Fritz!Box FON able to route calls through LAN?
kandy
19 Feb 2005
Is it possible to use the fritz!Box Fon routing the calls through the LAN?
I do not want use the modem.
Edit from Christoph:
I changed the topic to a more understandable one.
you can use an fritz!box fon ATA ....it is an fon box without modem
Yes, but one of my friends has a fritz!box Fon and he want to uses it inside a network that already has a router.
I tried to set the route but nothing, the router is well configured since with xlite is able to use the voip.
In order to change the setting of the fritz I need to load the mod firmware and I do not want to do that.
But, it is means that without any mod it is impossible to route the voip on the lan?
@ kandy:
Next time please specify your problem in the topic instead just mentioning the FBF's product name.
Keine Mitglieder online.
chingola
