[HowTo] MESH connection via LAN but transfer to DECT phones?
alexl7
24 Jun 2006
Hallo!
I use Mesh 7590 -> 7490, I noticed that there is no DECT switching from master to repeater, I read the instructions ....
  • Der Mesh Repeater fungiert nichtals DECT-Repeater. Es ist daher nicht möglich, aus dem DECT-Bereich des Mesh Masters in den Bereich des Mesh Repeaters zu wechseln oder umgekehrt.
    Hinweis:Sie können ein Schnurlostelefon aber an beiden FRITZ!Boxen anmelden und bei Bedarf manuell die gewünschte Basisstation auswählen. Falls Sie einen DECT-Repeater benötigen, können Sie stattdessen z.B. den FRITZ!DECT Repeater 100 einsetzen.
and realized that this is not implemented with DECT phones, it turns out that to switch you need to additionally use FRITZ! DECT Repeater 100, it’s strange that AVM Haven’t implemented this feature for DECT or are there other solutions on how to switch a DECT phone to a repeater (7490)?
It's strange that there is a menu for this in the settings
Danke!
You can use DECT-Phones in both areas, but there is no automatic handover between this areas.
Yes, I read the instructions, but there are difficulties when dialing outgoing numbers within the network and also with some incoming numbers
In any case, roaming between two Fritz!boxes is not well thought out since you have to enter additional prefixes to dial internal numbers
wolle 610
