[INFO] Firmware 5.10 für IX78
der_Gersthofer
Admin-Team
17 Apr 2004
Firmware 5.10 für IX78 ist verfügbar:
We have now released release 5.10 of our firmware for the IX78.
The easiest way of obtaining it is using the "Check for newer" link at lower left on the login page of your IX78.
Or you can use these direct links:
for ADSL Annex A: http://www.intertex.se/upfiles/78A510__.tar
for ADSL Annex B: http://www.intertex.se/upfiles/78B510__.tar
New features in release 5.10:
o Performance improved
o Voice ports (FXS/FXO) improved
o SIP support of RFC 2069 added
o SIP selection of preferred QOP added
o SIP Music on hold added
o SIP B2BUA re-INVITE end-to-end added
o SIP Strip ICE SDP attributes added
o Other SIP improvements
o Scheduler added
o Internet filter (parental control) added
o IPTV quality during heavy load improved
o ADSL improved
o Save permanently using front panel buttons added
o T.38 support improved
o IPTV quality during heavy load on Ether-WAN connections improved
o SNTP client now autoadjusts daylight saving time
o Wireless access point can now be enabled/disabled using front panel button
o Lifeboat stability improved
o Virtual access points (VAPs) implemented: AIR, AIR2, AIR3 interfaces
o Extra WAN interfaces can now be bridged to certain inside interfaces
o TR-069 improved
o VPN over PPP connections corrected
o VPN stability improved
o Added support of two channels on same PVC (one PPPoE, one DHCP)
o Telia ADSL PBX settings profile added
o Static routes support improved
o QoS routing improved
o Restore from backup file improved
o Stability improvements
o Other minor improvements
The biggest new feature is perhaps the virtual access points. It is like have three wireless access points in the same unit. You can for example have one of the access points unencrypted open for the public, with just Internet access (no access to your LAN (feature enabled by setting the subnet as "isolated", not "inside")), and the other access point encrypted, for private use, with LAN access.
People with ET4 as WAN might notice the increased throughput through the unit.
People with IPTV might notice the improved picture stability during heavy downloads and VoIP calls.
Plus there are lots of other improvments making it a good choice to upgrade to.
Weisst du vielleicht, ob mit der neuen Firmware IX78 am T-DSL funktioniert? Mit der Firmware 5.02 wurde die T-DSL Verbindung bei mir immer nach etwa einer Sekunde getrennt, so dass es ohne externem ADSL Modem nicht möglich war, sich zu verbinden.
Und funktioniert IX78 an den T-Home Entertain VDSL2 Anschlüssen, wo VLAN Tagging gemacht werden muss? Würde gerne T-Home VDSL bestellen, aber alle Router, die als dafür geeignet genannt werden, scheinen nicht SIP aware zu sein.
Der Router hat ja kein VDSL-Modem intergriert, nur ein ADSL2+ Modem.
Nein, kann ich nicht sagen, da mein IX78 an einem Kabelmodem hängt.Wichtig für Deutschland ist aber, dass man die Annex-B Firmware verwendet.
Habe mich gewagt, die 5.10 zu probieren, aber bin schon zurück auf die 5.02.
Die IP bei DynIP wurde nach der Änderung der IP nicht upgedatet.
Die Zeitzone änderte sich selbständig von UTC+2 auf UTC-12.
Zu gravierende Probleme um mit der Version weiter testen zu können.
Genau deswegen macht man ja einen factory reset und gibt die Einstellungen dann auch händisch ein :bahnhof:
mwsss
