Hi chaos2000,
falls man da was erkennen kann ?:
Connected to Asterisk 1.0.9-BRIstuffed-0.2.0-RC8j currently running on esel (pid = 22456)
Verbosity was 0 and is now 3
Jan 4 17:38:57 DEBUG[22457]: acl.c:176 ast_apply_ha: ##### Testing 217.10.79.9 with 192.168.0.0
Jan 4 17:38:57 DEBUG[22457]: chan_sip.c:636 ast_sip_ouraddrfor: Target address 217.10.79.9 is not local, substituting externip
Jan 4 17:38:57 DEBUG[22457]: chan_sip.c:4187 transmit_register: Scheduled a registration timeout # 2
Jan 4 17:38:57 DEBUG[22457]: chan_sip.c:842 __sip_ack: Stopping retransmission on '
[email protected]' of Request 102: Found
[email protected]' of Request 103: Found
Jan 4 17:38:57 DEBUG[22457]: chan_sip.c:6812 handle_response: Registration successful
Jan 4 17:38:57 DEBUG[22457]: chan_sip.c:6814 handle_response: Cancelling timeout 2
Jan 4 17:39:07 DEBUG[22457]: acl.c:176 ast_apply_ha: ##### Testing 217.10.79.9 with 192.168.0.0
Jan 4 17:39:07 DEBUG[22457]: chan_sip.c:636 ast_sip_ouraddrfor: Target address 217.10.79.9 is not local, substituting externip
Jan 4 17:39:07 DEBUG[22457]: chan_sip.c:5559 check_user_full: Setting NAT on RTP to 4
Jan 4 17:39:07 DEBUG[22457]: chan_sip.c:7382 handle_request: Check for res for
Jan 4 17:39:07 DEBUG[22457]: chan_sip.c:1597 update_user_counter: is not a local user
Jan 4 17:39:07 DEBUG[22457]: chan_sip.c:4646 build_route: build_route: Record-Route hop: <sip:
[email protected];ftag=c3709051a39f4a89aeb982e90ac3966b;lr=on>
Jan 4 17:39:07 DEBUG[22457]: chan_sip.c:4646 build_route: build_route: Record-Route hop: <sip:194.97.54.97;ftag=c3709051a39f4a89aeb982e90ac3966b;lr=on>
Jan 4 17:39:07 DEBUG[22457]: chan_sip.c:4646 build_route: build_route: Record-Route hop: <sip:194.97.59.146;ftag=c3709051a39f4a89aeb982e90ac3966b;lr=on>
Jan 4 17:39:07 DEBUG[22457]: chan_sip.c:4646 build_route: build_route: Record-Route hop: <sip:84.163.31.82:20166;lr=on>
Jan 4 17:39:07 DEBUG[22457]: chan_sip.c:4671 build_route: build_route: Contact hop: <sip:
[email protected]:20166>
-- Executing System("SIP/freenet.de-0816e000", "echo "04012006-17:39:07: "michaelxyxy" <michaelxyxy> rief an." | mail -s VOIP-Anrufbenachrichtigung mail@... ") in new stack
-- Executing GotoIfTime("SIP/freenet.de-0816e000", "23:50-7:00|mon-thu|*?7") in new stack
-- Executing GotoIfTime("SIP/freenet.de-0816e000", "00:30-7:00|fri-sat|*?7") in new stack
-- Executing GotoIfTime("SIP/freenet.de-0816e000", "23:30-7:00|sun|*?7") in new stack
-- Executing Dial("SIP/freenet.de-0816e000", "Zap/g1/3527737|60|tTr") in new stack
Jan 4 17:39:07 DEBUG[22457]: app_dial.c:519 dial_exec: SIMPLE DIAL (NO URL)
-- Requested transfer capability: 0x00 - SPEECH
-- Called g1/3527737
Jan 4 17:39:08 DEBUG[22457]: chan_zap.c:8382 pri_dchannel: Queuing frame from PRI_EVENT_PROCEEDING on channel 0/1 span 1
-- Zap/1-1 is making progress passing it to SIP/freenet.de-0816e000
Jan 4 17:39:08 DEBUG[22457]: app_dial.c:367 wait_for_answer: Dunno what to do with control type 15
-- Zap/1-1 is ringing
Jan 4 17:39:12 DEBUG[22457]: chan_zap.c:2680 zt_setoption: Set option AUDIO MODE, value: ON(1) on Zap/1-1
Jan 4 17:39:12 DEBUG[22457]: chan_zap.c:2178 zt_hangup: Hangup: channel: 1 index = 0, normal = 18, callwait = -1, thirdcall = -1
Jan 4 17:39:12 DEBUG[22457]: chan_zap.c:2315 zt_hangup: Not yet hungup... Calling hangup once with icause, and clearing call
Jan 4 17:39:12 DEBUG[22457]: chan_zap.c:1421 zt_disable_ec: disabled echo cancellation on channel 1
Jan 4 17:39:12 DEBUG[22457]: chan_zap.c:2592 zt_setoption: Set option TDD MODE, value: OFF(0) on Zap/1-1
Jan 4 17:39:12 DEBUG[22457]: chan_zap.c:1360 update_conf: Updated conferencing on 1, with 0 conference users
Jan 4 17:39:12 DEBUG[22457]: chan_zap.c:2674 zt_setoption: Set option AUDIO MODE, value: OFF(0) on Zap/1-1
-- Hungup 'Zap/1-1'
Jan 4 17:39:12 DEBUG[22457]: app_dial.c:1072 dial_exec: Exiting with DIALSTATUS=CANCEL.
== Spawn extension (pbx-trunk, 3527737, 5) exited non-zero on 'SIP/freenet.de-0816e000'
Jan 4 17:39:12 DEBUG[22457]: chan_sip.c:7851 sipsock_read: Failed to grab lock, trying again...
Jan 4 17:39:12 DEBUG[22457]: cdr_addon_mysql.c:178 mysql_log: cdr_mysql: inserting a CDR record.
Jan 4 17:39:12 DEBUG[22457]: cdr_addon_mysql.c:197 mysql_log: cdr_mysql: SQL command as follows: INSERT INTO cdr (calldate,clid,src,dst,dcontext,channel,dstchannel,lastapp,lastdata,duration,billsec,disposition,amaflags,accountcode) VALUES ('2006-01-04 17:39:07','\"michaelxyxy\" <michaelxyxy>','michaelxyxy','3527737','pbx-trunk', 'SIP/freenet.de-0816e000','Zap/1-1','Dial','Zap/g1/3527737|60|tTr',5,0,'NO ANSWER',3,'')
Jan 4 17:39:12 DEBUG[22457]: chan_sip.c:1728 sip_hangup: update_user_counter() - decrement inUse counter
Jan 4 17:39:12 DEBUG[22457]: chan_sip.c:1597 update_user_counter: is not a local user
Jan 4 17:39:12 DEBUG[22457]: chan_sip.c:842 __sip_ack: Stopping retransmission on '
[email protected]' of Response 2: Found
