Wed Dec 8 13:58:25 2010: MANAGEMENT: CMD 'state on'
Wed Dec 8 13:58:25 2010: MANAGEMENT: CMD 'hold release'
Wed Dec 8 13:58:25 2010: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Wed Dec 8 13:58:25 2010: Static Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Wed Dec 8 13:58:25 2010: Static Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Dec 8 13:58:25 2010: Static Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Wed Dec 8 13:58:25 2010: Static Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Dec 8 13:58:25 2010: MANAGEMENT: >STATE:1291813105,RESOLVE,,,
Wed Dec 8 13:58:26 2010: ROUTE default_gateway=192.168.178.1
Wed Dec 8 13:58:26 2010: TUN/TAP device /dev/tun0 opened
Wed Dec 8 13:58:26 2010: MANAGEMENT: >STATE:1291813106,ASSIGN_IP,,192.168.200.2,
Wed Dec 8 13:58:26 2010: /sbin/ifconfig tun0 delete
Wed Dec 8 13:58:26 2010: NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
Wed Dec 8 13:58:26 2010: /sbin/ifconfig tun0 192.168.200.2 192.168.200.1 mtu 1500 netmask 255.255.255.255 up
Wed Dec 8 13:58:26 2010: /Applications/Viscosity.app/Contents/Resources/dnsup.py tun0 1500 1544 192.168.200.2 192.168.200.1 init
Wed Dec 8 13:58:26 2010: MANAGEMENT: >STATE:1291813106,ADD_ROUTES,,,
Wed Dec 8 13:58:26 2010: WARNING: potential route subnet conflict between local LAN [192.168.178.0/255.255.255.0] and remote VPN [192.168.178.0/255.255.255.0]
Wed Dec 8 13:58:26 2010: /sbin/route add -net 192.168.178.0 192.168.200.1 255.255.255.0
Wed Dec 8 13:58:26 2010: Data Channel MTU parms [ L:1544 D:1450 EF:44 EB:4 ET:0 EL:0 ]
Wed Dec 8 13:58:26 2010: Local Options hash (VER=V4): '1db64539'
Wed Dec 8 13:58:26 2010: Expected Remote Options hash (VER=V4): '27d76c6d'
Wed Dec 8 13:58:26 2010: Socket Buffers: R=[42080->65536] S=[9216->65536]
Wed Dec 8 13:58:26 2010: UDPv4 link local: [undef]
Wed Dec 8 13:58:26 2010: UDPv4 link remote: 77.182.132.146:1194
Wed Dec 8 13:58:26 2010: MANAGEMENT: CMD 'hold release'
