Mod js
kandy
19 Feb 2005
Someone knows if is possble and how to change the file val.js that is on the directory /usr/www/html/js
Thank you
Hi kandy,
(Solution only for "Linux" users... )
the filesystem of the fritzbox is a "read only" squashfs. A way to modify and prepare
own changes can be found at: http://www.akk.org/~enrik/fbox/buildroot-fbox.tar.bz2
It's a complete build environment for binaries.
Another way is to modify the firmware by some scripts without building own binaries.
See the download file at http://www.ip-phone-forum.de/forum/viewtopic.php?t=6666
- unpack the tar file "mod-0.53.tar.gz"
- prepare fritbox_mod.6 to set the type to "ATA" for your box
- run ./fritzbox_mod <path/file of ata-image> <your image name>
You should get a ready to use image.
You might change the fritzbox_mod.* scripts to implement your changes.
Unfortunately most of the documentation is not in English and just designed
for Linux/UNIX enhanced user.
Best regards,
Haveaniceday
benschkenobi
