FRITZ!Box Fon WLAN (Annex B) I have serious problem
Dieses Thema im Forum "FRITZ!Box tot? Recover, Firmware Up-/ Downgrade" wurde erstellt von nikmag, 8 Feb. 2006.
  1. nikmag
    nikmag Neuer User
    8 Feb. 2006
    2
    Zustimmungen:
    Punkte für Erfolge:
    Sorry for my english but I have a big problem. I deleted mtd 3 and 4. I do not have any kind of communication betwwen my pc and Fritz!. It is not possible to apply ftp 192.168.178.1. I tried to apply recover 03.91 many times but the problem is that it can not find 192.168.178.3. and continues searching. Please Help.
    Thanks in advance:( :( :(
  2. olistudent
    olistudent IPPF-Urgestein
    19 Okt. 2004
    14,765
    Zustimmungen:
    5
    Punkte für Erfolge:
    38
    Beruf:
    Softwareentwickler
    Kaiserslautern
    Hi.
    You know that recover must be run within 5 seconds after the start?
    Your PC must have a fixed IP in the same subnet. If you own a switch or a hub it is better to connect the FBox to it then directly to the PC. You have to connect the LAN-Port with a 1:1 cable...
    Greets, Oliver
  3. nikmag
    nikmag Neuer User
    8 Feb. 2006
    2
    Zustimmungen:
    Punkte für Erfolge:
    Thanks Olistundent. I do run recover within 5 seconds after the start, I
    have a fixed IP (192.168.178.2) in the same subnet. I do not own a switch or a hub.I connect the LAN-Port with a 1:1 cable. Fritz! lost 192.168.178.1 and if I do not put a fixed ip to my PC Fritz gives me an IP like 169.254.3.196 and a mask 255.255.0.0.
