Hilfe gesucht für openclose.agi
Guard-X
Aktives Mitglied
14 Mai 2005
ich wollte folgendes Script von voip-info.org nutzen um verschiedene Ansagen für die Öffnungszeiten zu steuern:
 #!/bin/sh
# Done by Alex Lopez (alex.lopez (at) O p s y s (dot) com)
# You may need to change the if/than logic depending on OS and Shell implementation.
TODAY=`date +%m%d%y`
TODAYSHORT=`date +%m%d`
DAY=`date +%a`
HOUR=`date +%H`
MINUTE=`date +%M`
TIMENOW=$HOUR$MINUTE
STATUS=closed
case "$TODAYSHORT" in
  0101 ) STATUS=holiday;; # New Years Day
  0704 ) STATUS=holiday;; # July Forth
  1224 ) STATUS=halfday;; # Christmas Eve
  1225 ) STATUS=holiday;; # Christmas Day
  1226 ) STATUS=holiday;; # Year End holiday
  1227 ) STATUS=holiday;; # Year End holiday
  1228 ) STATUS=holiday;; # Year End holiday
  1229 ) STATUS=holiday;; # Year End holiday
  1230 ) STATUS=holiday;; # Year End holiday
  1231 ) STATUS=holiday;; # Year End holiday
esac
case "$TODAY" in
  090505 ) STATUS=holiday;; # Labor Day
  112405 ) STATUS=holiday;; # Thanksgiving
  112505 ) STATUS=holiday;; # Day after ThanksGiving
  052906 ) STATUS=holiday;; # Memorial Day
  090406 ) STATUS=holiday;; # Labor Day
  112306 ) STATUS=holiday;; # Thanksgiving
  112406 ) STATUS=holiday;; # Day after ThanksGiving
  052807 ) STATUS=holiday;; # Memorial Day
  090307 ) STATUS=holiday;; # Labor Day
  112207 ) STATUS=holiday;; # Thanksgiving
  112307 ) STATUS=holiday;; # Day after ThanksGiving
  052608 ) STATUS=holiday;; # Memorial Day
  090108 ) STATUS=holiday;; # Labor Day
  112708 ) STATUS=holiday;; # Thanksgiving
  112808 ) STATUS=holiday;; # Day after ThanksGiving
esac
if  test "$STATUS" != "holiday" -a \
    "$DAY" != "Sat" -a \
    "$DAY" != "Sun" -a \
    "$TIMENOW" -gt "0800" -a \
    "$TIMENOW" -lt "1900"
then
  STATUS=open
fi
if  test "$STATUS" = "halfday" -a \
    "$TIMENOW" -lt "1200"
then
  STATUS=open
fi
if  test "$DAY" = "Sat" -a \
    "$TIMENOW" -gt "0900" -a \
    "$TIMENOW" -lt "1600"
then
  STATUS=open
fi
if  test "$DAY" = "Sun" -a \
    "$TIMENOW" -lt "1300"
then
  STATUS=open
fi
# Until I can get the Holiday logic done in extensions.conf
# We Be CLOSED!!!
if  test "$STATUS" = "holiday"
then
  STATUS=closed
fi
echo "SET VARIABLE status $STATUS \"\""
Allerdings bekomme ich folgende Fehlermeldung in der Asterisk CLI:
*CLI> /var/lib/asterisk/agi-bin/vm-openclose.agi: line 47: Thu: command not found
/var/lib/asterisk/agi-bin/vm-openclose.agi: line 48: Thu: command not found
/var/lib/asterisk/agi-bin/vm-openclose.agi: line 49: 1404: command not found
/var/lib/asterisk/agi-bin/vm-openclose.agi: line 50: 1404: command not found
/var/lib/asterisk/agi-bin/vm-openclose.agi: line 56: 1404: command not found
/var/lib/asterisk/agi-bin/vm-openclose.agi: line 57: 1404: command not found
/var/lib/asterisk/agi-bin/vm-openclose.agi: line 63: 1404: command not found
/var/lib/asterisk/agi-bin/vm-openclose.agi: line 64: 1404: command not found
/var/lib/asterisk/agi-bin/vm-openclose.agi: line 70: 1404: command not found
/var/lib/asterisk/agi-bin/vm-openclose.agi: line 71: 1404: command not found
Habe bisher noch keine Erfahrungen mit agis gemacht, Betriebssystem ist SUSE 10. Kann mir da jemand weiterhelfen?
Danke im voraus...
mfg Guard-X
hallo,
das ist ein recht simpler fehler, der fast jedem copy&past passieren kann;
Entferne nach in allen Zeilen die mit if und bis zur zeile then das letzte Leerzeichen
Das wars nicht ganz, es gab ein kleines Problem mit den Zeilen.
So funktioniert es einwandfrei:
#!/bin/sh
DAY=`date +%a`
HOUR=`date +%H`
MINUTE=`date +%M`
STATUS=closed
esac
case "$TODAY" in
esac
if  test "$STATUS" != "holiday" -a "$DAY" != "Sat" -a "$DAY" != "Sun" -a "$TIMENOW" -gt "0800" -a "$TIMENOW" -lt "1900"
then
  STATUS=open
fi
if  test "$STATUS" = "halfday" -a "$TIMENOW" -gt "0800" -a "$TIMENOW" -lt "1200"
then
  STATUS=open
fi
if  test "$DAY" = "Sat" -a "$TIMENOW" -gt "0900" -a "$TIMENOW" -lt "1600"
then
  STATUS=open
fi
if  test "$DAY" = "Sun" -a "$TIMENOW" -gt "0900" -a "$TIMENOW" -lt "1300"
then
  STATUS=open
fi
# We Be CLOSED!!!
then
  STATUS=closed
fi
Trotzdem danke! Jetzt muss ich nur noch die Feiertage und Zeiten anpassen...
Georg Martin Reuss
