I need log on from Internet via SSH to FBF, is possible?
vpe
24 Feb 2006
I have FRITZ!Box Fon WLAN 7050 (UI), Firmware-Version 14.04.01
and i need log on from Internet via SSH to FBF, is possible?
Any howtos available? Please link, i use translator
Laender schrieb:
hi vpe!
If you only want ssh access to your fbf, you should try this one:
Anleitung: SSH (Dropbear) und Etherwake auf der FRITZ!Box
alternatively you could try the "Pseudo-Image-Creator" on this Website:
http://www.the-construct.com/
Good luck! ;)
Der Zugriff ist aber vom lan beschränkt und daher nicht übers internet abrufbar. Bzw. würde es reichen, wenn man auch den listen auf die WAN Schnitstelle oder WAN IP stellt (bei fester IP).
You could switch the interface to "listen" on wan port and/or wan ip.
For secure reason you should think about a vpn server?!
So you could login over the internet in you private network.
I realisted it over a vpn.
sorry for my bad english ;)
Yes, i known solution with separate PC in LAN with VPN, but i need solution for other situation, when i dont have running PC in LAN.
Oh no, #416 post in german on http://www.ip-phone-forum.de/showthread.php?t=79500&page=21 :-O
Plz, i need setup stealth and invissible FBF, in test with https://www.grc.com/x/ne.dll?bh0bkyd2 is vissible mapped ports and vissible:
Solicited TCP Packets: RECEIVED (FAILED) — As detailed in the port report below, one or more of your system's ports actively responded to our deliberate attempts to establish a connection. It is generally possible to increase your system's security by hiding it from the probes of potentially hostile hackers. Please see the details presented by the specific port links below, as well as the various resources on this site, and in our extremely helpful and active user community.
and
Ping Reply: RECEIVED (FAILED) — Your system REPLIED to our Ping (ICMP Echo) requests, making it visible on the Internet. Most personal firewalls can be configured to block, drop, and ignore such ping requests in order to better hide systems from hackers. This is highly recommended since "Ping" is among the oldest and most common methods used to locate systems prior to further exploitation.
Pls help. My linux box is 100% invissible... Is possible modify FBF for ping noreply and stealth all port (mapped port too)?
many thanx!!!
Blocking pings is isn't really that good...
If you ping a machine on the internet, there are 3 cases:
1. the machine is online - it answers the ping -> ok, you now know it is reachable.
2. the machine is offline - the last hop (router) tells you "host unreachable" -> you know there isn't any host on that ip.
3. the firewall on the target blocks the ping - you didn't get any answer, or maybe an answer != case 2 -> you know there is a machine with a firewall blocking pings.
So what have you won by this? Nothing! ;)
If you have a good firewall it doesn't matter if your machine is visible to the net!
Have you configured SSH (Dropbear) with a secure password (or certificate)? Then there should be no problem...
But I it I want. :-))
But I don't know, if FBF has good firewall!!!???
I at all I don't know, what has, because IPTABLES hasn't. How works firewall on FBF?
Have anyone experience with FBF firewall (modification via telnet)? Please link thread, many thx.
Is possible call IP to IP (FBF to FBF)? Used 2x FBF7050. Thx.
Hello, have anybody infos? I now use 7170 FBF. Plz. write link to german discussion (i not know search in german thread, i little englist and german no).
Nobody known link to german post?
You want to know how to call an IP? You have to create an entry in the "Telefonbuch".
Then you are able to dial the IP with a "Kurzwahl" (short dial).
Greets, Oliver
yes, work fine, thank.
Rufumleitung
and is possible Rufumleitung send to specific hostname, not Number?
I try wrote in Zielrufnummer, but input box is limited to 20 chars only...
But this works: [email protected] (1234 must be equal with any Benutzername of 10 SIP accounts)
But Zielrufnummer field must have <=20 chars !!! (bug in webgui interface in my firmware - see signature)?
Hello, work this with my latest firmware build? Thanx for reply.
Ostfriese1232
