<:@gw1> where gw1=sipgate.de, does not work; delay on
Dieses Thema im Forum "Linksys (VoIP)" wurde erstellt von tommmy.leee, 7 März 2005.
Status des Themas:
Es sind keine weiteren Antworten möglich.
  1. tommmy.leee
    tommmy.leee Neuer User
    3 Feb. 2005
    28
    Zustimmungen:
    Punkte für Erfolge:
    hello everybody,
    currently i have two problems with SPA3K:
    problem#1.
    configured Gateway1 (sipgate.de) does not work for outgoing calls (busy tones come up immediately when the match occurs), my configuration:
    Line1:
    Gateway1: sipgate.de
    NAT mapping: yes
    AuthID: 1234567
    Password: PaSsWoRd
    Dialplan: ([2-9]xxxx.<:mad:gw0>|0[2-9]xxxxx.<:gw0>||0049[2-9]xxxx.<:gw0>|01[4-7]xxxxxx.<:mad:gw0>|004918!|004919!|00xx.<:mad:gw1>)
    so the last part 00xx.<:mad:gw1> says to dial all international calls thru Gateway1 where sipgate.de is the VoIP provider configured (i can not set it up as VoIP provider for Line1 because i have US number from Stanaphone.com on it already).
    so if try to dial 0033xx. then surely call should be routed thru gw1 but as result i have busy tone meaning "service not available". maybe sipgate.de does not allow do outband calls without "normal" registration at all? :?
    problem#2:
    when i dial smth like 089xx. then surely i have to hop on gw0 (PSTN) as stands in dialplan to Line1. but immediately after dialing i hear ringing beeps BUT spa3k did not dial yet! so after ~10sec and these beeps spa3k goes off-hook and dials the number, then i see the real ringing beeps of callee. my "dialing pause" stands for 1 sec.
    thank you!
  2. tommmy.leee
    3 Feb. 2005
    28
    Zustimmungen:
    Punkte für Erfolge:
    anybody there? :beerdigu:
Status des Themas:
