Gebuehrenansage-Skript
zorg
17 Aug 2004
also bevor hier das rad neu erfunden wird...
schaut euch doch echt mal die listen von rates4linux an:
V:1.57 Int [01-Nov-2003 01:00:00]
# This version of country.dat originates from rates4linux:
# $Id: country-de.dat,v 1.46 2004/02/12 23:52:28 tobiasb Exp $
# The rates4linux homepage: http://www.sourceforge.net/projects/rates4linux/
# It bases on Rev. 1.39 of isdn4k-utils/isdnlog/country-de.dat
# in the CVS at http://www.isdn4linux.de.
# ISO 3166 Countrycodes ( ftp://sunsite.unc.edu/pub/Linux/apps/misc/
#       countrycodes.1.0.2.tar.gz
# Airportcodes: http://www.TravelDesk.com/airports.html
# Countries have a 2 letter ISO-Code
# Towns have a 3 letter airportcode or
#  a _XXXX code, where XXXX is a (uniq) abbrev of town
# all the codes have to be uppercase
# Country Mobilfunk : _ccMF
# Freephone : _ccFF
# Auskunft :  _ccAK
# Sonderrufnummern : _ccSO
# Partial source for national numbering plans (2002-08-23):
# http://www.itu.int/ITU-T/inr/nnp/index.html
# Offical German language country names (2003-07-23):
# http://www.auswaertiges-amt.de/www/de/infoservice/download/pdf/publikationen/staatennamen.pdf
# Note: The information in this file gets included in the destination database
# usually /usr/lib/isdn/dest.cdb.  As of August 2002 there is a limit of 1024
# bytes per entry value based on the size of buf in the function i4l_cdb_fetch
# in the file isdnlog/tools/cdb/i4l_cdb.c.  The value for _DOMF (N;C[,C][;R])
# would be longer if fully noted.
# Source (1998-05-19):
# http://www.itu.int/itudoc/itu-t/number/u/uzb/81566_ww2.doc
N:Usbekistan
E:Uzbekistan
C:+998                  # +7ABC till 1999
T:UZ
N:Usbekistan Mobilfunk
E:Uzbekistan cellphone
C:+9989                 # may be inaccurate
R:UZ
T:_UZMF
betateilchen
Grandstream-Guru
30 Jun 2004
ich würde mir im Gebührenansageskript eine Variante wünschen, die nach der Wahl der Rufnummer anhand eines vorhandenen Guthabens die verbleibenden Gesprächsminuten zur Zielrufnummer ansagt - und NICHT die Kosten :wink:
otaku42
Admin-Team
26 Mrz 2004
Das Problem dabei ist, dass die Ermittlung des aktuellen Guthabens alleine schon relativ lange dauert, jedenfalls bei Sipgate. Ich habe ein Skript, dass das Guthaben aus der Website zieht, und das hat gute 4-5 Sekunden Vorlauf. Es waere schoen, wenn die Sipanbieter endlich eine gemeinsame Schnittstelle fuer die (schnelle) Abfrage solcher Daten definieren koennten...
betateilchen
Grandstream-Guru
30 Jun 2004
schon klar - ich denke da auch mehr an den Einsatz auf einem eigenen Server mit Prepaid-Anwendung :wink:
cno
25 Okt 2004
Ich hätte gerne das Sipgate-Guthaben als Ansage auf eine Extension gelegt - hat das schon wer gelöst?
Hab bisher noch nix dazu gefunden.
TNX!
TinTin
Aktives Mitglied
6 Mai 2004
@otaku42
dann poste es doch unter "Vorbehalt" , vielleicht können wir es alle zusammen "release-fertig" machen *s* Würde mich nämlich auch interessieren.
Gruß,
Tin
rannseier
Aktives Mitglied
5 Mai 2004
Hat sich schon was mit der Gebührenansage getan?
MfG,
Karl
TinTin
Aktives Mitglied
6 Mai 2004
fabe schrieb:
also ich hätte ne db, mit vorwahlen, land und bezirken aus deutschland, Österreich, schweiz und usa. jeweils auch unterschieden nach Festnetz & Mobil (nicht usa)...
bestände daran intresse? (ist aus regtp daten der entsprechenden ländern entstanden...)
Hallo fabe,
ich hätte auch großes Interesse an diesen Datenbänken, um eingehende Rufe Orten zuzuordnen. Könntest Du sie mir auch bitte zukommen lassen? Ich habe mich schon wund gesucht nach sowas...
Vielen Dank,
Tin
3CX PBX - GRATIS
Linux / Win / Cloud
Torrehoradada
