FritzPhone 7150 updatet DynDNS nicht
Mediaman2000
24 Feb 2007
Abend, ich hab ja die ziemlich neue Fritz Fon 7150 Kiste hier liegen. Läuft ganz gut das Teil, ich poste euch als erstes mal die Konsolenausgabe:
Mar 13 23:40:29 multid[1739]: stopped.
Mar 13 23:40:36 multid[1769]: startup (Jul 6 2006 15:01:35)
Mar 13 23:40:36 multid[1769]: csock: using poll
Mar 13 23:40:36 multid[1769]: Couldn't load shared library libavmssl.so -File not found - Bad file descriptor (9)
Mar 13 23:40:36 multid[1771]: if_setup: usbrndis: SIOCSIFADDR failed - No such device (19)
Mar 13 23:40:36 multid[1771]: br_add_if: get index for usbrndis failed - No such device (19)
Mar 13 23:40:36 multid[1771]: if_allmulti: usbrndis: SIOCGIFFLAGS failed - No such device (19)
Mar 13 23:40:36 multid[1771]: if_setup: eth1: SIOCSIFADDR failed - No such device (19)
Mar 13 23:40:36 multid[1771]: br_add_if: get index for eth1 failed - No such device (19)
Mar 13 23:40:36 multid[1771]: if_allmulti: eth1: SIOCGIFFLAGS failed - No such device (19)
Mar 13 23:40:36 multid[1771]: static routes: 0 deleted (0 failed), 0 added (0 failed)
Mar 13 23:40:36 multid[1771]: mrouter: using IGMPv3 for upstream interface
Mar 13 23:40:36 multid[1771]: mrouter: using IGMPv3 for other interfaces
Mar 13 23:40:36 multid[1771]: DHCPD on lan
Mar 13 23:40:36 multid[1771]: DHCPD on lan:0 skipped, is virtual interface
Mar 13 23:40:36 multid[1771]: DDNS: mediahome.ath.cx
Mar 13 23:40:36 multid[1771]: DDNS: 1 accounts
Mar 13 23:40:36 multid[1771]: ONLINE: script /bin/onlinechanged not found.
Mar 13 23:40:36 multid[1771]: verbose: DISABLED
Mar 13 23:40:36 multid[1771]: eth0: SIOCGIFADDR - Cannot assign requested address (126)
Mar 13 23:40:36 multid[1771]: tiwlan0: SIOCGIFADDR - Cannot assign requested address (126)
Mar 13 23:40:36 multid[1771]: wdsup0: SIOCGIFADDR - Cannot assign requested address (126)
Mar 13 23:40:36 multid[1771]: wdsdw0: SIOCGIFADDR - Cannot assign requested address (126)
Mar 13 23:40:36 multid[1771]: wdsdw1: SIOCGIFADDR - Cannot assign requested address (126)
Mar 13 23:40:36 multid[1771]: wdsdw2: SIOCGIFADDR - Cannot assign requested address (126)
Mar 13 23:40:36 multid[1771]: wdsdw3: SIOCGIFADDR - Cannot assign requested address (126)
Mar 13 23:41:40 multid[1771]: DDNS: mediahome.ath.cx: verify failed, is 84.128.126.252, but should be 84.128.94.20
Also ich habe, wo in der ersten Zeile multid gestoppt wird via Webinterface die DynDNS Einstellungen vorgenommen (glaubt mir's die Angaben stimmen ;)). Ok soweit so gut - multid startet wieder wie man in den folgenden Zeilen sehen kann und bringt aber für mein Verständnis allerhand Fehlermeldungen. Besonders diese hier "ONLINE: script /bin/onlinechanged not found." oder die letzte Zeile "mediahome.ath.cx: verify failed, is 84.128.126.252, but should be 84.128.94.20" machen mich stutzig. Das die Adressaktualisierung nicht klappt bestätigt mir das Interface von dyndns.org und dass ich nicht auf meine Adresse von einem anderen DSL Anschluss aus zugreifen kann...
Ist da irgendwas in der Firmware faul (die gibts ja leider noch nicht mal zum neu laden auf der AVM Seite) oder ist das alles normal mit den ganzen Fehlermeldungen und der Haken liegt vielleicht woanders?
So nebenbei, gibts andere wege einmal am Tag durch andere Programme auf der Box das Update vorzunehmen?
Danke schonmal
Ok, mein Fehler den anderen Thread nicht bis zu Ende gelesen, aber vielleicht sind meine Ausgaben Hilfreich für den anderen Thread. Das Phänomen das DynDNS nicht klappt, hab ich auch auf anderen Routern von Kunden.... K ich finde mich im anderen Thread ein ;)
...und damit hier zu ;)
Lord#1
