neues chan_mISDN Release Version 0.0.3-rc5
thaeger
12 Jan 2005
Gibts da ne Doku für?
MfG,
Karl
Hallo Karl,
es ist ein Readme in dem tar-gz enthalten, was eigentlich das wichtigste beschreibt. Solltes Du nich damit klar kommen, dann schicke ich Dir gerne ein von mir erstellte Doku.
Grüße,
Thomas.
Kannst du die hier mal irgendwo reinpacken? Wäre nett. :-)
MfG,
karl
README von 0.3.0-rc5
mISDN Channel Driver for Asterisk PBX
This package contains the mISDN Channel Driver for the Asterisk PBX. It
supports every mISDN Hardware and provides an interface for asterisk.
Features:
* NT and TE mode
* PP and PMP mode
* DTMF Detection (for now with asterisk)
* Display Messages to Phones (which support display msg)
* HOLD/RETRIEVE/TRANSFER on ISDN Phones : )
* some other
Overview
- Pre-Requisites
- Compilation
- Installation
- Configuration
- Dial String
- misdn cli commands
- Debugging and sending Bugreports
- Examples
- Known working Configurations
- Known Problems
- Changes
Pre-Requisites
To compile and install this driver, you'll need at least one mISDN Driver, the
mISDNuser package and the asterisk includes (which will be inside of the
sources). For now I'll recommend you to use the v1-0.2_stable Release of the
asterisk sources, get it via cvs or by downloading it from
here:ftp://ftp.asterisk.org/pub/telephony.
To get the mISDN stuff please follow the instructions at
http://www.isdn4linux.de.  Please Note that mISDN works good for the
linux-2.6.x kernels. Some of the mISDN drivers do not compile against the
2.4.x or older kernels, you can patch them, but than you'll get myterius
errors.
I used Kernel 2.6.5 for a while, but there were lots of B-Channel Problems. Andreas (jolly) told me to use 2.6.3 and it really works better (there must be a patch in the Kconfig files so that the mISDN stuff apears at make menuconfig, the ISDN Flag must be ISDN_BOOL).
After getting up with mISDN, you can test your mISDN stuff by use of the jolly-PBX, get it at isdn.jolly.de. (Maybe you'll prefer this pbx against the asterisk :-) ).
Ok so far so good, now follow the compilation instructions.
!! Dont forget to create the /dev/mISDN device node.
Compilation
!! Be aware, in the actual mISDNuser package theres a bug in the Makefile
!! the compilation stops near iapplication.h, this isn't very important
!! at this step you are ready.
After you've successfully installed mISDN, mISDNuser and asterisk, you should
modify the Makefile in the chan_misdn source path. There you can tell the
Makefile where to install the driver, sample-conf, and most important where it
can find the linux kernel includes, the mISDNuser package and the asterisk
includes.  If you use the Head-Revision of Asterisk (or at least a newer
version than stable) uncomment the CCFLAGS+=-DASTERISK_STABLE, the stable
version of asterisk is at the moment v1-0 as cvs tag.
Now you can type in:
make
This should compile chan_misdn.so, if theres an error check the paths in the
Makefile again.
Installation
After successful compilation of chan_misdn, you should simply type in:
make install
as privileged user to put chan_misdn.so in the asterisk modules
directory.
You should see a Msg like: "Successfully installed chan_misdn".
Congratulations.
Theres a sample init.d script for loading the mISDN modules (mISDN.sample),
simply copy it to /etc/init.d/ and modify it, there you can enter your cards.
!! Forget to use capi together with chan_misdn.
Configuration
First of all you must configure the mISDN drivers. Each driver module has got
an options and layermask option, which tells the driver wether to start in
TE,NT, PP or PMP mode (there are lots more please read docs in misdn for
that).
After thinking about the above you'll probably want to configure the
misdn.conf file which resides in the asterisk-config directory.
The misdn.conf file contains a "general" Section, and user sections which
contain misdn port settings and different asterisk contexts.
The general section contains especially a variable named context with which
the default context is set. There is also the very important debug variable
which you can set from the asterisk cli (command line interface) or in this
configfile, bigger numbers will lead to more debug output. Theres also a
tracefile options, which takes a path+filename where debug output is written
to.
The user Sections have names which are unequal to "general". Those sections
contain the ports variable which mean the mISDN Ports. Here you can add
comma-sepperated multiple ports.
Espacially for TE-Mode Ports there is a msns variable. This variable tells the
chan_misdn driver to listen for incomming calls with the given msns, you can
insert a '*' as single msn, which leads in getting every incomming call (if
you want to share on PMP TE S0 with a asterisk and a phone or isdn card you
should insert here the msns which you'll like to give the asterisk).  Finally
a context variable resides in the user sections, which tells chan_misdn where
to send incomming calls to (extension.conf).
