Nokia 6300 i und Carpo VOIP?
rolandmerz
22 Mai 2009
Bin nach mehreren Stunden probieren entnervt:
Carpo VOIP für Nokia 6300i mittels carpo.prov -Datei läuft nicht (s. unten).
Es kommt die Fehlermeldung LOGIN FALSCH
Hat jemand in diesem wirklich tollen Forum eine Lösung, wo der Fehler liegt ?
Vielen Dank
carpo.prov -Datei:
<?xml version="1.0"?>
<!DOCTYPE wap-provisioningdoc PUBLIC "-//WAPFORUM//DTD PROV 1.0//EN" "http://www.wapforum.org/DTD/prov.dtd">
<wap-provisioningdoc version="1.1">
<!-- XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-->
<characteristic type="BOOTSTRAP">
<parm name="NAME" value="Carpo_Roland"/>
</characteristic>
<!-- Nokia S40 v72 VoIP settings, w9013 -->
<characteristic type="APPLICATION">
<parm name="APPID" value="w9013"/>
<parm name="PROVIDER-ID" value="Carpo_Roland"/>
<parm name="TO-NAPID" value="VoIP_WLAN_settings"/>
<parm name="TO-NAPID" value="INTERNET"/>
<parm name="TO-APPREF" value="VoIP_SIP_settings"/>
<parm name="SMPORT" value="16384"/>
<parm name="EMPORT" value="32766"/>
<parm name="MEDIAQOS" value="46"/>
<parm name="SECURECALLPREF" value="0"/>
<parm name="RTCP" value="0"/>
<parm name="MOMAXALERT" value="45"/>
<parm name="MTMAXALERT" value="30"/>
<!-- AMR NB -->
<characteristic type="CODEC">
<parm name="MEDIASUBTYPE" value="0"/>
<parm name="PRIORITYINDEX" value="0"/>
<parm name="OCTET-ALIGN"/>
<parm name="VAD"/>
</characteristic>
<!-- G.729 with default values -->
<parm name="MEDIASUBTYPE" value="10"/>
<parm name="PRIORITYINDEX" value="1"/>
<parm name="ANNEXB"/>
</characteristic>
<!-- G711 a-law with default values -->
<parm name="MEDIASUBTYPE" value="3"/>
<parm name="PRIORITYINDEX" value="2"/>
<parm name="VAD"/>
</characteristic>
<!-- G711 u-law with default values -->
<parm name="MEDIASUBTYPE" value="4"/>
<parm name="PRIORITYINDEX" value="3"/>
<parm name="VAD"/>
</characteristic>
<!-- G.726-40 with default values -->
<parm name="MEDIASUBTYPE" value="5"/>
<parm name="PRIORITYINDEX" value="4"/>
<parm name="VAD"/>
</characteristic>
<!-- G.726-32 with default values -->
<parm name="MEDIASUBTYPE" value="6"/>
<parm name="PRIORITYINDEX" value="5"/>
<parm name="VAD"/>
</characteristic>
<!-- G.726-24 with default values -->
<parm name="MEDIASUBTYPE" value="7"/>
<parm name="PRIORITYINDEX" value="6"/>
<parm name="VAD"/>
</characteristic>
<!-- G.726-16 with default values -->
<parm name="MEDIASUBTYPE" value="8"/>
<parm name="PRIORITYINDEX" value="7"/>
<parm name="VAD"/>
</characteristic>
<!-- CN Comfort noise with default values -->
<parm name="MEDIASUBTYPE" value="9"/>
<parm name="PRIORITYINDEX" value="8"/>
</characteristic>
<!-- IP Voice mail -->
<characteristic type="VOIPURIS">
<!-- Link to SIP settings -->
<parm name="IPVOICEMAILBOXURI" value=""/>
</characteristic>
</characteristic>
<!-- NAT/FW settings, w902E -->
<parm name="APPID" value="w902E"/>
<parm name="NAME" value="NAT/FW Traversal settings"/>
<characteristic type="NW">
<parm name="APPREF" value="Example_NAT_FW_settings"/>
<parm name="DOMAIN" value="carpo.de"/>
<parm name="STUNSRVADDR" value="stun.carpo.de"/>
<parm name="STUNSRVPORT" value="3478"/>
<parm name="NATREFRESHTCP" value="30"/>
<parm name="NATREFRESHUDP" value="20"/>
</characteristic>
<characteristic type="NATIAP">
<parm name="REFRESHTCP" value="1200"/>
<parm name="REFRESHUDP" value="28"/>
<parm name="STUNRETRANSMIT" value="250"/>
</characteristic>
</characteristic>
<!-- SIP settings, w9010 -->
<parm name="APPID" value="w9010"/>
<parm name="APPREF" value="VoIP_SIP_settings"/>
<parm name="PROVIDER-ID" value="Carpo"/>
<parm name="PTYPE" value="IETF"/>
<parm name="PUID" value="sip:[email protected]"/>
<parm name="APROTOCOL" value="UDP" />
<!-- Outbound settings -->
<characteristic type="APPADDR">
<parm name="LR"/>
<parm name="ADDR" value="sip.carpo.de"/>
<characteristic type="PORT">
<parm name="PORTNBR" value="5060" />
</characteristic>
</characteristic>
<!-- Outbound credentials -->
<characteristic type="APPAUTH">
<parm name="AAUTHNAME" value="benutzername"/>
<parm name="AAUTHSECRET" value="passwort"/>
<parm name="AAUTHDATA" value="carpo.de"/>
<parm name="AAUTHTYPE" value="HTTP-DIGEST" />
</characteristic>
<!-- Registrar location and credentials -->
<characteristic type="RESOURCE">
<parm name="URI" value="sip.carpo.de"/>
</characteristic>
</characteristic>
<!-- IAP WLAN settings -->
<characteristic type="NAPDEF">
<parm name="NAME" value="WLAN"/>
<parm name="NAPID" value="VoIP_WLAN_settings"/>
<parm name="BEARER" value="WLAN"/>
<characteristic type="WLAN">
<parm name="PRI-SSID" value="Priv"/>
<parm name="NETMODE" value="INFRA"/>
</characteristic>
</characteristic>
</wap-provisioningdoc>
