[Problem] no remote access
binary_dreamer
24 Jul 2009
hello everyone. i have a 7270 v3 with FRITZ!OS 05.53. I am using it for more than a year and i am happy with that. All of sudden 10 days ago started a problem that i cannot figure how to solve it.
i cannot have remote access to the router from the internet. i get the following error:
Server has a weak ephemeral Diffie-Hellman public key
This is in opera, explorer, chrome and firefox.
There in not a button to bypass the problem such as proceed anyway and i cannot access the router.
Is there a way to fix this issue?
The old international firmware has only support for long-time outdated SSL methods (RC4-MD5, RC4-SHA1). Are you sure, you want to continue using a really really weak connection to this box? If the answer is "yes", you have to use an older client (browser) to do so ... all newer (main-stream) browsers have dropped their support for the needed methods meanwhile.
hi. thanks for the reply. Is there a newer international firmware for 7270 v3? as i cannot find anything
No, there's yet no newer firmware for these rather old devices.
najsai
