OutFragmentWhenVoIP Fehlermeldungen bei Telnet-Login
astefan
11 Dez 2004
wenn ich mich auf meiner 7050 mit Telnet einlogge, bekomme ich neuerdings als erstes folgende Zeilen angezeigt:
2005-06-12 16:54:47 unknown: /var/flash/ar7.cfg:135: member OutFragmentWhenVoIP not found in ST_struct DPCFG_config
2005-06-12 16:54:47 unknown: /var/flash/ar7.cfg:135: member OutFragmentWhenVoIP not in DPCFG_config, try to recover
2005-06-12 16:54:47 unknown: /var/flash/ar7.cfg:517: member OutFragmentWhenVoIP not found in ST_struct DPCFG_config
2005-06-12 16:54:47 unknown: /var/flash/ar7.cfg:517: member OutFragmentWhenVoIP not in DPCFG_config, try to recover
2005-06-12 16:54:47 unknown: /var/flash/ar7.cfg:576: member OutFragmentWhenVoIP not found in ST_struct DPCFG_config
2005-06-12 16:54:47 unknown: /var/flash/ar7.cfg:576: member OutFragmentWhenVoIP not in DPCFG_config, try to recover
2005-06-12 16:54:47 unknown: load_config(ar7): warning: converted
Keine Ahnung was er mir damit sagen möchte, aber eigentlich bilde ich mir ein, dass meine Box funktioniert... Anbei für die Profis hier meine ar7.cfg:
 * /var/flash/ar7.cfg
 * Sun Sep  8 14:05:30 2002
ar7cfg {
        mode = dsldmode_full_bridge;
        tsdisabled = no;
        igddenabled = yes;
        igdd_control_enabled = no;
        wan_bridge_with_dhcpc = yes;
        wan_bridge_gateway = 192.168.0.1;
        dhcpc_use_static_dns = no;
        ethmode = ethmode_bridge;
        ethinterfaces {
                name = "eth0";
                dhcp = yes;
                ipaddr = 192.168.178.1;
                netmask = 255.255.255.0;
                dstipaddr = 0.0.0.0;
                dhcpenabled = no;
                dhcpstart = 0.0.0.0;
                dhcpend = 0.0.0.0;
                name = "eth0:0";
                dhcp = no;
                ipaddr = 192.168.178.254;
                dhcpenabled = yes;
                dhcpend = 0.0.0.0;
                name = "eth1";
                dhcp = no;
                ipaddr = 192.168.181.1;
                dhcpenabled = yes;
                dhcpend = 0.0.0.0;
                name = "usbrndis";
                dhcp = no;
                ipaddr = 192.168.179.1;
                dhcpenabled = no;
                dhcpend = 0.0.0.0;
                name = "tiwlan0";
                dhcp = no;
                ipaddr = 192.168.182.1;
                dhcpenabled = no;
                dhcpend = 0.0.0.0;
        brinterfaces {
                name = "lan";
                dhcp = yes;
                interfaces = "eth0", "usbrndis", "eth1", "tiwlan0";
                dhcpenabled = no;
                dhcpend = 0.0.0.0;
                name = "lan:0";
                dhcp = no;
                dhcpenabled = yes;
                dhcpend = 0.0.0.0;
        dslinterface {
                name = "dsl";
                dhcp = no;
                netmask = 255.255.255.255;
                dstipaddr = 192.168.179.1;
                dhcpenabled = yes;
                dhcpend = 0.0.0.0;
        dslinterface_metric = 2;
        pppoefw {
                interfaces = "usbrndis", "eth0", "eth1", "tiwlan0";
                nofirewall = yes;
                ipnetbiosfilter = yes;
                dnsfilter_for_active_directory = yes;
                hostuniq_filter = "";
                dpconfig {
                        security = dpsec_host;
                        lowinput {
                                policy = "reject";
                                accesslist =
                                             "permit ip any any connection outgoing-related",
                                             "permit ip any any connection incoming-related",
                                             "permit icmp any any";
                        lowoutput {
                                policy = "permit";
                        highinput {
                                policy = "permit";
                        highoutput {
                                policy = "permit";
                                accesslist =
                                             "reject ip any 242.0.0.0 255.0.0.0",
                                             "deny ip any host 255.255.255.255",
                                             "reject ip any 10.0.0.0 255.0.0.0",
                                             "reject ip any 169.254.0.0 255.255.0.0",
                                             "reject udp any any eq 135",
                                             "reject tcp any any eq 135",
                                             "reject udp any any range 137 139",
                                             "reject tcp any any range 137 139",
                                             "reject udp any any range 161 162",
                                             "reject udp any any eq 520",
                                             "reject udp any any eq 111",
                                             "reject udp any any eq 22289",
                                             "reject udp any any eq 1710",
                                             "reject udp any any eq 1048",
                                             "reject udp any any eq 158",
                                             "reject udp any any eq 515",
                                             "reject icmp any 149.1.1.0 255.255.255.0",
                                             "reject tcp any host 202.106.185.127 eq 25";
                        OutFragmentWhenVoIP = 0;
        dslconfig {
                autodetect = yes;
                templates {
