[Gelöst] Fritzbox 7340: flashing whatever current trunk image bricks the router
Melchior
14 Okt 2011
When I try to flash the Fritzbox 7340 with, for example, a minimal current trunk image, the router dies.
Only with an official image I can revive it with the standard recovery tool. Also, I needed to use rukerneltool after even the standard recovery tool failed to deliver.
Before, I could flash whatever image, but not anymore...
Help is much appreciated.
Solved: In my case, the new 7941 revision made it possible again to use Freetz on the Fritzbox 7340.
There was a typo in an earlier revisions turning Fritzbox into bricks.
Very similar to this.
Greets,
JD.
Indeed, and in this thread is yet another referral to a thread about similar problems with the 7390.
A lot of reading.... sigh...
I have the same problem with a fresh trunk on 7270v2
compiling a basic international firmware for my device generate an image that brick the fritzbox.
Serial output:
executing /etc/init.d/S10-html
executing /etc/init.d/S10-vm
executing /etc/init.d/S11-config_def
executing /etc/init.d/S11-piglet
[avm_debug]standard kernel-messages
[piglet]use gpio-settings for 139
patch_dectfw: patch_adress: 7a82 max_len: 22 with Version 2 Len: 16
patch_dectfw: c0ab8000, datalen = 34417,
dect_loader(first): unknown c0 in state dect_wait_for_ack received
dect_loader(first): unknown fe in state dect_wait_for_ack received
dect_loader(first): unknown 80 in state dect_wait_for_ack received
dect_loader(first): unknown f7 in state dect_wait_for_ack received
dect_loader(first): unknown f8 in state dect_wait_for_ack received
dect_loader(first): unknown 3e in state dect_wait_for_ack received
dect_loader(first): unknown 7f in state dect_wait_for_ack received
dect_loader(first): crc failure (01ce) 2 47
dect_file_process: error on upload firstloader '/lib/modules/dectfw_firstlevel.hex'
Call Trace:
[<9441516c>] dump_stack+0x8/0x34
[<944151cc>] panic+0x34/0x19c
[<c0a5a2d4>] init_module+0x2d4/0x2ec [Piglet_noemif]
[<9410006c>] do_one_initcall+0x6c/0x1fc
Kernel panic - not syncing:
[piglet]panic: Can't load dect-fw!
WARNING: use tffs in panic mode (minor 96)
Rebooting in 3 seconds..
The svn server is up again, serving you revision 7941. Maybe this one solves it?
Serial output:
Call Trace:
Rebooting in 3 seconds..[/QUOTE]
Now it boot but dect doesn't works and I get other errors and fritzbox is unavailable in my network:
[code]...
AVMMULTID: /etc/init.d/rc.multid: /etc/init.d/modlibrc: line 412: syntax error: unterminated quoted string
/etc/init.d/rc.S: /etc/init.d/S76-media: line 6: /etc/init.d/rc.media: not found
executing /etc/init.d/S99-zzz-rcmod
/etc/init.d/rc.S: /etc/init.d/modlibrc: line 412: syntax error: unterminated quoted string
root@fritz:/var/mod/root# ifconfig
ath0      Link encap:Ethernet  HWaddr ******************
          UP BROADCAST RUNNING MULTICAST  MTU:2290  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
cpmac0    Link encap:Ethernet  HWaddr ******************
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:389 errors:0 dropped:0 overruns:0 frame:0
          TX packets:389 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:65195 (63.6 KiB)  TX bytes:65195 (63.6 KiB)
wifi0     Link encap:Ethernet  HWaddr ******************
          RX packets:44 errors:0 dropped:0 overruns:0 frame:2
          TX packets:36 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:7503 (7.3 KiB)  TX bytes:3743 (3.6 KiB)
          Interrupt:80 Memory:c2220000-c2230000
Did you use the new revision 7941 or up?
Did you select the 'remove chronyd' option?
Can we close here? Or do you still have problems?
Regards
Oliver
Closed.
Regards
Oliver
akuankka
