Hallo
ich benutze die LiveCD VoIPBoX V. 0.1.1 mit einer FritzCard PCI.
Die Lösung läuft soweit ohne Probleme, jedoch happert es nocht bei dem Punkt mit dem Hinaustelefonieren.
Hier meine capi.conf.
extension.conf
Ich benutze zum hinausfunken den X-Lite
; CAPI config
; general section
[general]
nationalprefix=0
internationalprefix=00
language=de
rxgain=0.8
txgain=0.8
;ulaw=yes ;set this, if you live in u-law world instead of a-law
; interface sections ...
[ISDN1] ;this example interface gets name 'ISDN1' and may be any
;name not starting with 'g' or 'contr'.
;ntmode=yes ;if isdn card operates in nt mode, set this to yes
isdnmode=msn ;'MSN' (point-to-multipoint) or 'DID' (direct inward dial)
;when using NT-mode, ptp should be set in any case
incomingmsn=* ;allow incoming calls to this list of MSNs/DIDs, * == any
;controller=0 ;ISDN4BSD default
;controller=7 ;ISDN4BSD USB default
controller=1 ;capi controller number to use
group=1 ;dialout group
;prefix=0 ;set a prefix to calling number on incoming calls
softdtmf=on ;enable/disable software dtmf detection, recommended for AVM cards
relaxdtmf=on ;in addition to softdtmf, you can use relaxed dtmf detection
accountcode= ;Asterisk accountcode to use in CDRs
context=capi-in ;context for incoming calls
holdtype=local ;when Asterisk puts the call on hold, ISDN HOLD will be used. If
;set to 'local' (default value), no hold is done and Asterisk may
;play MOH.
;immediate=yes ;immediate start of pbx with extension 's' if no digits were
;received on incoming call (no destination number yet)
;echosquelch=1 ;_VERY_PRIMITIVE_ echo suppression
;echocancel=yes ;EICON DIVA SERVER (CAPI) echo cancelation
;(possible values: 'no', 'yes', 'force', 'g164', 'g165')
echocancelold=yes;use facility selector 6 instead of correct 8 (necessary for older eicon drivers)
;echotail=64 ;echo cancel tail setting
;bridge=yes ;native bridging (CAPI line interconnect) if available
;callgroup=1 ;Asterisk call group
;deflect=1234567 ;deflect incoming calls to 1234567 if all B channels are busy
devices=2 ;number of concurrent calls on this controller
;(2 makes sense for single BRI, 30 for PRI)
channel=>1-2
;[myName]
;;PointToPoint (55512-0)
;isdnmode=ptp
;incomingmsn=*
;controller=2
;devices=30
extension.conf
[general]
static=yes
writeprotect=no
[capi-in]
exten => 52577,1,Dial(Sip/123)
exten => 52577,2,Hangup()
[capi-out] << ZUm Hinaustelefonieren
exten => s,1,Set(CALLERID(number)=52577)
exten => s,2,Dial(Capi/contr1/)