                        VPI = 1;
                        VCI = 32;
                        manu = 0;
                        encap = dslencap_pppoe;
                        VPI = 8;
                        VCI = 35;
                        manu = 0;
                        VPI = 8;
                        VCI = 48;
                        manu = 0;
                        encap = dslencap_pppoa;
                        VPI = 8;
                        VCI = 48;
                        manu = 0;
                        encap = dslencap_pppoa_llc;
                        VPI = 8;
                        VCI = 67;
                        manu = 0;
                        VPI = 8;
                        VCI = 67;
                        manu = 0;
                        VPI = 8;
                        VCI = 64;
                        manu = 0;
                        VPI = 8;
                        VCI = 36;
                        manu = 0;
                        VPI = 0;
                        VCI = 35;
                        manu = 0;
                        VPI = 0;
                        VCI = 35;
                        manu = 0;
                        VPI = 9;
                        VCI = 35;
                        manu = 0;
                        VPI = 0;
                        VCI = 32;
                        manu = 0;
                        VPI = 0;
                        VCI = 32;
                        manu = 0;
                        VPI = 0;
                        VCI = 32;
                        manu = 0;
                        VPI = 0;
                        VCI = 34;
                        manu = 0;
                        VPI = 0;
                        VCI = 34;
                        manu = 0;
                        VPI = 0;
                        VCI = 34;
                        manu = 0;
                        VPI = 0;
                        VCI = 30;
                        manu = 0;
                        VPI = 8;
                        VCI = 32;
                        manu = 0;
                        VPI = 8;
                        VCI = 32;
                        manu = 0;
                        VPI = 8;
                        VCI = 32;
                        manu = 0;
                        VPI = 0;
                        VCI = 38;
                        manu = 0;
                        VPI = 0;
                        VCI = 38;
                        manu = 0;
                        VPI = 8;
                        VCI = 35;
                        manu = 0;
                        VPI = 8;
                        VCI = 35;
                        manu = 0;
                        VPI = 0;
                        VCI = 81;
                        manu = 0;
                        VPI = 0;
                        VCI = 81;
                        manu = 0;
                        VPI = 0;
                        VCI = 81;
                        manu = 0;
                        VPI = 8;
                        VCI = 81;
                        manu = 0;
                        VPI = 8;
                        VCI = 81;
                        manu = 0;
                        VPI = 8;
                        VCI = 81;
                        manu = 0;
                        VPI = 0;
                        VCI = 100;
                        manu = 0;
                        VPI = 0;
                        VCI = 100;
                        manu = 0;
                        VPI = 0;
                        VCI = 100;
                        manu = 0;
                VPI = 1;
                VCI = 32;
                dsl_encap = dslencap_pppoe;
                connect_delay_when_synced = 3s;
                speed_in_netto = 1024;
                speed_out_netto = 128;
                etherencapcfg {
                        use_dhcp = yes;
                        ipaddr = 0.0.0.0;
                        netmask = 0.0.0.0;
                        gateway = 0.0.0.0;
                        dns1 = 0.0.0.0;
                        dns2 = 0.0.0.0;
        default_dsliface {
                ppptarget = "internet";
                stay_always_online = no;
                redial_delay_after_auth_failure = 1m;
                redial_limit = 3;
                redial_after_limit_reached = 1h;
                username_prefix_after_auth_failure = "";
                dsldpconfig {
                        security = dpsec_firewall;
                        lowinput {
                                policy = "permit";
                                accesslist =
                                             "deny ip any 242.0.0.0 255.0.0.0",
                                             "deny udp any any eq 135",
                                             "deny tcp any any eq 135",
                                             "deny udp any any range 137 139",
                                             "deny tcp any any range 137 139",
                                             "deny udp any any range 161 162",
                                             "deny udp any any eq 520",
                                             "deny udp any any eq 111",
                                             "deny udp any any eq 22289",
                                             "deny udp any any eq 1710",
                                             "deny udp any any eq 1048",
                                             "deny udp any any eq 158",
                                             "deny udp any any eq 515";