In NT-Mode Ports there is a new option, directly after the port number you can
write ptp, this enables PP Mode for this port, please look at misdn.conf for
an example.
When everything worked you should get the asterisk running.
Dial String
The Dialstring of chan_misdn got more complex, because we added more features,
so the generic dialstring looks like:
mISDN/<port>|g:<group>/<extension>[/:<optchar1><OptParam1>:<optchar1><OptParam1>:]
The available Optchars are:
	d - Send display text on called phone, text is the optparam
	n - don't detect dtmf tones on called channel
misdn cli commands
At the asterisk cli you can try to type in:
misdn <tab> <tab>
Now you should see the misdn cli commands:
- clean
	-> pid 		(cleans a broken call, use with care, leads often
			 to a segmentation fault)
- send
	-> display	(sends a Text Message to a asterisk channel,
			 this channel must be an misdn channel)
- set
	-> debug	(sets debug level)
- show
	-> config	(shows the configuration options)
	-> channels	(shows the current active misdn channels)
	-> stacks	(shows the currend ports, there protocols and states)
	-> fullstacks	(shows the current active and inactive misdn channels)
- reload 		(reloads misdn.conf)
You can only use "misdn send display" when a asterisk channel is created and
isdn is in the corect state, correct state means that you have established a
call to another phone (mustnt be isdn though).
Then you use it like this:
misdn send display mISDN/1/101 "Hello World!"
where 1 is the Port of the Card where the phone is plugged in, and 101 is the
msn (callerid) of the Phone to send the text to.
Debugging and sending Bug-Reports
If you encounter problems, you should set up the debugging flag, usually debug=1 should be enough. the Messages are divided in asterisk and misdn parts. Misdn Debug messages begin with an 'I', asterisk messages begin with an '*', the rest is clear I think.
Please take a trace of the problem and send this trace via mail to [email][email protected][/email]
Examples
here some examples of how to use chan_misdn in the dialplan (extensions.conf):
[globals]
OUT_PORT=1 ; The physical Port of the Card
OUT_GROUP=ExternE1 ; The Group of Ports defined in misdn.conf
[misdnIn]
exten => _X.,1,Dial(mISDN/${OUT_PORT}/${EXTEN})
exten => _0X.,1,Dial(mISDN/g:${OUT_GROUP}/${EXTEN:1})
exten => _1X.,1,Dial(mISDN/g:${OUT_GROUP}/${EXTEN:1}/:dHello)
exten => _1X.,1,Dial(mISDN/g:${OUT_GROUP}/${EXTEN:1}/:dHello Test:n)
In the last line you will notice the last argument (Hello), this is sended
as Display Message to the Phone.
In this Section I'll put working  configurations for chan_misdn. Beware It seems that between Kernel 2.6.3 and Kernel 2.6.8 there were lots of mISDN Bugs. Form me the Kernel 2.6.3 works very well, I'd like to update, but have no time to test out a Kernel 2.6.8 + .
- chan_misdn-0.0.3-rc1:
	* linux-kernel >= 2.6.3 (but at least 2.6)
	* asterisk >= v1-0
	* mISDN/mISDNuser since September/04
- chan_misdn-0.0.3-rc3:
	* asterisk >= v1-0.2
	* mISDN/mISDNuser since December/04
- chan_misdn-0.0.3-rc4:
	* linux-kernel >= 2.6.8 (but at least 2.6)
	* mISDN/mISDNuser head on cvs.isdn4linux.de
Known Problems
* When I use mISDN->IAX I cannot hear the other end, and or the other end
cannot hear me.
-> You need to use ztdummy as dummy zaptel interface for the iax timing in
trunkking mode, simply grab libpri, zaptel and compile them (i think you need
to modify the makefile in zaptel to add ztdummy to the defaultly compiled
modules) then modprobe ztdummy, this resolves the problem.
Changes
in the Changes File
Gruß,
Tucca
The requested URL was not found on this server
thaeger schrieb:
Das Dokument existiert nicht im angegebenen Pfad: Statt der PDF-Datei bekomme ich nur 311 Bytes zurück. Mit einem Texteditor betrachtet steht dort dann "The requested URL /download/card_install_handbook_preRelease.pdf was not found on this server."
Bitte nochmal einstellen. Danke!
Gruss,
Klaus
@ru
Nimm mal den hier : http://www.beronet.com/download/
Wählen müsstest Du selber...aber dafür nach freier Wahl :-)
@thaeger
Es sei ggf. erwähnt das dieses Update unstable ist und nur ab Asterisk v1.2 läuft...
Ich würde auch **liebend** gerne einmal vrnünftig updaten, da es in meiner mISDN Asterisk Version optisch hapert (kein misdn show channels ergibt mehr als "nil") - aber doch bitte eine stable version..
grüsse stefan
chan_misdn-0.3.0-rc15 is out
Inzwischen gibts die rc15. Die ist jedenfalls deutlich stabiler als die rc5.
