keine Anurufe von Freenet, Purtel, Nikotel aus möglich
  • Ersteller Ersteller beckmann
B
beckmann
Guest
ich kann keine Anrufe von Freenet aus bekommen. Hier meine Sip.conf
[general]
 ;localnet=192.168.123.0/255.255.255.0
 port = 5060
 bindaddr = 0.0.0.0
 context = default
 disallow=all
 allow=gsm
 allow=ulaw
 allow=alaw
 nat=yes
 ;externip=www.xxxxxxxx.ipme.de
 ;srvlookup=yes
 ;canreinvite=no
 ;tos=0x18
 ;insecure=very
 ;dtmfmode=info
 ;maxexpirey=3600
 ;defaultexpirey=120
 register => UUUUU:*******@sipgate.de/UUUUUU
 register => UUUUU:*******@sip.purtel.de/55555
 register => UUUUU:*******@deu1.purtel.com/55555
 register => UUUUU:*******@calamar0.nikotel.com/55555
 register => UUUUU:*******@sipsnip.com/55555
 register => UUUUU:*******@pbx-network.de/101031
 register => UUUUU:*******[email protected]/55555
[55555]
 type=friend
 username=55555
 secret=*******
 host=dynamic
 disallow=all
 allow=ulaw
 allow=alaw
 dtmfmode=rfc2833
 context=sipgate
 mailbox=55555
 nat=yes
[55556]
 type=friend
 username=55556
 secret=*******
 host=dynamic
 disallow=all
 allow=ulaw
 allow=alaw
 dtmfmode=rfc2833
 context=sipgate
 mailbox=55556
 nat=yes
 [sipgate]
 type=friend
 username=UUUUUUU
 secret=******
 host=sipgate.de
 fromuser=UUUUUU
 nat=yes
 context=sipgate
 canreinvite=no
 qualify=yes
 insecure=very
 fromdomain=sipgate.de
 [purtel_de]
 type=friend
 username=UUUUUU
 host=sip.purtel.de
 secret=*****
 qualify=yes
 trunk=no ; If the ztdummy-Kernel Module is enabled
 context=default
 nat=yes
 [purtel_com]
 type=friend
 username=UUUUUUU
 host=deu1.purtel.com
 secret=******
 qualify=yes
 context=fromPurtel
 nat=yes
 [nikotel]
 secret=******
 username=UUUUU
 fromuser=UUUUU
 type=friend
 host=calamar0.nikotel.com
 context=default
 canreinvite=no
 nat=yes
 fromdomain=nikotel.com
 insecure=very
 promiscredir=yes
 qualify=1200
 [pbx]
 secret=*******
 username=UUUUUU
 fromuser=UUUUUU
 type=friend
 host=pbx-network.de
 context=default
 canreinvite=no
 nat=yes
 fromdomain=pbx-network.de
 insecure=very
 promiscredir=yes
 qualify=1200
 [freenet]
 secret=******
 username=UUUUU
 fromuser=UUUUU
 type=friend
 host=freenet.de
 context=sipgate
 canreinvite=no
 nat=yes
 fromdomain=freenet.de
 insecure=very
 ;promiscredir=yes
 qualify=yes
extensions.conf
default]
;user 55555
exten => 55555,1,Dial(SIP/${EXTEN},60)
exten => 55555,2,Voicemail2(b55555)
exten => 55555,102,Voicemail2(u55555)
;user 55556
exten => 55556,1,Dial(SIP/${EXTEN},60)
exten => 55556,2,Voicemail2(b55556)
exten => 55556,102,Voicemail2(u55556)
[sipgate]
include => default
;Mailbox
exten => 333/_[1-9].,1,Answer
exten => 333/_[1-9].,2,Wait(1)
exten => 333/_[1-9].,3,VoicemailMain2(s${CALLERIDNUM})
exten => 333/_[1-9].,4,Hangup
;Anrufe für sipgate-Account  an 55555 leiten
exten => UUUUU,1,Dial(sip/55555,30,tr) ;das gleiche UUUU wie bei Sip conf - Anrufe kommen an nur werden nicht auf die Mailbox geleitet
;für Purtel.de
exten => _8.,1,Dial(SIP/${EXTEN:1}@purtel_de,60)
exten => _8.,2,Congestion
exten => _8.,102,Busy
;für Purtel.com
exten => _7.,1,Dial(SIP/${EXTEN:1}@purtel_com,60)
exten => _7.,2,Congestion
exten => _7.,102,Busy
;für Nikotel
exten => _6.,1,Dial(SIP/${EXTEN:1}@nikotel,60)
exten => _6.,2,Congestion
exten => _6.,102,Busy
;für PBX
exten => _4.,1,Dial(SIP/${EXTEN:1}@pbx,60)
exten => _4.,2,Congestion
exten => _4.,102,Busy
;für Freenet
exten => _2.,1,Dial(SIP/${EXTEN:1}@freenet,60)
exten => _2.,2,Congestion
exten => _2.,102,Busy
Kann mir einer weiterhelfen Warum ich keine Anrufe entfangen kann?
