Installation von H.323
olaf_TT
15 Mrz 2005
Hallo Forum,
bei der Installation von H.323 nach der VoIP-FAQ
geht bei mir unter Suse 9.0 folgendes schief:
linux:/usr/src/pwlib # ./configure --prefix=/usr
PTLib version is 1.5.2
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
OSTYPE set to linux
OSRELEASE set to 2.4.21-280-default
MACHTYPE set to x86
checking for gcc... gcc
checking for C compiler default output... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking whether byte ordering is bigendian... no
checking if linker accepts --gc-sections... yes
checking if compiler accepts -ffunction-sections... yes
checking if compiler accepts -fdata-sections... yes
checking if compiler accepts -fvtable-gc... no
checking for pthread_create in -lpthread... yes
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking libdc1394/dc1394_control.h usability... no
checking libdc1394/dc1394_control.h presence... no
checking for libdc1394/dc1394_control.h... no
checking libavc1394/avc1394.h usability... no
checking libavc1394/avc1394.h presence... no
checking for libavc1394/avc1394.h... no
checking libdv/dv.h usability... yes
checking libdv/dv.h presence... yes
checking for libdv/dv.h... yes
checking for res_search... no
checking for res_search in -lresolv... yes
checking ldap.h usability... no
checking ldap.h presence... no
checking for ldap.h... no
checking for /usr/local/include/ldap.h... no
checking openssl/ssl.h usability... yes
checking openssl/ssl.h presence... yes
checking for openssl/ssl.h... yes
checking expat.h usability... yes
checking expat.h presence... yes
checking for expat.h... yes
checking for XML_ParserCreate in -lexpat... yes
checking SDL/SDL.h usability... no
checking SDL/SDL.h presence... no
checking for SDL/SDL.h... no
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for IPv6 Support... yes
checking linux/videodev.h usability... yes
checking linux/videodev.h presence... yes
checking for linux/videodev.h... yes
checking machine/ioctl_meteor.h usability... no
checking machine/ioctl_meteor.h presence... no
checking for machine/ioctl_meteor.h... no
checking i386/ioctl_meteor.h usability... no
checking i386/ioctl_meteor.h presence... no
checking for i386/ioctl_meteor.h... no
checking dev/ic/bt8xx.h usability... no
checking dev/ic/bt8xx.h presence... no
checking for dev/ic/bt8xx.h... no
checking for swab... yes
checking for dlopen in -ldl... yes
configure: creating ./config.status
config.status: creating make/ptbuildopts.mak
config.status: creating make/ptlib-config
config.status: creating Makefile
config.status: creating include/ptbuildopts.h
config.status: include/ptbuildopts.h is unchanged
linux:/usr/src/pwlib # make install
mkdir -p /usr/include
mkdir -p /usr/bin
mkdir -p /usr/lib
mkdir -p /usr/share/pwlib
chmod a+r lib/*so*
cp -df lib/*so* /usr/lib/
cp -rf include/ptclib/ /usr/include/
cp -rf include/ptlib/ /usr/include/
cp -rf include/ptbuildopts.h /usr/include/
cp -rf include/ptlib.h /usr/include/
cp tools/asnparser/obj*/asnparser /usr/bin/
cp: cannot stat `tools/asnparser/obj*/asnparser': No such file or directory
make: *** [install] Error 1
Was mache ich falsch?
Danke für Hilfe
Google Suche:
http://www.google.de/search?hl=de&q...ch+file+or+directory+&btnG=Google-Suche&meta=
führt Dich zu:
http://www.openh323.org/pipermail/openh323/2004-April/067508.html
Dort steht beim Posting von Craig Southeren vom 20.April 2004 folgendes:
es, you have discovered a bug.
> > >Please remove the following line from the file Makefile.in:
> > >cp tools/asnparser/obj*/asnparser /usr/local/bin/
> > >And re-run the configure program.
... ob das des Rätsels Lösung ist, weiss ich nicht, auf alle Fälle deutet die Fehlermeldung darauf hin, dass es das Verzeichnis tools/asnparser/obj*/asnparser nicht gibt...
Grüsse
schuelsche
Hi schuelsche,
werde das heute abend mal testen.
olaf_TT
hi olaf_tt
die neuesten sourcen findest du unter http://sourceforge.net/projects/openh323/
eine Anleitung zum bauen findest du unter
http://www.openh323.org/build.html
und in den sourcen von asterisk sollte es auch ein readme dazu geben.
evtl. mußt du noch unter asterisk vergl. ob es eine empfohlene version
für pwlib und openh323 gibt, da es sein kann, daß nicht alle versionen kompatibel sind.
vorher die pfade setzen (findest du in der anleitung bei h.323 s. oben)
dann jeweils
ein ./configure
make opt
sollte funktionieren und dann den teil von asterisk kompilieren.
...so, hab jetzt alles mit Suse 9.0 am laufen:
ZAPHFC im NT-Mode, CAPI, H323 und SIP!
Jetzt hab ich aber noch ein Problem mit ??? (ich denke die Codec's).
Meine grobe Konfiguration:
NTBA <--> Fritz! <--> Asterisk <--> ZAPHFC <--> TK-Anlage (Alcatel OmniPCX Office)
+ TK-Anlage (Alcatel OmniPCX Office) <--> H323 <--> Asterisk
Mein Problem:
Gespräche von SIP und ZAP untereinander und auf H323 sind OK
Gespräche von H323 auf SIP und ZAP haben einseitige Verständigung.
Man hört auf der H323 Seite nichts.
Danke für eure Hilfe
olaf_TT
Moin TOM,
hab mal auf die schnelle einen Trace mit Ethereal gemacht und ich denke das sieht alles OK aus.
Asterisk: 192.168.92.230
SIP: 192.168.92.101
H323: 192.168.92.248
Trace: siehe Anhang
Thema H323 installation:
es hatte bei mir das Packet "flex" gefehlt.
Mit Yast draufgezogen und fertig.
War wohl dringend notwendig, denn danach lief die installation
problemlos...
(installation=compilieren -- komme aus der Windoofwelt -- Sorry!)
war das jetzt ein trace bei dem nur eine seite etwas hört ?
in dem trace kann man sehen, daß die rtp pakete in beide richtungen gehen, aber nur zwischen dem SIP(192.168.92.101) Client und Asterisk(192.168.92.230), der RTP Stream zwischen dem H323 Endpoint(192.168.92.246) und Asterisk fehlt vollkommen. ???
ups...sorry! Hab den Trace auf dem "SIP-Rechner" gemacht. Da mein Netz geswitcht ist fehlen natürlich die Packete zur TK-Anlage.
Wird nachgeliefert!!!
Hier der Trace gemacht auf dem Asterisk-PC:
Hallo
ich bin bei installation von ptlib folgende Fehler
was muss ich tun?
make[3]: *** [/home/pse/build-intrepid/ptlib/lib_linux_x86/device/sound/pulse_pwplugin.so] Fehler 1
make[3]: Verlasse Verzeichnis '/home/pse/build-intrepid/ptlib/plugins/sound_pulse'
make[2]: *** [optshared] Fehler 2
make[2]: Verlasse Verzeichnis '/home/pse/build-intrepid/ptlib/plugins/sound_pulse'
make[1]: *** [optshared] Fehler 2
make[1]: Verlasse Verzeichnis '/home/pse/build-intrepid/ptlib/plugins'
make: *** [optshared] Fehler 2
greypeter1
