- Mitglied seit
- 13 Apr 2004
- Beiträge
- 93
- Punkte für Reaktionen
- 0
- Punkte
- 0
Unter Hellofone gibts seit heute die Firmware 1.0.5.0 zum download.
Folgende Release-Notes sind dabei:
Na dann, bin gespannt auf die Erfahrungsberichte! Mein 486er bekommt sie auch gleich !
http://www.grandstream.com/BETATEST/ ist zZt noch leer
Release 1.0.5.0 6/1/2004
¡¤ Fix the PPPoE related issue
1. nak MRU bug introduced in 1.0.4.81
2. Israel findings of no PAP if nak our magic of 0 after ACKSENT
3. add slow start PPP LCP to yield to server
Release 1.0.4.81 5/27/2004
¡¤ enhanced PPPoE to handle both 1492 and 1500 MTU in a more tolerant
fashion (if remote side insists on 1500, we will be agreeable; for
outbound TCP traffic, we will use 1492 in TCP negotiation)
Release 1.0.4.79 5/24/2004
¡¤ Fix the parameter initialization issue that blocks call
waiting (bug introduced recently)
¡¤ When loading config parameters from Flash at reboot, use
default setting if a certain parameter is out of range
¡¤ Fix the issue where STUN IP:port change detection packet
is not sent periodically
Release 1.0.4.75 5/17/2004
¡¤ Fix the issue related to subsequent REGISTER upon receiving 302 response
¡¤ Improved 486 performance
Release 1.0.4.74 5/15/2004
¡¤ fix the issue where ACK with SDP format is incorrect (the separator
line between SIP and SDP is overwritten by the SDP length)
¡¤ Add support for pressing ** to remotely access the IVR menu (HandyTone)
¡¤ Support automated switching to PCM upon detection of FAX tone (this is
especially helpful when the device is configured using other codecs
different from PCM).
¡¤ Fix the bugs related to call forwarding, do not disturb, etc. Please
note that under IP-to-IP mode, you need to first enter the IP calling
mode and then press *72 (or *90 or *92) to activate the call forwarding.
HTML: 1.0.0.33 5/14/2004
¡¤ Removed Voice Mail UserID for HandyTone
¡¤ Removed Dial Plan Length matching option
Release 1.0.4.73 5/14/2004
¡¤ fix the issue related to 302 response to REGISTER (we do not retry)
¡¤ use different From tag in subsequent requests upon receiving 401/407
¡¤ allow potentially non-80 port to be used for HTTP server
¡¤ fixed the timer issue that is causing unanswered call to be terminated
within 6 seconds
¡¤ removed the dial plan length matching function
Fixes from previous unstable release 1.0.4.72 (for reference here):
¡¤ Add support for Do-not-disturb, Call Forward (Unconditional, Busy and
Delayed)
and Diversion header:
Do not disturb = *70
Unconditional Call Forward = *72
--Cancel UCF = *73
Busy Call Forward = *90
--Cancel BCF = *91
Delayed Call Forward = *92
--Cancel DCF = *93
¡¤ Fix the scrambled ringback tone issue when the callee sends multiple 180
within a short period of time.
¡¤ DHCP client-server renewal looping fix
¡¤ start pppoe first if pppoe account is given, fallback to DHCP if attempt
trial fails.
¡¤ Enhanced DHCP client so that it will automatically start DHCP discovery
after
sending repeated DHCP requests without getting any responses
- fix the problem of direct IP calling
- bootload.bin: allow downloading up to 3 blocks big ringx.bin file
- support G722 wideband ring tone
- Attached G722, G711, G726 music ring tone for comparison. Obviously G722 is superior to G711
- Attached female ring tone with English callid
Release 1.0.4.71 5/10/2004
¡¤ Fix the http header issue
¡¤ 486 portmap mac index sync up with dhcp server client table.
