MOH geht nicht
trepper
25 Jun 2005
Hi all,
hab den Asterisk 1.0.9 auf FC4 laufen und es geht kein MOH. Hab die Soundkarte nachinstalliert, d.h. im BIOS ge-enabled und ich kann Musik hören, wenn ich mpg321 von der Console starte, nur MOH geht nicht.
musiconhold.conf
; Music on hold class definitions
[classes]
;default => quietmp3:/var/lib/asterisk/mohmp3
default => mp3:/var/lib/asterisk/mohmp3
;loud => mp3:/var/lib/asterisk/mohmp3
;random => quietmp3:/var/lib/asterisk/mohmp3,-z
;unbuffered => mp3nb:/var/lib/asterisk/mohmp3
;quietunbuf => quietmp3nb:/var/lib/asterisk/mohmp3
; Note that the custom mode cannot handle escaped parameters (specifically embedded spaces)
;manual => custom:/var/lib/asterisk/mohmp3,/usr/bin/mpg123 -q -r 8000 -f 8192 -b 2048 --mono -s
modules.conf
; Asterisk configuration file
; Module Loader configuration file
[modules]
autoload=yes
; If you want, load the GTK console right away.
; Don't load the KDE console since
; it's not as sophisticated right now.
noload => pbx_gtkconsole.so
;load => pbx_gtkconsole.so
noload => pbx_kdeconsole.so
; Intercom application is obsoleted by
; chan_oss.  Don't load it.
noload => app_intercom.so
; Explicitly load the chan_modem.so early on to be sure
; it loads before any of the chan_modem_* 's afte rit
load => chan_modem.so
load => res_musiconhold.so
; Load either OSS or ALSA, not both
; By default, load OSS only (automatically) and do not load ALSA
noload => chan_alsa.so
;noload => chan_oss.so
; Module names listed in "global" section will have symbols globally
; exported to modules loaded after them.
[global]
chan_modem.so=yes
asterisk-console
[root@legolas ~]# asterisk -vvvvvvvvvvvvvvvvr
  == Parsing '/etc/asterisk/asterisk.conf': Found
  == Parsing '/etc/asterisk/extconfig.conf': Found
Asterisk 1.0.9, Copyright (C) 1999-2004 Digium.
Written by Mark Spencer <[email protected]>
Connected to Asterisk 1.0.9 currently running on legolas (pid = 2826)
Verbosity was 3 and is now 16
    -- Remote UNIX connection
    -- Executing Dial("SIP/600-0411", "SIP/400|60") in new stack
    -- Called 400
    -- SIP/400-98cd is ringing
    -- SIP/400-98cd answered SIP/600-0411
    -- Attempting native bridge of SIP/600-0411 and SIP/400-98cd
    -- Started music on hold, class 'default', on SIP/600-0411
    -- Stopped music on hold on SIP/600-0411
  == Spawn extension (TomCisco, 400, 1) exited non-zero on 'SIP/600-0411'
legolas*CLI>
hab schon alles ausprobiert, aber keine Idee. Da ich Musik von mpg321 an der Soundkarte hören kann, denke ich, das das passt und das Problem irgendwo beim Asterisk liegt.
Da in dem RPM kein mp3 war, hab ich mir eins runtergesaugt und es in den mohmp3-ordner kopiert.
Hat jemand von Euch eine Idee, was ich falsch gemacht habe oder ggf. vergessen habe?
Herzlichen Dank
Thomas
Hast Du auch "mpg123" installiert? Kannst Du damit auch musik abspielen. Irgendwo habe ich mal gelesen, dass einige Linux-Dists nicht wirklich mpg123 installieren, sondern nur einen Link auf mgp321 setzen. Kanst Du das ausschliessen? Wenn Du Asterisk gestartet hast, und "ps -A" in dei Linux-Konsole eintippst, dann sollte (mindestens) ein Prozess manes "mpg123" da sein. Ist das so?Sonst problier mal mit mpg123 was auf Deiner Soundkarte auszugeben.
Hi Hupe,
hab ich gemacht:
2847 ? 00:00:00 mpg123
Daran denke ich, kann es nicht liegen. Ich kann mp3s hören, wenn ich es von der Console aus starte...
Hab nur keine Idee mehr, woran es liegen könnte...
Mmmmh, hat denn keiner eine Idee? Ich kann ja Musik hören, wenn ich mpg321 im command starte, dann höre ich etwas durch den Kopfhörer.
Kann es daran liegen, das ich die Soundkarte nachträglich installiert habe?
Muß ich den * erneut installieren?
Mit der Soundkarte dürfte das nix zu tun haben. In meinem rechner ist garkeine (Soundunterstützung im Bios deaktiviert, und keine Kernel-Unterstützung einkompiliert). Und MOH läuft bei mir auch.
Laut voip-info sollte man auch kein mgp321 installiert haben, da es wohl zu problemen führen kann.
Welche Version von mpg123 hast Du denn? Vielleicht ist sie estwas inkompatibel. Es sollte schon die Version v0.59r sein (http://www.mpg123.de/). Hättest Du Asterisk selber kompiliert, dann hätte man das wohl mit "make mgp123" automatisch downloaden und kompilieren können. Also schmeiss mal mpg321 runter und installiere die richtige Version von mpg123 (so Du sie nicht schon hast). Und das deinstallieren der alten Version nicht vergessen.
Hab das mpg321 entfernt, jetzt kommt so etwas:
res_musiconhold.c:309 monmp3thread: Request to schedule in the past?!?!
Ja, dann deinstalliere mal auchnoch mpg123. Dann das Source-Paket runterladen ( http://www.mpg123.de/ ) und selbiges kompilieren und installieren.
Das Problem mit eigenen MP3s ist das diese Eventuell ID3 Tags enthalten. Damit kann Asterisk nichts anfangen. Such mal nach dem Paket "id3ed", damit kann man ziemlich einfach alle ID3 Tags von einem MP3 entfernen.
Vielleicht liegts daran.
Ich habe ein sehr interessantes problem, welches hier glaub ganz gut rein passt.
Wenn der Rechenr auf dem der * läuft nicht ausgelastet ist, laeuft die musik on hold total verhackt.
wenn ich jetzt nebenher etwas compiliere, dann läuft sie absult sauber ;-)
Debian Sarge Kernel 2.6.10
hat eienr eine erklärung dafür ?
ich setzte die aktuelle mpg123 version ein
danke
bye
eazy
Hört sich nach einem Timing-Problem an. Aber ne richtige Erklärung dafür habe ich nicht.
Hast Du einen Timer für Asterisk? Du solltest es mal damit probieren. Das soll auch MOH in der Qualität verbessern. Bei mir sind dadurch die Hacker in der Musik verschwunden. Und da du Kernel 2.6 nutzt ist es auch kein Problem.
http://www.voip-info.org/wiki/index.php?page=Asterisk+timer+ztdummy
beetlesch