                        lowoutput {
                                policy = "permit";
                        highinput {
                                policy = "permit";
                        highoutput {
                                policy = "permit";
                                accesslist =
                        forwardrules = "tcp 0.0.0.0:0 0.0.0.0:0 1 out",
                                       "udp 0.0.0.0:0 0.0.0.0:0 1 out",
                                       "udp 0.0.0.0:5060 0.0.0.0:5060",
                                       "udp 0.0.0.0:7078 0.0.0.0:7078",
                                       "udp 0.0.0.0:7079 0.0.0.0:7079",
                                       "udp 0.0.0.0:7080 0.0.0.0:7080",
                                       "udp 0.0.0.0:7081 0.0.0.0:7081",
                                       "udp 0.0.0.0:7082 0.0.0.0:7082",
                                       "udp 0.0.0.0:7083 0.0.0.0:7083",
                                       "udp 0.0.0.0:7084 0.0.0.0:7084",
                                       "udp 0.0.0.0:7085 0.0.0.0:7085",
                                       "# tcp 0.0.0.0:21 192.168.178.20:21 0 # FTP-Server",
                                       "# tcp 0.0.0.0:80 192.168.178.20:80 0 # HTTP-Server",
                                       "# tcp 0.0.0.0:4662 192.168.178.20:4662 0 # eMule",
                                       "# udp 0.0.0.0:4672 192.168.178.20:4672 0 # eMule",
                                       "# tcp 0.0.0.0:3389 192.168.178.20:3389 0 # MS Remote Desktop";
                        shaperconnection {
                                enabled = yes;
                                targets = "";
                                name = "Fritz!Box";
                                limiters {
                                        name = "default-out";
                                        bps_limit {
                                                limit_total = 100;
                                                limit_p0 = 0;
                                                limit_p1 = 95;
                                                limit_p2 = 95;
                                                limit_p3 = 0;
                                        pps_limit {
                                                limit_total = 0;
                                                limit_p0 = 0;
                                                limit_p1 = 0;
                                                limit_p2 = 0;
                                                limit_p3 = 0;
                                        min_priority = 0;
                                        max_priority = 3;
                                        grouping_by_source_ip = no;
                                        grouping_by_dest_ip = no;
                                        grouping_by_source_port = no;
                                        grouping_by_dest_port = no;
                                        dynamic_balancing = no;
                                        bps_child_limit {
                                                limit_total = 0;
                                                limit_p0 = 0;
                                                limit_p1 = 0;
                                                limit_p2 = 0;
                                                limit_p3 = 0;
                                        pps_child_limit {
                                                limit_total = 0;
                                                limit_p0 = 0;
                                                limit_p1 = 0;
                                                limit_p2 = 0;
                                                limit_p3 = 0;
                                        shapeOutgoingOnIncomingCounters = no;
                                        name = "default-in";
                                        bps_limit {
                                                limit_total = 0;
                                                limit_p0 = 0;
                                                limit_p1 = 0;
                                                limit_p2 = 0;
                                                limit_p3 = 0;
                                        pps_limit {
                                                limit_total = 0;
                                                limit_p0 = 0;
                                                limit_p1 = 0;
                                                limit_p2 = 0;
                                                limit_p3 = 0;
                                        min_priority = 0;
                                        max_priority = 0;
                                        bps_child_limit {
                                                limit_total = 0;
                                                limit_p0 = 0;
                                                limit_p1 = 0;
                                                limit_p2 = 0;
                                                limit_p3 = 0;
                                        pps_child_limit {
                                                limit_total = 0;
                                                limit_p0 = 0;
                                                limit_p1 = 0;
                                                limit_p2 = 0;
                                                limit_p3 = 0;
                                out_rules {
                                        name = "download-tcp-ack";