¡¤ 486 DHCP server offers to clients uses a wrong lease time (already
available in previous release. This is just a code re-synch)
¡¤ fix the typo in bootloader (still 1.0.0.17)
¡¤ further fine tuning of G168 parameters to balance between performance
and resource use
Release 1.0.4.69 5/7/2004
¡¤ Add port change detection in IP address change checking using STUN
¡¤ Fix the typo of ¡°Adelaide¡±
¡¤ Fix the issue where we send wrong INVITE upon receiving 302 to a
REGISTER request
Release 1.0.4.68 5/7/2004
¡¤ Fix the issue related to PPPoE/CHAP (AOL)
¡¤ Used new and better VP.BIN (professional female voice)
Release 1.0.4.67 5/6/2004
¡¤ Fix the LAN-WAN IP call no audio issue accidentally introduced recently
¡¤ Fix the ARP for own IP issue
¡¤ Fix the codec negotiation issue remaining from previous release.
¡¤ Add code to better handle packet loss situation under iLBC
¡¤ Fix the DMZ and port forwarding bugs (HT486 only)
¡¤ Fixed the issue related to IP calls between WAN and LAN when HT486 is
under router and DSL modem (HT486 only)
Release 1.0.4.66 5/4/2004
¡¤ Fix the issue where if no DNS SRV is available even if it is so
configured, we will try DNS A record in a round robin fashion.
¡¤ Display WAN IP for 486
¡¤ Add support for port forwarding (486)
¡¤ improved ftp performance
¡¤ add support for pptp VPN pass-through
¡¤ PPP pap/chap account name and password memory free up.
¡¤ Enhance the codec negotiation to allow enforcing of certain
configured codecs to be used (instead of picking the first
supported codec from SDP list)
¡¤ Support configuration of music ringtone from keypad (BudgeTone)
Release 1.0.4.65 4/28/2004
¡¤ Fix the bug related to DNS SRV IP transaction ID
¡¤ Improved echo canceller
¡¤ Play silence prompt if there is no valid and qualified VP.BIN file
(HandyTone)
Release 1.0.4.64 4/27/2004
¡¤ Add support for PPPoE CHAP authentication method
¡¤ Fix the missing ¡°<¡± issue in handling certain contact field. The actual
case is that we were including extra ¡°>¡± and other fields that are not
supposed to be included in contact URI. This fix solves the problem of
mis-format of ACK to 302 message and subsequent INVITE request
¡¤ Added support for scenarios where the IP addresses of the servers are
not in the SRV response.
¡¤ Fix the bug related to DMZ for HandyTone 486
Release 1.0.4.63 4/25/2004
¡¤ Remove the code for handling date display format parameter update
¡¤ Ensure the dhcp IP lease time is non-zero when loading from Flash;
otherwise, use the default value
¡¤ Support for DNS SRV and server fail-over
¡¤ Add support for up to 3 custom downloadable music ring tones that can
also be used when a certain incoming caller ID is matched (BudgeTone only)
¡¤ Adjusted UI to reflect the new 3 ring tone settings
HTML 1.0.0.30 4/25/2004
¡¤ Add support for DNS SRV
¡¤ Add support for custom ring tones (BudgeTone only)
BOOTLOADER.BIN 1.0.0.16
Herein the release package, are 3 ringtone files (ring1.bin, ring2.bin,
ring3.bin) which
basically have the same content. I have also included 1 slightly different ringtone files with different names (ring1_0s.bin) for your testing and just remember to change their name to ringx.bin in order to download them onto the phone. For production release in the next few days, we will include 3 different (more interesting) music files as our standard offering.
Release 1.0.4.61 4/22/2004
This release fixes the crashing bug of previous version and some additional
enhancements:
HTML 1.0.0.29 4/23/2004
¡¤ Remove auto-answer and date-display-format options for HandyTone 286/486
¡¤ Use 192.168.2.1 as the default base IP for HandyTone 486 LAN port
Release 1.0.4.62 4/23/2004
¡¤ fix the bug that an unanswered 3rd incoming call during current active call
mode will cause crash if the call is cancelled after the current active call
ends. Also with the fix, once the phone is hung up, a ringing tone will be
generated if the 3rd incoming call is still pending.
