[INFO] Version 4.02 (Final) für IX68 verfügbar
der_Gersthofer
Admin-Team
17 Apr 2004
Erste BETA Version von Version 4.02 für IX67 und IX68 verfügbar unter
Beim IX68 ist wichtig, dass man nach dem Update auf die Administratorseite geht und auf "install" im Feld "Bootloader" klickt, um den neuen Bootloader zu installieren.
Nachdem es sich um eine frühe Beta-Version handelt, sollte diese nicht in Produktivumgebungen eingesetzt werden.
Neue Betaversion
IX68
We have now put pre-release 5 of 4.02 on our site.
Pre-release 5 of 4.02 is available for the IX68 model:
(a version suitable for IX67 will also be released soon)
This is a hidden link, the release is not public yet. In fact, as the name tells, it is only a pre-release. This is only for you guys reading IX Central!
NOTE: This pre-release is provided "as-is". Intertex does not support it officially. You cannot contact neither our resellers' nor Intertex's support with questions about it.
But of course will we try to help you through this site!
New features in 4.02pre5 (compared to 4.02pre1):
* SNTP support
* Improved german language
* Improved swedish help texts
* Updated ADSL driver
* Provisioning
* New upgrade procedure
* Ability to disable "obtain automatically" and enter DNS server IP addresses manually on Network configuration page
* Memory size available for configuration storage doubled to 128KB
* dyndns update after boot improved
* new bootloader: config-area in flash autorepaired if damaged
* Network status, Advanced added to dropdown menu
* FXS one-way media corrected
* forward to FXO port from user account no longer requires authentication
* FXO caller ID corrected
* ADSL configuration page improved
* Upgrade / provisioning page improved
* FXS QoS corrected
* DTMF caller ID support for Denmark
WARNING! As the memory area in flash used to store configuration information has changed, loading 4.02pre5 instantly erases all your settings!
To avoid loosing your settings you must back them up before installing this release!
Also, due to memory problems, you might get problems upgrading units to this release, especially models with PHONE ports or units with extensive configuration.
Therefore please follow this steps closely when upgrading your unit to this release:
1. Go to Configurations, Administraton and click on "Backup to file" to backup your config to a PC file
2. Units with PHONE ports: Go to Configurations, Security and enter "100" into the "Total" field of Resource Allocation. Click Apply, then click "Save permanently" at top of the page.
3. Reboot the unit.
After unit has rebooted:
4. Go to "Configurations", "Upgrade", and enter the name of the tar-file to upgrade to and click "Go"
After the new firmware has been installed:
5. Go to Configurations, Administration and click on "Install" in the "Bootloader" field.
After new bootloader has been installed (takes ca 2 seconds):
6. Go to Configurations, Administration, enter the file name of your file saved in step 1 above, and klick "Go"
7. Click "Save permanently" at top of the page.
These steps are not required in future upgrades but are vital for this one.
We plan to release release 4.02 as soon as possible.
IX67
New features in 4.02pre6 (compared to 4.02pre1):
* SNTP hostnames corrected
* FXS QoS corrected
* export/import of ATAbox mode now handled correctly
* improved DHCP server behaviour when IX67 is not the only DHCP server on a network
* improved power-on test of flash files
The improved power-on test of flash files now displays "FEr" (Flash Error) if any severe error is found in the flash file system of the unit that requires it to be reformatted.
If your unit displays "FEr" upon reboot you need to go to the upgrade firmware page and follow instructions for how to reformat your unit and reload the firmware.
Eine neue Beta ist verfügbar
After some final fixes we have now put a new pre-release of 4.02 on our site.
(Yes it is actually pre7 for the IX67 and pre8 for the IX68, as we have found one problem in pre7 that applied to IX68 only)
New features:
* Improved fragment handling
* "Allow outgoing calls from" improved
* Authentication on multiple servers for same request improved
* Forking improved
* 408 request timeout fallback improved
* Call transfer corrected
* Provisioning improved
* IX68: Debug file improved
* IX68: ADSL offline behaviour with FTP server specified improved
* IX67: Power-on selftest improved
Der letzte RC vor 4.02
OK, this is the final release candidate for 4.02
New features:
* voice packet time parameter added
* FXO authentication improved
* SIP one-way media problem corrected
* SIP double authentication corrected
* SIP Cisco compability improved
* SIP Messenger file transfer corrected
* IX68 caller ID corrected
* IX68 SNTP server can now be IP address too
* QoS improved
* IX67: PPTP server stability improved
* IX68: added Call Anonymous for FXS ports to user page
* other minor improvements
We really hope to release this final release candidate next week, unless any serious error is found.