                                        filter = "tcp and len <= 64";
                                        priority = 2;
                                        limiters = "default-out";
                                        name = "dns";
                                        filter = "udp port 53";
                                        priority = 1;
                                        name = "fon-rtp";
                                        filter = "udp[8] = 0x80 or udp port 5060";
                                        priority = 3;
                                        name = "http-requests";
                                        filter = "(tcp dst port 80 or dst port 8080 or dst port 3128) and (len <= 800)";
                                        priority = 1;
                                        name = "pri-out";
                                        filter = "icmp";
                                        priority = 1;
                                        name = "default";
                                        filter = "";
                                        priority = 0;
                                in_rules {
                                        name = "default";
                                        filter = "";
                                        priority = 0;
                                        limiters = "default-in";
                                demasquerade = no;
                budget {
                        Enabled = no;
                        Period = 2;
                        VolumeLow = 0;
                        VolumeHigh = 0;
                        ConnectionTime = 0;
                        WarnOnly = yes;
        voip_routes = "permit ip any any connection exists",
                      "permit udp any eq 5060 any",
                      "permit udp any eq 7077 any eq 53",
                      "permit udp any range 7078 7085 any";
        voip_dsliface {
                ppptarget = "voip";
                stay_always_online = yes;
                redial_limit = 3;
                dsldpconfig {
                        lowinput {
                                policy = "permit";
                                accesslist = "permit udp any any",
                                             "permit icmp any any",
                                             "reject ip any any";
                        lowoutput {
                                policy = "permit";
                        highinput {
                                policy = "permit";
                        highoutput {
                                policy = "permit";
                                       "udp 0.0.0.0:7085 0.0.0.0:7085";
                        shaperconnection {
                                enabled = yes;
                                targets = "";
                                name = "voip";
                                demasquerade = no;
                budget {
                        Enabled = no;
                        Period = 2;
                        VolumeLow = 0;
                        VolumeHigh = 0;
                        ConnectionTime = 0;
                        WarnOnly = yes;
        targets {
                type = pppcfg_target_internet;
                name = "internet";
                only_crypt_auth = no;
                local {
                        username = "";
                        passwd = "";
                remoteauth = pppcfg_authtype_chap;
                remoteauth_only_on_incoming = yes;
                remote {
                inactivity_timeout = 5m;
                bUseChargeInterval = no;
                nChargeInterval = 1m;
                logicaldisconnect_with_physical = yes;
                disconnect_timeout = 0w;
                finaldisconnectcall = no;
                ipnetbiosspoofing = no;
                dnsfilter_for_active_directory = no;
                no_outgoing_calls = no;
                coso = pppcfg_coso_caller;
                callback_delay = 1s;
                icbmode = pppcfg_icbmode_none;
                ocbmode = pppcfg_ocbmode_none;
                mscbprefered = no;
                multilink {
                        extra_static_channels = 0;
                        max_channels = 1;
                        automatic = no;
                        automatic_param {
                                window = 20s;
                                add_percent = 85;
                                drop_percent = 70;
                                sportlich = no;
                header_compression = yes;
                data_compression = pppcfg_datacomp_auto;
                stac_reset_with_history_number = no;
                encryption = pppcfg_crypt_none;
                inactivity_prevention_interval = 0w;
                new_ipaddr_on_connect = no;
                my_ipaddr = 0.0.0.0;
                his_ipaddr = 0.0.0.0;
                bVolumeRoundUp = no;
                VolumeRoundUpBytes = 0;
                bProviderDisconnectPrevention = yes;
                ProviderDisconnectPreventionInterval = 1d;
                ProviderDisconnectPreventionHour = 3;
                name = "voip";
                local {
                        username = "";
                        passwd = "";
                remote {
                inactivity_timeout = 0w;
                mscbprefered = no;
                multilink {
                        max_channels = 1;
                        automatic = no;
