Gespräche brechen zusammen
iptelefonie
29 Mrz 2006
beim Raustelefonieren brechen die Gespräche sehr oft zusammen. Manchmal nach wenigen Minuten, manchmal aber auch erst nach einer halben Stunde.
Ich benutze Asterisk 1.2.23-BRIstuffed-0.3.0-PRE-1y-j und chan_capi Common ISDN API Driver (1.1.0).
Ich habe folgenden Aufbau:
ISDN-Telefone->ZAPHFC->Asterisk_1->IAX2->Asterisk_2->Capi/ISDN
Das ist der Auszug aus dem Logfile vom Asterisk_2 und die extension dazu:
[iax]
exten => _0.,1,SetCALLERPRES(prohib_not_screened)
exten => _0.,n,Dial(CAPI/contr1/${EXTEN})
May 19 16:12:32 VERBOSE[2016] logger.c:     -- Accepting AUTHENTICATED call from 192.168.0.25:
May 19 16:12:32 VERBOSE[13048] logger.c:     -- Executing SetCallerPres("IAX2/ast2-8", "prohib_not_screened") in new stack
May 19 16:12:32 VERBOSE[13048] logger.c:     -- Executing Dial("IAX2/ast2-8", "CAPI/contr1/089665522366") in new stack
May 19 16:12:32 VERBOSE[13048] logger.c:        > data = contr1/089665522366 format=8
May 19 16:12:32 VERBOSE[13048] logger.c:        > capi request controller = 1
May 19 16:12:32 VERBOSE[13048] logger.c:   == ISDN1#02: Call CAPI/ISDN1#02/089665522366-43a   (pres=0x20, ton=0x00)
May 19 16:12:32 VERBOSE[13048] logger.c:     -- Called contr1/089665522366
May 19 16:12:32 VERBOSE[2018] logger.c:     -- ISDN1#02: received CONNECT_CONF PLCI = 0x101
May 19 16:12:34 VERBOSE[2018] logger.c:     -- chan_capi queue frame: [ TYPE: Control (4) SUBCLASS: Unknown control '15' (15) ] [ISDN1#02]
May 19 16:12:34 VERBOSE[13048] logger.c:     -- CAPI/ISDN1#02/089665522366-43a is proceeding passing it to IAX2/ast2-8
May 19 16:12:35 VERBOSE[2018] logger.c:     -- ISDN1#02: PLCI=0x101 CCNR unique id=0x0002
May 19 16:12:35 NOTICE[2018] chan_capi_supplementary.c: No peerlink found to set CCBS/CCNR linkage ID.
May 19 16:12:35 VERBOSE[2018] logger.c:     -- ISDN1#02: PLCI=0x101 CCBS/CCNR new id=0x0002 handle=536936450
May 19 16:12:35 VERBOSE[2018] logger.c:     -- chan_capi queue frame: [ TYPE: Control (4) SUBCLASS: Unknown control '14' (14) ] [ISDN1#02]
May 19 16:12:35 VERBOSE[2018] logger.c:     -- chan_capi queue frame: [ TYPE: Control (4) SUBCLASS: Ringing (3) ] [ISDN1#02]
May 19 16:12:35 VERBOSE[13048] logger.c:     -- CAPI/ISDN1#02/089665522366-43a is making progress passing it to IAX2/ast2-8
May 19 16:12:35 VERBOSE[13048] logger.c:     -- CAPI/ISDN1#02/089665522366-43a is ringing
May 19 16:12:44 VERBOSE[2018] logger.c:     -- contr1: PLCI=0x1 CCBS/CCNR erase id=0x0002
May 19 16:12:44 VERBOSE[2018] logger.c:     -- capi: PLCI=0x1 CCBS/CCNR removed id=0x0002 state=1
May 19 16:12:44 VERBOSE[2018] logger.c:        > CAPI: Command=FACILITY_IND,0x8496: no interface for PLCI=0x1, MSGNUM=0x378f!
May 19 16:12:44 VERBOSE[2018] logger.c:        > CAPI: Command=INFO_IND,0x8492: no interface for PLCI=0x1, MSGNUM=0x3790!
