Help foe 02 router (p2602 hwn-d7a) firmware
redocili
18 Mai 2006
hi to all
i have bricked my router upgrading the firmware...
i need a copy of original firmware...does anybady can dump it form the router (aod.1 or aof.2 version)
can be made by tftp command or by a serial cable in the bootbase debug menu
thanks to all
hi to all
i have tried with success to upgrade my old P2602hwl-67 (aol verison) in the p2602hwl-61c version by updating the firmware (from annex b to annex a used here in Italy)....with serial cable with the featurebit tip to upload a different firmware...
i got the p2602hwn-d7a (o2 router) some time ago ago and i tried the same to upgdate the router to annex a with the -d1a firmware....but with no luck
does anybody if someone get success to make sonething similar?
And i can't recover the router to its original state (neither with the Z pressing at bootup...i can make a recovery upload but i get a signature error even if is a backup of original firmware....or a excetpion error...)
Does anybody can help me to recover the router pls?
Thanks
i have tried to put the backup i have made of the firmware
i got this...
Bootbase Version: V1.07 | 7/31/2006 18:30:00
RAM: Size = 32768 Kbytes
FLASH: AMD 64M *1
frist image are empty or crash.
second image are empty or crash.
signature error!
Download firmware...
Starting XMODEM upload (CRC mode)....
CCC
FLASH: AMD 64M *1
signature error!
CC
received = 370400
Erasing.............................................................
start programing................................................................
OK
Don't know the size of romfile!!
Restore default Romfile fail, ret = 0xFFFFFFFC
Exception occured!
EPC = 0x94014620
CAUSE = 0x30808008
STATUS = 0x10007C03
$RA= 0x94014620
pressing the D key at bootup i got this...
FLASH: AMD 64M *1
Download firmware -> bootext.ram
C
what can i do now?
is this a recovery upload for the bootbase? Can i change the bootbase with this?
mwsss