Ersetz mal 55555 durch die Nummer unter uuuuu und pass dann die extensions.conf entsprechend an.
Ich habe jetzt abgeändert in:
register => UUUUU:*******[email protected]/UUUUU
und in der extensions.conf habe ich den Eintrag
exten => UUUUU,1,Dial(SIP/55555,60)
Ich bekomme immer noch ein besetzt zu hören wenn ich mich über meine Festnetznummer anrufe.
Komischerweise kann ich nur über Sipgate angerufen werden
Rufst du dich über VoIP (sipgate) selber an oder von einem nicht VoIP-Anschluss?
Wenn du dich über * selbst anrufst gibt es einen:
-- Got SIP response 482 "Loop Detected" back from 217.10.79.9
Freenet stellt quasi fest, dass Absender und Empfänger identisch sind und legt auf!
Lass das qualify=yes aus (=no)
und unter [general] ergänze mal:
maxexpirey=3600
defaultexpirey=600
Starte die Konsole mal mit 'asterisk -dddvvvr' und schau dir an ob ein Call reinkommt und falls ja siehst du wo es klemmt!
'sip show registry' zeigt dir ob du bei freenet ordentlich registriert bist. Dies ist zunächst einmal die Grundvoraussetzung um mit obigem Command etwas sehen zu können!
Also sip show registry gibt aus:
Host                            Username       Refresh State
freenet.de:5060              UUUUU         585 Registered
sipgate.de:5060              UUUUU         585 Registered
Wenn ich mich über Freenet anrufe gibt asterisk -dddvvvr nichts aus. Rufe ich über Sipgate an kommt die Meldung unten und das Telefon klingelt.
  -- Executing Dial("SIP/UUUUU-8450", "SIP/55555|60") in new stack
    -- Called 55555
    -- SIP/55555-97ff is ringing
Dann liegt es an freenet und wir brauchen nicht mehr weiterzusuchen!
Schade, dann muss ich wohl auf den Asterisk Server verzichten. Wollte eigentlich alle Anschlüße auf ein Telefon leiten lassen.
Das komische ist, wenn ich das Grandstream BT101 benutze (ohne einen einzigen Port weiter zu leiten) dann kann ich anrufe empfangen. Ausgende Anrufe funktionieren über Freenet.
Eins kannst du noch probieren!
'asterisk -dddvvvr'
'sip debug' und schauen ob bei einem eingehenden Anruf irgendwelche Fehlermeldungen erscheinen!
Vielleicht stört sich sich freenet trotz status 'registered' an irgendetwas?
