Kann mit AAH nicht auf die S0 raustelefonieren
Messerjocke2000
5 Jul 2005
Hallo!
Ich habe da ein Prob mit AAH.
Ich will AAH als PBX laufen lassen:
ISDN->normale PBX->Asterisk@Home->IP-Telefone
IP-Telefonie funktioniert auch.
Bristuff läuft, Karte ist im TE-Modus.
Meine .confs
Zapata
Zapata telephony interface
; Configuration file
[channels]
language=en
switchtype=euroisdn
;If you connect to a hicom PBX set your ISDN Numbering Plan Identifier to unknown.
pridialplan=dynamic
prilocaldialplan=local
; p2mp TE mode
 signalling = bri_cpe_ptmp
; p2p TE mode
; signalling = bri_cpe
; p2mp NT mode
;signalling = bri_net_ptmp
; p2p NT mode
usecallerid=yes
hidecallerid=no
callwaiting=yes
usecallingpres=yes
callwaitingcallerid=yes
threewaycalling=yes
transfer=yes
cancallforward=yes
callreturn=yes
echocancel=yes
echocancelwhenbridged=yes
rxgain=0.0
txgain=0.0
group=1
callgroup=1
pickupgroup=1
immediate=no
context=default
channel => 1-2
zaptel
#/etc/zaptel.conf
loadzone=nl
defaultzone=nl
# Hinweis: Zone nl ist mit Zone de identisch
span=1,1,3,ccs,ami
bchan=1-2
dchan=3
extensions_additional.conf
[globals]
RINGTIMER = 15
REGTIME = 7:55-17:05
REGDAYS = mon-fri
RECORDEXTEN = ""
PARKNOTIFY = SIP/200
OUT_2 = ZAP/g0
OUTPREFIX_2 =
OUTMAXCHANS_2 = 2
OUTCID_2 = TESTER
OPERATOR =
NULL = ""
IN_OVERRIDE = forcereghours
INCOMING = GRP-1
FAX_RX_EMAIL = [email][email protected][/email]
FAX_RX = system
FAX =
E102 = SIP
E101 = SIP
E100 = SIP
DIRECTORY_OPTS =
DIRECTORY = last
DIAL_OUT = 9
DIAL_OPTIONS = tr
DIALOUTIDS = 2/
CALLFILENAME = ""
AFTER_INCOMING =
[ext-did]
include => ext-did-custom
exten => 386,1,Goto(from-pstn,s,1)	;
[ext-group]
include => ext-group-custom
exten => 1,1,Setvar(GROUP=100-101-102)	;
exten => 1,2,Setvar(RINGTIMER=20)	;
exten => 1,3,Setvar(PRE=)	;
exten => 1,4,Macro(rg-group)	;
exten => 1,5,Macro(vm,102)	;
[ext-local]
include => ext-local-custom
exten => 100,1,Macro(exten-vm,100@default,100)
exten => 101,1,Macro(exten-vm,101@default,101)
exten => 102,1,Macro(exten-vm,102@default,102)
[outbound-allroutes]
include => outbound-allroutes-custom
include => outrt-001-local
[outrt-001-local]
include => outrt-001-local-custom
exten => _0XXX,1,Macro(dialout-trunk,2,${EXTEN:1})
exten => _0XXX,2,Macro(outisbusy)	; No available circuits
[globals]
RINGTIMER = 15
REGDAYS = mon-fri
RECORDEXTEN = ""
OUT_2 = ZAP/g0
OUTPREFIX_2 =
OUTMAXCHANS_2 = 2
OUTCID_2 = TESTER
OPERATOR =
NULL = ""
INCOMING = GRP-1
FAX_RX = system
FAX =
E102 = SIP
E101 = SIP
E100 = SIP
DIRECTORY_OPTS =
DIRECTORY = last
DIAL_OUT = 9
DIAL_OPTIONS = tr
DIALOUTIDS = 2/
CALLFILENAME = ""
AFTER_INCOMING =
[ext-did]
[ext-group]
[ext-local]
[outrt-001-local]
Wenn ich raustelefonieren will (auf die S0) kommt die Ansage:All lines are busy.......
versuche ich vom Netz aus reinzurufen, passiert nix in der CLI und ich krieg ein besetztzeichen.
in der Zapata hab ich schon beide Signalisierungen probiert, tut sich nüscht.
jemande Ideen?
Danke schon mal,
Kilian
mehlm
