Fritz and Flash
kandy
19 Feb 2005
I connected the fritz!box Fon Ata to my asterisk.
I have the following problem, if I use the key flash in order to put a people in hold the connection drop.
I need to enable the # in order to use the hold.
There is some setting in the fritz in order to use the flash key?
I forgot to say that this test was done in US. And I discovered that the flash Button (R) has a longer time if it is compared with the european.
Hi Kandy,
I just remember: http://www.ip-phone-forum.de/forum/viewtopic.php?p=78412#78412
The thread said that the settings are permanent.
#611*1*#91** turn on longer flash time for phone 1
#612*1*#91** fone 2
Revert the setting:
#611*0*#91** fon1
#612*0*#91** fon2
I am not sure if it works. But it's worth a try.
Best regards,
Haveaniceday
Appy