Ausserdem habe ich noch folgenden Fehler gesehen:
register => UUUUU:*******G@iphone.freenet.de/UUUUU
ich bekomme dann nach mehr als 15 sekunden follgendes:
Reliably Transmitting:
OPTIONS sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.123.1:5060;branch=z9hG4bK2cd62895
From: "asterisk" <sip:[email protected]>;tag=as5a0e5d20
To: <sip:[email protected]:5060>
Contact: <sip:[email protected]>
Call-ID: [email protected]
CSeq: 102 OPTIONS
User-Agent: Asterisk PBX
Date: Sun, 23 Jan 2005 10:07:30 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER
Content-Length: 0
 (no NAT) to 192.168.123.2:5060
Server*CLI>
Sip read:
SIP/2.0 200 Ok
To: <sip:[email protected]:5060>;tag=656517845
Contact: <sip:[email protected]:5060>
Allow: INVITE,ACK,BYE,CANCEL,OPTIONS,NOTIFY
CSeq: 102 OPTIONS
Server: X-Lite release 1103a
Content-Length: 0
10 headers, 0 lines
Destroying call '[email protected]'
11 headers, 0 lines
OPTIONS sip:194.97.54.97 SIP/2.0
Via: SIP/2.0/UDP 192.168.123.1:5060;branch=z9hG4bK2967c48f
From: "asterisk" <sip:[email protected]>;tag=as1b70c0eb
To: <sip:194.97.54.97>
CSeq: 102 OPTIONS
Content-Length: 0
 (no NAT) to 194.97.54.97:5060
11 headers, 0 lines
OPTIONS sip:217.10.79.9 SIP/2.0
Via: SIP/2.0/UDP 192.168.123.1:5060;branch=z9hG4bK7ce48523
From: "asterisk" <sip:[email protected]>;tag=as6129aac2
To: <sip:217.10.79.9>
CSeq: 102 OPTIONS
Content-Length: 0
 (no NAT) to 217.10.79.9:5060
Server*CLI>
Sip read:
SIP/2.0 403 no relaying
Via: SIP/2.0/UDP 192.168.123.1:5060;branch=z9hG4bK2967c48f;received=80.143.179.1
To: <sip:194.97.54.97>;tag=5f61617ce4661383c5d475661db5b4db.d454
CSeq: 102 OPTIONS
Content-Length: 0
7 headers, 0 lines
Server*CLI>
Sip read:
SIP/2.0 482 Loop Detected
Via: SIP/2.0/UDP 192.168.123.1:5060;branch=z9hG4bK7ce48523;rport=5060;received=80.143.179.1
To: <sip:217.10.79.9>;tag=b11cb9bb270104b49a99a995b8c68544.3efa
CSeq: 102 OPTIONS
Server: sipgate ser
Content-Length: 0
Warning: 392 217.10.79.9:5060 "Noisy feedback tells:  pid=16300 req_src_ip=80.143.179.1 req_src_port=5060 in_uri=sip:217.10.79.9 out_uri=sip:217.10.79.9 via_cnt==1"
9 headers, 0 lines
Server*CLI>
das mit dem iphone.freenet.de funktioniert nicht. Dann kann sich Asterisk gar nicht mehr anmelden. das mit Freenet.de funktioniert, wenn ich iphone.freenet.de neme, dann kommt not Found.
Du erhälst zwar Fehlermeldungen, aber diese sind bekannt - Anrufe sollten trotzdem funktionieren!
iphone.freenet.de:5060 xxxxxx 600 Request Sent
-- Got SIP response 403 "Anruf nicht erlaubt" back from 194.97.54.97
Liegt das jetzt an meiner Seite oder an der Seite von Freenet? Dieses howto habe ich genau übernommen und es kommen trozdem noch Fehler. Kann das noch an anderen Asterisk einsellungen liegen?
Jetzt schau mal nicht auf die Fehlermeldungen - klappt das Anrufen?
Kontrolle mit 'asterisk -dddvvvr'
wichtig:
verify=no
und unter global:
maxexpirey=3600
defaultexpirey=600
Anrufen kann ich ohne Probleme. Nur anrufe aus dem Festnetz kommen nicht an. Die Einstellungen habe ich gesetzt. Leider ohne erfolg.
ich versuche mich mal mit diesem Beispiel. Mal sehen ob das was bringt.
Ausserdem scheint mit deinem dialplan etwas nicht zu stimmen - du produzierst einen loop Richtung sipgate:
Sip read:
CSeq: 102 OPTIONS
Server: sipgate ser
Content-Length: 0
Poste doch bitte nochmals deine sip.conf und extensions.conf damit wir auf dem aktuellsten Stand sind!
Horst@alphago
