- Mitglied seit
- 1 Nov 2007
- Beiträge
- 1
- Punkte für Reaktionen
- 0
- Punkte
- 0
Hello,
Sorry, but I don't speak German. However, I hope there is a kind soul out there who can tell me if it's possible to upgrade the firmware in a Fritzbox FON WLAN Annex A so it supports Annex M ??
The reason for my question is that my DSL-line was upgraded from an Annex A line to an Annex M line. My DSL speed is supposed to be 8/2, but I only get 8/1, because the Fritzbox only supports Annex A which limits the upload speed to 1mbit.
So either I have to upgrade the firmware (and AVM does not offer a firmware upgrade) _or_ I have to buy a new box similar to FritzBox FON WLAN but with Annex M support.
So my questions are:
1) Is there firmware available for the FritzBox FON WLAN Annex A which will upgrade it so it also supports Annex M ?
2) If the answer to question 1 is "no", then I would like a recommendation for another product that is just as good as the Fritzbox. The product I am looking for must have:
* WLAN
* Minimum 1 LAN port
* Stable VOIP
* DSL modem
* Support for Annex M (and Annex A if possible)
Thank you.
* WLAN
* Stable VOIP
* DSL modem
Thank you.
