Freenet-ATA-Nutzer mit .45er: Wie sieht eure voip.cfg aus?
ike
Aktives Mitglied
18 Apr 2005
Hi!
In der .45er Firmware, die nur mit den Freenet-ATA ausgeliefert wurde, schien ja iLBC zu klappen. Kann vielleicht mal jemand mit so einer Box seine voip.cfg posten? Ich gebe ja die Hoffnung nicht auf, dass man die neue Firmware doch noch soweit bringen kann, dass sie iLBC kann ...
Tschau!
Michael
* /var/flash/voip.cfg
* Thu Jun 16 23:13:01 2005
voipcfg {
dnsport = 7077;
rtpport_start = 7078;
ua1 {
enabled = yes;
username = "xxx";
authname = "";
passwd = "xxx";
registrar = "xxx";
ttl = 30m;
sipping_enabled = yes;
sipping_interval = 280s;
name = "xxx";
authenticatemode = authenticate_mode_none;
infodtmfnotsupported = no;
register_failwaitmax = 30m;
stunserver = "xxx";
stunserverport = 3478;
is_nat_aware = no;
clirtype = clir_displayname;
only_one_dialog = no;
presence_supported = no;
ua2 {
enabled = yes;
username = "xxx";
authname = "";
passwd = "xxx";
registrar = "xxxe";
ttl = 30m;
name = "xxx";
stunserver = "xxx";
is_nat_aware = no;
ua3 {
enabled = yes;
username = "xxx";
authname = "";
passwd = "xxx";
registrar = "xxx";
ttl = 30m;
name = "xxx";
stunserver = "xxx";
is_nat_aware = no;
ua4 {
enabled = yes;
username = "xxx";
authname = "";
passwd = "xxx";
registrar = "xxx";
ttl = 30m;
name = "xxx";
stunserver = "xxx";
is_nat_aware = no;
ua5 {
enabled = yes;
username = "xxx";
authname = "";
passwd = "xxx";
registrar = "xxx";
ttl = 30m;
name = "xxx";
stunserver = "xxx";
is_nat_aware = no;
use_audiocodecs = yes;
audiocodecs = "iLBC", "G729", "G726-24", "G726-32", "G726-40",
"PCMA", "PCMU";
verbose = no;
sip_prio = 0;
rtp_prio = 0;
dyn_codecs = yes;
send_ringtone = no;
rtpstream {
voice_activity_detection {
enabled = no;
vad_threshold = 10000;
generate_noise {
on_packetloss = no;
on_capi_underrun = yes;
jitter {
auto_on = yes;
in_ms = 50;
in_packets = 0;
tx_packetsize_in_ms = 0;
// EOF
Bitte schön :) aber ich glaub nicht das dir die weiter hilft :(
Ich hab ein ähnliches Problem wie du ich will den G729 zurück :evil:
Aber iLBC geht bei Dir? Ich hatte gehofft, dass die vielleicht "iLBC" anders schreiben :-(
Ja iLBC geht :) aber G729 dafür nicht mehr :(
[Edit]
Und ich hab so sen Verdacht das es etwas mit diesen Dateien
./lib/libmscodex.so
./lib/libmscodex.so.2
./lib/libmscodex.so.2.0.0
zu tun hat...
Leider bekomme ich es einfach nicht hin das firmware update image ganz zu öffnen und mir alle Dateien mal anzugucken :(
kimtremblay643
