offtopic: squid/2.6.STABLE18 fli4l.3.x.x
squid 2.6.STABLE17:
Changes to squid-2.6.STABLE17 (26 Nov 2007)
	- Fix compile error with old GCC 2.x or other ANSI-C compilers before
	  C99
	- Mention the login= cache_peer option in release notes
	- Fix bad cache_peer example in squid.conf
	- Bug #2086: Fix a compile-time memory corruption error causing cf_gen
	  to fail
	- Bug #2048: Clarify high_memory_warning usage
	- Reject DNS responses which result in no data
	- Fix version number in configuration manual
	- Move cache and request/reply_header_max_size to their proper
	  sections
	- Bug #2088: sbrk statistics broken when process size >2GB
	- Move logopen() much earlier to have fatal startup errors sent to the
	  proper syslog facility
	- Fix HTTP/0.9 responses
	- Correct bad example config for tos_outgoing_tos
	- Fix grammar in description of mail_program squid.conf option
	- Ignore Content-Length in chunked responses instead of rejecting the
	  response as invalid
	- Documented that http_port no longer have a default
	- Cleanup of cache digest documentation
	- Make aufs store rebuilding back off a little if I/O load too high
	- Bug #2100: Respect DNS ttl=0
	- Update udp_(incoming|outgoing)_address documentation to reflect
	  current bahaviour.
	- Update HTCP documentation
	- Document the overlapping helper request format
	- Change priority of proxy auth and extacl provided username in
	  login=*:pass
	- pack header entries on cache updates
	- Make squid_db_auth reopen the database connection on each query by
	  default
	- Improve helper debug ouput, including the channel number
	- Update cachePeerEntry MIB description to mention what is used as
	  index key
	- Import squid_radius_auth for authenticating to RADIUS
squid 2.6.STABLE18:
2008/01/09 14:36:37	hno	+5 -5	 	This is STABLE18, not 16..
2008/01/09 14:20:58	hno	+0 -41		Remove HEAD ChangeLog entries copied by mistake
2008/01/09 14:20:08	hno	+90 -8		Preparing for 2.6.STABLE18
2008/01/09 13:58:12	hno	+22 -15		MFC: Bug #2175: Update valgrind support for valgrind-3.3.0
2008/01/09 13:02:07	adrian	+2 -2		Sometimes arrayShrink() will be asked to shrink by 0 entries. Handle that.
2008/01/02 17:07:26	hno	+11 -16		MFC: Digest authentication fixes
2008/01/02 17:06:50	hno	+10 -8		MFC: Minor cleanups to make some 64-bit platforms happier
2008/01/02 16:29:22	hno	+429 -194		MFC: Novell eDirectory digest helper edir_digest_auth update to clean up license
2008/01/02 16:20:20	wessels	+1 -1		MFC: Change old [email protected] contact address to [email protected]
2008/01/02 16:15:47	serassio	+321 -321		MFC: Convert spnegohelp.h and spnegohelp.c files drom DOS to Unix text format.
2007/12/21 09:56:53	adrian	+3 -2		Bug #2156: Fix bug in header array compression (SQUID-2007:2)
Duggy
