GMX und Grandstream 486
PPPawlo
19 Feb 2005
Ich komme ins Internet (hniter dem Modem), funktioniert als "Router" aber ich bekomme nur "besetzt". Hier ist meine Konfiguration. Kann das einer von euch erfahrenen Leuten evtl mal kurz durchchecken - wär ganz toll!! Per Netphone über Software/Computer funktioniert alles. 1000 Dank!
Grandstream HandyTone 486 Configuration
MAC Address: 	  00.0B.82.02.82.89
Product Model: 	  HT487
Software Version: 	  Program--1.0.5.16    Bootloader--1.0.0.21    HTML--1.0.0.41    VOC--1.0.0.7
  	  detected NAT type is open Internet
Admin Password: 	   xxx(admin user password to configure this IP phone)
End User Password: 	 xxx (end user password to configure this IP phone)
WAN IP Address: vorhanden
X dynamically assigned via DHCP (default) or PPPoE
(will attempt PPPoE if DHCP fails and following is non-blank)
  	PPPoE account ID: XXXX
  	PPPoE password: XXXX
   Use this DNS server (if specified): leer. . .
statically configured as:
       	IP Address: 	  . . .
       	Subnet Mask: 	  . . .
       	Default Router: 	  . . .
       	DNS Server 1: 	  . . .
       	DNS Server 2: 	  . . .
SIP Server: sip-gmx.net	  (e.g., sip.mycompany.com, or IP address)
Outbound Proxy: leer	  (e.g., proxy.myprovider.com, or IP address, if any)
SIP User ID: 49XXX(TelNummer)	  (the user part of an SIP address)
Authenticate ID: 49XXX(Telnummer)	  (can be identical to or different from SIP User ID)
Authenticate Password: XXX
Name: 	  (optional, e.g., John Doe)leer
Advanced Options:
Preferred Vocoder:
(in listed order) 	  choice 1:  PCMU
  choice 2:  PCMA
  choice 3:  G723
  choice 4:
  choice 5:
  choice 6:
  choice 7:
G723 rate: 	X  6.3kbps encoding rate       5.3kbps encoding rate
iLBC frame size: X	  20ms       30ms
iLBC payload type: 99	  (between 96 and 127, default is 98)
Silence Suppression: 	X  No      Yes
Voice Frames per TX: 2	  (up to 10/20/32/64 for G711/G726/G723/other codecs respectively)
Layer 3 QoS: 48	  (Diff-Serv or Precedence value)
Layer 2 QoS: 	  802.1Q/VLAN Tag 0    802.1p priority value (0-7) 0
Use DNS SRV: 	 X No      Yes
User ID is phone number: 	  No     X Yes (habe mit beidem experimentiert)
SIP Registration: 	  Yes     No X
Unregister On Reboot: 	  Yes     No X
Register Expiration: 	60  (in minutes. default 1 hour, max 45 days)
Early Dial: 	 X No      Yes (use "Yes" only if proxy supports 484 response)
Dial Plan Prefix: 	  (this prefix string is added to each dialed number)
No Key Entry Timeout: 4	  (in seconds, default is 4 seconds)
Use # as Dial Key: 	  No     X Yes (if set to Yes, "#" will function as the "(Re-)Dial" key)
local SIP port: 	5060  (default 5060)
local RTP port: 	5004  (1024-65535, default 5004)
Use random port: 	X  No      Yes
NAT Traversal: 	  No
  X Yes, STUN server is: (URI or IP:port) stun.gmx.net
keep-alive interval: 	20  (in seconds, default 20 seconds)
Use NAT IP 	  (if specified, this IP address is used in SIP/SDP message)
Proxy-Require: 	  (if specified, the content will appear in Proxy-Require header)
TFTP Upgrade Server: 	  . . . (for remote software upgrade and configuration)
HTTP Upgrade Server: 	  (IP address or URL)
Auto Upgrade: 	 X No      Yes, check for new firmware every days (default 7 days)
SUBSCRIBE for MWI: 	  No, do not send SUBSCRIBE for Message Waiting Indication
  Yes, send periodical SUBSCRIBE for Message Waiting Indication
Offhook Auto-Dial: 	  (User ID/extension to dial automatically when offhook)
Enable Call Features: 	  No      Yes (if Yes, Call Forwarding & Do-Not-Disturb are supported locally)
Disable Call-Waiting: X	  No      Yes
Send DTMF: 	   Xin-audio     via RTP (RFC2833)     via SIP INFO
DTMF Payload Type: 101
Send Flash Event: 	X  No      Yes   (Flash will be sent as a DTMF event if set to Yes)
FXS Impedance: 	 600
NTP Server: 	time.nist.gov  (URI or IP address)
Time Zone:
Daylight Savings Time: 	  No      Yes X  (if set to Yes, display time will be 1 hour ahead of normal time)
Send Anonymous: 	  No X      Yes   (caller ID will be blocked if set to Yes)
Lock keypad update: 	  No  X    Yes   (configuration update via keypad is disabled if set to Yes)
WAN side http access: 	  No  X    Yes   (WAN side access to http server will be rejected if set to No)
NAT/DHCP Server Information & Configuration:
WAN IP Address: 	  0.0.0.0
Cloned WAN MAC Addr: 	leer            (in hex format)
LAN Subnet Mask: 	  (default is 255.255.255.0)
LAN DHCP Base IP: 	  (base IP for the LAN port, default is 192.168.2.1)
DHCP IP Lease Time: 	  (in units of hours, default is 120 hours or 5 days)
DMZ IP:
Port Forwarding: 	  WAN port    LAN IP    LAN port    Protocol
PSTN access code: 	leer  (key pattern to use the PSTN line, default is "*00")
sip registration auf yes
send dtmf auf via sip info
bei stun server habe ich : stun.gmx.net:3478
Meines Erachtens heißt der STUN bei GMX "stun.gmx.de",probiere es mal damit! Außerdem setze mal "Layer 3 QoS" auf 176 !
Mal einen Versuch damit starten.
Gruß von Tom
Hat geklappt - Ihr seid einfach super! Danke!!
Drakkan