¡¤ Add support for DMZ for HT486
¡¤ Remove auto-answer and date display format configuration option for HandyTone
because these features are meaningless for HandyTone platform
¡¤ Fix the RTCP BYE issue related to conferencing scenario
¡¤ Fix the static IP issue for 486
¡¤ New LCD display logics for HT (286/486) only:
RED LED always indicates WAN port status:
No IP from WAN port: flash @0.5Hz
FXS port fails Reg: flash @0.5Hz
ORANGE LED always indicates FXO line status and only for HT-486A
FXO port fails Reg: flash @0.5Hz
NO FXO line connection: constant YELLOW
GREEN LED always for normal working status:
MWI GREEN: flash @0.5Hz
RINGING: flash @10Hz
RINGING INTERVAL: flash @1Hz
OFFHOOK: steady ON
¡¤ reduce the audio volume on analog phone to -6dB from 3.5db in release
1.0.4.60.
¡¤ improved the code to further reduce the chance of echo
Release 1.0.4.60 4/20/2004
¡¤ modified HT LED display logics:
- RED LED toggles at 0.5Hz if voice mail is available
- GREEN LED toggles at 10Hz during 2s ringing and at 1Hz at 4s not ringing intervals
- GREEN is steady ON whenever the handset goes off hook
Release 1.0.4.59 4/18/2004
¡¤ Fix the G.728 codec issue and ensure that only voice frames per TX
in multiples of 4 are allowed for G.728
¡¤ Fix the issue related to using # as the dial key (it causes busy tone
at caller side sometime after the call is initiated)
¡¤ Fix the bug that will cause phone to crash if a 3rd incoming call
is answered after the current call channel ends
¡¤ Enable the ¡°keypad update lock¡± option for HandyTone (it was only
enabled for BudgeTone previously)
Release 1.0.4.58 4/16/2004
¡¤ Fix the ilbc mode negotiation issue
¡¤ Fix the issue that no dial plan length matching is performed under IP calling mode
¡¤ Fix the problem that if no DHCP server is available, we get stuck in PPPoE discovery
state. The fix will only allow entering PPPoE discovery state if a PPPoE account is
configured. Otherwise, DHCP discovery will be done indefinitely until a DHCP server is
found
¡¤ Fix the G722 payload length and sampling rate information in SDP message
¡¤ Update run-time RTP configuration parameters upon each new call so that
any Flash
content changes (e.g., codec, voice_frames_per_TX, etc) will be immediately reflected
without requiring reboot
¡¤ Removed the static debug info from PPPoE code
¡¤ Merged code fixes for 486 related issues (LAN client ping WAN subnet IP and the ICMP
unreachable is dropped if unreachable is not triggered by a ICMP ping from LAN client)
Release notes:
HTML 1.0.0.27 4/13/2004
¡¤ Add ¡°date display format¡± option
¡¤ Add ¡°No key entry timeout¡± option
¡¤ Add ¡°Use NAT IP¡± option
Release 1.0.4.57 4/13/2004
¡¤ Fix the issue related to via header parsing when multiple Via headers are
on the
same line and separated by comma (previous fix didn¡¯t fully solve the
problem)
¡¤ Fix the codec negotiation issue related to iLBC
¡¤ Add support for different date display format
¡¤ Add "no key entry timeout" option for dialing
¡¤ Add support for static NAT IP
¡¤ Muted in-band audio for both BT and HT
¡¤ Updated key menu for BT to reflect new codecs
Release 1.0.4.57 4/11/2004
1. iLBC codec (both sides must use payload of 98 temporarily--will fix this
shortly)
2. G722 codec (BudgeTone only)
3. display of VOC.BIN version
4. support for dial plan length matching to trigger immediate sending of INVITE without
pressing "Send" key
