OK, so I didn't sign up here first and didn't know about the downgrade.tar....
Did the upgrade to 29.04.15 this morning and found that the web page with the DSL DSLAM and ATM specs was no longer available. Wanted to downgrade to the 29.04.03-3306 and the box told me that was a no-no... and would keep the current version. Searched the web, found this, registered and downloaded downgrade.tar / downgrade2.tar and went throught the steps manually via telnet. Uploaded the previous version and got the same error msg.
Now the real problem is that I can't access the web pages any more. After a cold start I have just a few seconds where I can sign in and by the time I have accessed the upload page the web pages no longer appear.
What I have found out via telnet is that the following:
Console Ausgaben auf dieses Terminal umgelenkt
# ls -l /usr/www/all
drwxrwxr-x 1 root root 62 Aug 2 2006 cgi-bin
drwxrwxr-x 1 root root 440 Aug 2 2006 html
lrwxrwxrwx 1 root root 17 Aug 2 2006 index.html -> ./html/index.html
# telefon: set initial telefon time from linux time to 15:29 15.08 2006!
drwxrwxrwx 1 root root 0 Aug 15 15:29 cgi-bin
lrwxrwxrwx 1 root root 17 Aug 15 15:29 html -> /usr/www/all/html
lrwxrwxrwx 1 root root 24 Aug 15 15:29 htmltsb -> /var/tmp/tsb/www/htmltsb
lrwxrwxrwx 1 root root 28 Aug 15 15:29 index.html -> /usr/www/all/html/index.html
lrwxrwxrwx 1 root root 40 Aug 15 15:29 tsb.htm -> /var/tmp/tsb/www/cgi-bin/tsb/_index.html
lrwxrwxrwx 1 root root 40 Aug 15 15:29 tsb.html -> /var/tmp/tsb/www/cgi-bin/tsb/_index.html
# cd /usr/www/all/
# more index.html
more: index.html: Too many levels of symbolic links
# Aug 15 15:27:07 webcm[960]: MakeLanguagePath html=../html tail=login.html -> ../html/login.html
It looks like some process is re-right'ing the ../www/.. files and creating an infinite loop by linking the files to their own directories. Then if you try to access the login page via the web you get the last msg. Logical.
So what can I do to recover this? Can I unlink the directories?
In the end I want to get back to the 29.04.03.. FW revision because I want to see when DTAG upgrades the ATM interfaces so that 1&1 can provide me with the service I am paying for, i.e. 6 MBit instead of the 3MBit that I now have.
Why did AVM take that out and how can it be added to the current FW release?
Hope someone has a working fix for this screw-up.
Regards,
Reg
# cd /usr/www/all/
# more index.html
Regards,
Reg
