1/PSTN Line
02. Log Regsiter OK and failed events (debug level 3)
    Format are:
    [<line-id>]RegOK. NextReg in <(sec)>
    [<line-id>]RegFail. Retry in
    Note: retry-delay = 0 => no more retry (until reboot)
03. Support called number distinctive ringing for FXS port.
    The called number is extracted from the To header user-id field.
    To configure a ring for a special called number, enter
    @<called-number> (such as @14089991234) in
    parameter (under User 1 tab on spa config web page).
04. Treat it as anonymous call if From header user-id or display name
    is "Anonymous" (case-insensitive, quotes ignored). Before only
    the display name is checked.
kukus
