Mod for no rings on Festnetz anonymous calls, is it possible?
zooster
4 Jan 2006
With the new firm for 7050 there is the possibility to reject anonymous calls. But for several reason this is no good for me.
I'm lookin for a way to do not have rings. But I don't wanna refuse the call, instead I want phones NOT ringing if the Festnetz call is anonymous.
Is it possible to add a mod in the pseudo image?
Maybe this could work:
Just check it out and give feedback please.
Joe
Great! It worked, but the number 9 didn't work, it forwared the call somewhere else, so there was an answer to the call. Instead I had to put the same number as my festnetz number and now it doesn't ring and no answer/forward anymore.
Thank you.
Redirecting the call to its incoming number is a very easy and stupid simple way to present a buys tone to the caller! :dance:
Die Lösung mit dem Rückwärtsverweis auf die eingehende Festnetznummer (was ja zu einem Belegt-Zeichen führt) ist genau so einfach wie genial! :dance:
@admin:
Diesen Thread bitte schliessen und nach "Telefonie" verlegen.
Joe
There is a problem, this good trick works with every call! I wanted it to work only on anonymous incoming landline calls, but in this way it works also on sip incoming calls.....
Midares
