How-To insert/substitute the libs in Ds-Mod
inshar_it
17 Feb 2006
Just a stupid question , but i am not practise with German, so i have looked for but not found an answer, how do i insert libs in the directory /lib ????
by the HOW-TO:
Integrating own files into fimware
That is really simple: Copy your files to the ./root/ folder where ever you want
the files to be in the firmware root filesystem (except ./root/lib/ and
./root/usr/lib/ which are treated seperatly)
. e.g a file ./root/usr/bin/foo will
be at /usr/bin/foo on the box.
But i need to substitute some system libs how do i do?
What libs do you want to substitue? Why?
Put your files in add/libs-0.1/root/lib and add libs-0.1 to addon/static.pkg
Greets Oliver
Greets Oliver
Because i use a Fritz 7170 with version .40 converted in Annex A and the DSL sync show a S/N Ratio that isn't great.
The International FW (mounted on converted annex b) seems to have a small better S/N ratio, so i would like to change dsl deamon and dsl drivers on .40 version substituting them with the international one.
Thanks for the answer tonight i will try this...
Can you report back to this thread with your results?
I'm interested in this mod.
Positive results, S/N Ratio is enough better on the same DSL line, connect capacity passes by 2-3Mbps up to 8 Mbps.
I will post screenshoots taken with various trial (various original FW and modded one).
Patrick89
