forgot password
braza
1 Feb 2008
Hello
I forgot my password to my fritzbox and forgot what is my voip Anbieter, how can i get my password back without reset... Because i need information about my Anbieter.
In advance thanks !
Use the findfunction in this forum and look for Fritzrepass; this piece of software enables you to read the passwords out
Thank you bud i forgot password to fritzbox and with this tool FritzRePass i need enter first password
and is it possible to get the password? with other program or somthing ? i hope some body can help me because i really need it :(
No, it is not possible.
You would not want a password protection on your box that can be circumvented with some program or something.
If the password was useless, why would you bother setting one?
that sounds as if everywhere is carnival at this time
jwe87