Neue Beta PRE15 für IX68
As for the IX68 we want to release a final pre-release just to make sure everything is acceptable, before releasing the final 4.02 release for the IX68 too.
Pre-release 15 is updated to the same level as the released IX67 firmware, plus two IX68-specific fixes.
You can download it at:
New features in 4.02pre15:
* Memory leak corrected
* Flash protection improved
* SIP forking improved
* Find SIP URI locally added
* SIP hold improved
There are a couple of issues with 4.02 for the IX68 -like SNTP and syslog being attempted to be accessed before PPP connection is up- that will not be fixed in 4.02 but in 4.03
Final der 4.02 verfügbar
Annex B (Deutschland) http://www.intertex.se/upfiles/68B402__.tar
Annex A http://www.intertex.se/upfiles/68A402__.tar
ACHTUNG:
Für alle, die schon eine PRE 4.02 installiert haben, gilt:
Those of you upgrading from a 4.02 pre-release shall NOT follow those instructions!!! (Messes up your unit) You upgrade as usual.
Für alle anderen, die also von 4.01 kommen, gilt:
WARNING!
  • Follow these upgrade instructions closely!
  • Loading release 4.02 instantly ERASES all your settings!
  • You might also fail upgrading certain units to this release if not proceeding as described below.
Therefore please follow these steps closely when upgrading your unit to this release:
  • Go to Configurations, Administration and click on "Backup to file" to backup your configuration to a PC file.
  • Units with PHONE ports: Go to Configurations, Security and enter "100" into the "Total" field of Resource Allocation. Click Apply, then click "Save permanently" at top of the page.
  • Reboot the unit.
  • Go to "Configurations", "Upgrade", and enter the name of the tar-file to upgrade to and click "Go".
  • Go to Configurations, Administration and click on "Install" in the "Bootloader" field.
  • Installation of the bootloader takes about 10 seconds. Please click "Install" just once and wait for the installation to finish.
After new bootloader has been installed:
  • Go to Configurations, Administration, and at "Restore from file" enter the file name of your file saved in step 1 above, then click "Go".
  • Click "Save permanently" at top of the page.
Release notes:
[B]WLAN ENHANCEMENTS:[/B]
WPA2-PSK added
WEP Authentications added
Closed System added
Café Mode added
[B]TELEPHONE PORT FUNCTION ENHANCEMENTS:[/B]
Improved caller ID handling
Improved 3-way calling voice quality
DTMF caller ID support for Denmark added
FXO caller ID improved
FXS account not limited to user if SIP Switch license exists
Forward to FXO port from user account no longer requires authentication
Call Anonymous for FXS ports added to user page
Voice quality improved
Call transfer improved
Voice stability improved
[B]SIP HANDLING IMPROVEMENTS:[/B]
Major improvements in SIP registrar/proxy/server/B2BUA/switch
Double authentication corrected
SIP switch promote/evaluate added
One-way media corrected
Forking improved
Handling of no answer improved
Interoperability with weak SIP implementations improved
Broadvoice compatibility improved
[B]OTHER ENHANCEMENTS:[/B]
Fragment handling improved
QoS improved
Remote config using ALT button
WAN IP connectivity detection added
Keepalive added
German language added
Security level Blocked added
Diagnostic test added
MAC address spoofing added
E-mail notification added
Lifeboat support added
Backup/restore improved
Provisioning added
SNTP added
DHCP improved
Manual entry of DNS address added
Revised upgrade procedure
Configuration memory area doubled
Dyndns update after boot improved
config-area in flash auto repaired if damaged
User login page login handling modified
Other minor improvements
Patrick89
