How to upload to webdav directly from the usb disk?
gcf
11 Nov 2007
Hi all,
I need to upload 20gb of files to a webdav location. Is it possible to connect the disk to a 7270 and issue the transfer commands directly from it, so I don't have to have a pc turned on?
You have to copy the files to a folder named "Online-Speicher", either trough network or by opening a telnet session to the box and copy the file with the linux cp command.
Ostfriese1232
