Hi there.
I cant get it working:-( I think avm have make some changes that all old mod. not working ant more...
the command guote SETENV dosent work on the 7140 but ok on 7050??
Anyway I cant convert the 7050 A to B :-(
I got this error all time
Searching FRITZ!Box Fon WLAN 7050 at: 192.168.178.1
One system found! - Detecting the current version.
Version successfully detected!
Hardware: FRITZ!Box Fon WLAN 7050
Bootstrap: 1203
Firmware: 14.4.26
Flash area (mtd1)
Deleting flash area (mtd1)
Restoring flash area (mtd1)
Checking flash area (mtd1)
Could not check the partition mtd1! WinError -4
update, fixed! after downgrade...
//f
Bootstrap: 1203
Firmware: 14.4.26
Flash area (mtd1)
//f