Aber ich gehe recht in der Annahme das sie noch nicht als stable eingestuft ist?!
Grüsse,
Stefan
Das ist richtig, wir haben die Version im moment im beta-testbetrieb, bei ein paar friendly customern und auf unserer PBX.
Läuft in den Umgebungen schon recht stabil, aber es gibt auch bekannte Probleme, z.B. das Entladen der mISDN Kernelmodule führt ab und an zum kernel freeze.. aber das ist während des Betriebes nicht kritisch.
Für einen test ist es allerdings schon recht gut, hat vielle nette neue features :-D
Ist es eigentlich möglich eine härtere Echo Cancellation zu fahren ?
Ich habe den EC Mode (trained) an, auch bridged, mit einem Wert von 126(auch trained findet er immer 126), jedoch habe ich immernoch einen leisen Resthall, der auffällt wenn man einen Satz beendet (zB : [..]Dann tschüss noch.. (2x "och.."-Hall))
zu :
testet 0.3.0 damit es stable werden kann!
Tut mir leid, aber in meinem Fall hapert es daran das ich ein produktives System für meine Firma und kein "Hobbysystem" fahre, somit bin ich froh wenn ich stabile Komponenten fahre..ist denke ich verständlich.
Gibt es eigentlich offizielle Betateilnehmer(listen) ?
Beste Grüße,
Stefan
In 0.3.0 ist ein besserer EC enthalten, die asterisk Leute haben ja inzwischen den KB1 und den MG2 Cancellor, die deutlich besser sind als der alte Mark2 der auch in chan_misdn 0.2.x enthalten war.
mit der 0.3.0 ist automatisch der kb1 an und wir legen gerade den mg2 nach.
Zu den offiziellen Teilnehmerlisten: nein gibt es leider nicht, erfahrungsberichte findet man nur über die Interne quellen.
Es wäre in der tat eine gute idee so eine Seite aufzusetzen, vielleicht im voip-info.org wiki ? ich denke mal drüber nach.
mISDN-Liste
wäre vielleicht schon eine Rubrik hier im Forum ausschliesslich zu mISDN zielführender?
Just my 2 EuroCent
Gruß,
Klaus
moin,
... und als die rc12, die ich vorher hatte.
gibt zwar immer noch diese meldung recht haeufig bei datenverbindungen (X.75 transparent):
kernel: channel_senddata: next_skb exist ERROR (skb->len=64 next_skb->len=64)
aber bis jetzt schon relativ stabil ohne dass man die misdn-module komplett ent- und neuladen musste und asterisk restarten, wie noch mit der rc12 reproduzierbar ziemlich oft.
die verwendete hfc-karte ist eine pci intern fuer ~30 eur seinerzeit von der elektronikapotheke mit dem blauen "C" ( #955078 ).
mISDN-Liste
ru:
wie kann man denn eine Rubrik erstellen? Ich nehme an das kann nr der Board-Admin oder?
Danke!
Das ist auch meine Vermutung. Ich werde mal versuchen ihm eine PM mit dem ANliegen zukommen zu lassen. Vielleicht können andere, interessierte dies auch tun (damit es nicht nach einem Einzelwunsch aussieht).
Gruß,
Klaus
Gehe ich ganz stark von aus, versuchs Doch mal bei "rollo" (Admin)
Rubrik-Idee : Spitze!
Wiki-Idee : Mehr als nur genial!
Support-Seite(Anlaufstelle) bzw. verbesserte Homepage für mISDN : Der Oberknüller!
:wink: :wink: :wink:
Beste Grüße
Stefan
Edit 12:11 Uhr:
@Klaus
An wen genau schreibst Du , würde dies dann auch tun.
@mISDN Update - @crich
Ich bin etwas zögerlich mit dem Update auch aus einem weiteren Grund, die Installation von misdn seinerzeit war alles andere als prickelnd, der manuelle weg scheiterte immer wieder an anderen hürden, wobei die beronet automatic-installation reibungslos lief, bei einem update gehe ich wie vor .. ?
Beste Grüße,
Stefan
Hinweis von Christoph: Bitte die Funktion "Ändern" beachten, um aufeinanderfolgende Beiträge zu vermeiden.
HobbyStern:
Die manuelle Installation war recht umständlich, inzwischen haben wir direkten Zugriff auf den mISDN CVS Server und haben auch die manuelle Installation vereinfacht.
Jedenfalls haben wir ein neues automatisches Installscript gebastelt, gibts unter:
www.beronet.com/downloads/install-misdn-mqueue.tar.gz
ausserdem gibt es bereits eine Wiki Seite im voip-info.org Wiki:
www.voip-info.org/wiki/view/chan_misdn
das versuchen wir immer Up-To-date zu halten.
tempuser777
