Is virtuel ip working with freetz?
flemse
14 Mrz 2007
Hi
I use virtuel ip together with dropbear but after upgrading to latest avm firmware and made a svn from freetz, my 7140 hawing problem with it to work.
7140 Annex A, Firmware version 39.04.56-freetz-devel-2274
I hawing this message from syslog:
internet: 192.168.10.250 not an intern host, forwardrule "tcp 0.0.0.0:2500 192.168.10.250:22 0 # ssh-wan" ignored
any hints?
AVM has disabled this hack for recent firmwares. You can use nvi /var/flash/ar7.cfg to go further. Simple replace 192.168.10.250 with 0.0.0.0. After that you can't see this forwarding in the webinterface anymore but it should work.
Greets Oliver
There is this thread which covers this topic quite nicely.
It is in German, but maybe nevertheless of use for you (look at the code boxes).
In the very 1st post of that thread there are two different ways how to handle the fact that forward rules entered/edited in "ar7.cfg" (e.g. via the FBEditor tool - java applet which should run on almost all platforms) are not displayed anymore in the WebGUI (but still working).
There is a short and a long script, whereas the long script helps to display such rules as 0.0.0.0 also in the WebGUI (if a I am not completely mistaken).
If you like to, you may ask your questions in that thread, of course.
figo12