May 19 16:12:44 VERBOSE[2018] logger.c:     -- chan_capi queue frame: [ TYPE: Control (4) SUBCLASS: Answer (4) ] [ISDN1#02]
May 19 16:12:44 VERBOSE[2018] logger.c:        > ISDN1#02: DTMF conf(PLCI=0x101)
May 19 16:12:44 VERBOSE[13048] logger.c:     -- CAPI/ISDN1#02/089665522366-43a answered IAX2/ast2-8
May 19 16:16:04 VERBOSE[2018] logger.c:        > ISDN1#02: DTMF conf(PLCI=0x101)
May 19 16:19:48 VERBOSE[13048] logger.c:     -- ISDN1#02: activehangingup (cause=16) for PLCI=0x101
May 19 16:19:48 VERBOSE[13048] logger.c:   == Spawn extension (iax, 089665522366, 2) exited non-zero on 'IAX2/ast2-8'
May 19 16:19:48 VERBOSE[13048] logger.c:     -- Hungup 'IAX2/ast2-8'
May 19 16:19:49 VERBOSE[2018] logger.c:   == ISDN1#02: Interface cleanup PLCI=0x101
Woran könnte das liegen?
Jetzt auch bei einem eingehenden Anruf:
May 27 09:38:37 VERBOSE[2018] logger.c: -- CONNECT_IND (PLCI=0x101,DID=889,CID=,CIP=0x4,CONTROLLER=0x1)
May 27 09:38:37 VERBOSE[2018] logger.c: == Started pbx on channel CAPI/ISDN1#02/889-559
May 27 09:38:37 VERBOSE[4729] logger.c: -- Executing Dial("CAPI/ISDN1#02/889-559", "IAX2/ast2/889") in new stack
May 27 09:38:37 VERBOSE[4729] logger.c: -- Called ast2/889
May 27 09:38:37 VERBOSE[2016] logger.c: -- Call accepted by 192.168.0.25 (format alaw)
May 27 09:38:37 VERBOSE[2016] logger.c: -- Format for call is alaw
May 27 09:38:38 VERBOSE[4729] logger.c: -- IAX2/ast2-1 is proceeding passing it to CAPI/ISDN1#02889-559
May 27 09:38:38 WARNING[2018] chan_capi.c: ISDN1#02: conf_error 0x2001 PLCI=0x101 Command=SELECT_B_PROTOCOL_CONF,0x8495
May 27 09:38:38 VERBOSE[4729] logger.c: -- IAX2/ast2-1 is ringing
May 27 09:38:47 VERBOSE[4729] logger.c: -- IAX2/ast2-1 stopped sounds
May 27 09:38:47 VERBOSE[4729] logger.c: -- IAX2/ast2-1 answered CAPI/ISDN1#/889-559
May 27 09:38:47 VERBOSE[2018] logger.c: > ISDN1#02: DTMF conf(PLCI=0x101)
May 27 09:38:47 VERBOSE[2018] logger.c: -- contr1: PLCI=0x1 CCBS/CCNR erase id=0x0001
May 27 09:38:47 VERBOSE[2018] logger.c: > CAPI: Command=FACILITY_IND,0x8496: no interface for PLCI=0x1, MSGNUM=0xc40f!
May 27 09:38:47 VERBOSE[2018] logger.c: > CAPI: Command=INFO_IND,0x8492: no interface for PLCI=0x1, MSGNUM=0xc410!
May 27 09:41:57 VERBOSE[2018] logger.c: -- chan_capi queue frame: [ TYPE: Control (4) SUBCLASS: Hangup (1) ] [ISDN1#02]
May 27 09:41:57 VERBOSE[4729] logger.c: -- Hungup 'IAX2/ast2-1'
May 27 09:41:57 VERBOSE[4729] logger.c: == Spawn extension (incomming-custom, 889, 1) exited non-zero on 'CAPI/ISDN1#02/889-559'
May 27 09:41:57 VERBOSE[4729] logger.c: -- ISDN1#02: activehangingup (cause=16) for PLCI=0x101
May 27 09:41:57 VERBOSE[2018] logger.c: == ISDN1#02: Interface cleanup PLCI=0x101
Ich vermute, es liegt am chan_capi?
IchBinEsDoch