                        automatic_param {
                                window = 20s;
                                add_percent = 85;
                                drop_percent = 70;
                                sportlich = no;
        StatisticStartOfMonth = 1;
        macdsl_override = 00:00:00:00:00:00;
servercfg {
        dns1 = 192.168.180.1;
        dns2 = 192.168.180.2;
websrv {
        port = "80";
        read_timeout = 15m;
        request_timeout = 30s;
        keepalive_timeout = 5m;
        nokeepalive = "*";
        errordir = "/usr/lib/websrv/errors";
        webdir = "/usr/www";
        cgidir = "cgi-bin";
        indexfn = "index.var", "index.htm", "index.html";
dhcpserver {
        saveinterval = 1h;
        generic {
                default_lease_time = 10d;
                max_lease_time = 13d;
dhcpclient {
        metric = 9;
dnsserver {
        cache_maxKB = 16;
        negative_ttl = 5m;
ddns {
        accounts {
                enabled = no;
                domain = "";
                iface = 0;
                username = "";
                passwd = "";
                ddnsprovider = "dyndns.org";
        types {
                type = "dyndns";
                url = "/nic/update?system=dyndns&hostname=<domain>&myip=<ipaddr>&wildcard=NOCHG";
                type = "dyndns-custom";
                url = "/nic/update?system=custom&hostname=<domain>&myip=<ipaddr>&wildcard=NOCHG";
                type = "dyndns-statdns";
                url = "/nic/update?system=statdns&hostname=<domain>&myip=<ipaddr>&wildcard=NOCHG";
                type = "noip";
                url = "/ducupdate.php?update=<b64>username=<username>&pass=<pass>&h[]=<domain>&ip=<ipaddr></b64>";
                type = "2mydns";
                url = "/dyn.asp?username=<username>&password=<pass>&hostname=<domain>&myip=<ipaddr>";
                type = "dns4biz";
                url = "/nic/update?hostname=<domain>&myip=<ipaddr>";
                type = "selfhost";
                url = "/nic/update?myip=<ipaddr>";
                type = "userdefined";
                url = "";
        provider {
                name = "dyndns.org";
                type = "dyndns";
                livedelay = 0w;
                touchtime = 30d;
                server = "members.dyndns.org";
                infourl = "http://www.dyndns.org/";
                name = "dyndns.org-custom";
                livedelay = 0w;
                touchtime = 30d;
                name = "dyndns.org-statdns";
                livedelay = 0w;
                touchtime = 30d;
                name = "No-IP.com";
                type = "noip";
                livedelay = 4m;
                touchtime = 0w;
                server = "dynupdate.no-ip.com:8245";
                infourl = "http://www.no-ip.com/";
                name = "2myDNS";
                type = "2mydns";
                livedelay = 0w;
                touchtime = 0w;
                server = "dyn.2mydns.com";
                infourl = "http://www.2mydns.com/";
                name = "DNS4BIZ.DE Premium";
                type = "dns4biz";
                livedelay = 0w;
                touchtime = 0w;
                server = "au-eu.dns4biz.net";
                infourl = "http://www.dns4biz.com/services_avm.php3";
                name = "DNS4BIZ.DE Business";
                type = "dns4biz";
                livedelay = 0w;
                touchtime = 0w;
                server = "au-eu.dns4biz.biz";
                name = "selfhost.de";
                type = "selfhost";
                livedelay = 0w;
                touchtime = 0w;
                server = "carol.selfhost.de";
                infourl = "http://www.selfhost.de";
                name = "Benutzerdefiniert";
                livedelay = 4m;
                touchtime = 0w;
                server = "";
                infourl = "http://";
webui {
        username = "";
        password = "";
        expertmode = yes;
        wizard_completed = yes;
capiovertcp {
        enabled = no;
        maxctrl = 1;
emailnotify {
        enabled = no;
        interval = daily;
        From = "";
        To = "";
        SMTPServer = "";
        accountname = "";
        passwd = "";
usbhost {
        readonly = no;
        password = "";
        autoprov_enabled = yes;
// EOF
Ich mache mir wirklich Sorgen, dass die Box etwas ernstes haben könnte... Bitte gebt doch kurz ein Feedback. Danke!
Gruss,
Stefan
In deiner ar7.cfg steht 3x die Zeile: OutFragmentWhenVoIP
Und die findet er nicht in den libs.
Ist wahrscheinlich von einer anderen Firmware.
Entweder lässt du die Zeilen stehen, oder kannst sie auch löschen...
Du verwendest die Fritz hinter einem Router?
Hast du mal probiert was der Unterschied zwischen mode = dsldmode_full_bridge und mode = dsldmode_both ist?
Würde mich mal interessieren...
MfG Oliver
Hallo Oliver,
ich hoffe du hast recht und meine Box hat keinen schleichende Krankheit. Kann schon sein das die Zeilen seit dem letzten FW Update auftauchen.
Ich betreibe die Box hinter einem Kabelmodem, ist also eigentlich schon ein Router. Nein, die beiden Modes habe ich nicht getestet. Zusätzlich ist mit in einer anderen hier geposteten ar7.cfg noch der Eintrag mode = dsldmode_bridge aufgefallen. Keine Ahnung was die Unterschiede bedeuten.
Weiss hier jemand mehr?
Gruss,
Stefan
"OutFragmentWhenVoIP" ist aus dem Trafficshaping der 7050.
Da wird die Variable aber nur einmal gesetzt.
Probier mal aus was passiert wenn du die Einträge löscht und die Variable nur einmal nach der Zeile "shaperconnection { " einfügst.
tempuser777
