[Frage] FRITZ!VPN and roadwarrior, how i change config?
alfonzo
6 Feb 2011
I have VPN FRITZ!VPN <-> FRITZ!Box VPN connected successfully.
I need connect FRITZ!VPN <-> FRITZ!Box <-> public Internet. I ask HOW?
i need (after FRITZ!VPN start), automaticaly change default route like
Microsoft VPN build in to 0.0.0.0 go via my fritzbox...
2.Second question is, if Microsoft VPN (Windows7) is usable to connect FRITZ!Box VPN or only FRITZ!VPN or Shrew solution,?
Many thx for response.
nobody known?
Microsoft VPN will not Work with the Box, you need Fritz! VPN-Connection or Shrew or OpenVPN.
When you generate the Config-Files, you will be able to add/change the default route.
BtW, do you use a german or international Box?
i use intl box
i see, latest german Einrichtung allow make this config:
1.03.00
* Neue Funktion: "Alle Daten über den VPN-Tunnel senden". Erhöht beispielsweise
die Sicherheit beim Surfen in öffentlichen Hotspots.
Okay, this solve my request, thx.
Only problem is with tracert command (Windows), this not work correctly... :-(
maybe need any change in config files? Any idea?
great man
many thx to you...
hello,
and is possible EXCLUDE any routes from traffic? For example, i need route 10.x.x.x locally and all others to VPN, is possible change vpn.cfg file for this?
And second request (diferent scenario):
FBF router with WAN on LAN1
i need this: all traffic from FBF LAN subnet -> VPN (second fritz), is possible?
thx
tacohell
